Donut Supercharged December 23, 2014 Share December 23, 2014 Hi all, i got some kitchen tiles that are not v well done. Been like this for past 10-12 years with no problem. just that i get abit irritated sometimes. i want to diy some repairs, is there something like epoxy or adhesive liquid that i can inject into the grout? some grout lines have no cement, so there are gaps where i can inject the tiles are not cracked or damaged. just that some have hollow sound or loose. ↡ Advertisement Link to post Share on other sites More sharing options...
Gitanic 6th Gear December 23, 2014 Share December 23, 2014 hollow tiles can play drumming,why fill it up. Link to post Share on other sites More sharing options...
Evillusion Supersonic December 23, 2014 Share December 23, 2014 Hi all, i got some kitchen tiles that are not v well done. Been like this for past 10-12 years with no problem. just that i get abit irritated sometimes. i want to diy some repairs, is there something like epoxy or adhesive liquid that i can inject into the grout? some grout lines have no cement, so there are gaps where i can inject the tiles are not cracked or damaged. just that some have hollow sound or loose. i have those hollow sound for 20 yrs liao.....my neighbour's flat the living room tiles popped out! Was told by reno contractors it may happen if the tiles are placed to close to each other. Can oni suggest u to stop knocking or play marbles in your house/flat......hahaha! Link to post Share on other sites More sharing options...
Jman888 Moderator December 23, 2014 Share December 23, 2014 Hi all, i got some kitchen tiles that are not v well done. Been like this for past 10-12 years with no problem. just that i get abit irritated sometimes. i want to diy some repairs, is there something like epoxy or adhesive liquid that i can inject into the grout? some grout lines have no cement, so there are gaps where i can inject the tiles are not cracked or damaged. just that some have hollow sound or loose. if the problem come from below the tile, unless you relay the affected tile, i think the noise will still be there. Link to post Share on other sites More sharing options...
Lala81 Hypersonic December 23, 2014 Share December 23, 2014 Can't do much from your side. Grouting u should be able to fill up. But hollow or loose tiles are another thing all together Link to post Share on other sites More sharing options...
Gitanic 6th Gear December 23, 2014 Share December 23, 2014 Can't do much from your side. Grouting u should be able to fill up. But hollow or loose tiles are another thing all together Dr Lala Merry Christmas! 1 Link to post Share on other sites More sharing options...
Soya Supersonic December 23, 2014 Share December 23, 2014 Hi all, i got some kitchen tiles that are not v well done. Been like this for past 10-12 years with no problem. just that i get abit irritated sometimes. i want to diy some repairs, is there something like epoxy or adhesive liquid that i can inject into the grout? some grout lines have no cement, so there are gaps where i can inject the tiles are not cracked or damaged. just that some have hollow sound or loose. Hollow sounding tiles is due to insufficient mortar cement under the tile during the laying process. Grouting from gaps between tile won't help. Unfortunately, the proper solution is to hack & re-tile. Link to post Share on other sites More sharing options...
Porker Turbocharged December 23, 2014 Share December 23, 2014 Hollow sounding tiles is due to insufficient mortar cement under the tile during the laying process. Grouting from gaps between tile won't help. Unfortunately, the proper solution is to hack & re-tile. Please get the bangla to do it 😂 Link to post Share on other sites More sharing options...
Kklee 6th Gear December 23, 2014 Share December 23, 2014 i got some kitchen tiles that are not v well done. Been like this for past 10-12 years with no problem. just that i get abit irritated sometimes. In my experience, I also thought that nothing will happen to the 10 years old (IIRC) the kitchen tiles as they are smaller and thicker.... until they popped. Link to post Share on other sites More sharing options...
Volvobrick Hypersonic December 23, 2014 Share December 23, 2014 My parent's flat built in the late 80's till today tiles still very solid. Workmanship then was much much better. Link to post Share on other sites More sharing options...
Extinguisher 6th Gear December 23, 2014 Share December 23, 2014 Yes hollow tiles will be at risk of popping. Happened to me last time in the middle of the night. Woke up by the sound of exploding tiles. Once they pop, the whole lot will all pop. Link to post Share on other sites More sharing options...
Kangadrool Supersonic December 23, 2014 Share December 23, 2014 Do nothing is the best solution. This mostly will happen to all homogeneous tiles due to or Huay shrinking over time. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Sound Proofing the car
Whole car sound proof
Right side speakers no sound
Metal grinding sound on civic
