BabyBlade Internal Moderator November 24, 2014 Share November 24, 2014 Lets say car average petrol fc is 10km/l, how much time of idling in minutes will consume one litre of petrol? And why would you car be idling for so long................ ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Cephas 3rd Gear November 24, 2014 Share November 24, 2014 Quoted from this webpage: http://livingstingy.blogspot.sg/2011/12/idling-your-engine.html Idling cars are usually the sign of idling minds. Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear November 24, 2014 Share November 24, 2014 Car risk overheat if idle too long. Its not the petrol cost..but rather maintenance.. and most importantly environmental cost. Imagine small kids outside near yr car.. they will be taking in the exhaust at the expense of yr comfort. 2 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic November 24, 2014 Author Share November 24, 2014 And why would you car be idling for so long................ hmmm sleep? Link to post Share on other sites More sharing options...
Kklee 6th Gear November 24, 2014 Share November 24, 2014 Car risk overheat if idle too long. Its not the petrol cost..but rather maintenance.. and most importantly environmental cost. Imagine small kids outside near yr car.. they will be taking in the exhaust at the expense of yr comfort. On the overheat, it is not an issue if the car is maintenance is done correctly. 1 Link to post Share on other sites More sharing options...
Darryn Turbocharged November 24, 2014 Share November 24, 2014 Here's a cite... Depending on your vehicle, every 10 minutes of idling is costing you between 1/10 and 4/10′s of a liter of fuel. ....taking the midpoint as 25/100 of a litre per 10 minutes that's 1.5 litres per hour Here's a different cite Table 1. Idling Emissions and Fuel Use per Second... 0.279cc ... which is almost exactly 1 litre per hour.... Here it say's a "quart every 15 minutes" - which would make it 3.5 litres per hour...Personally I think that's WAY too much (based on my personal experience) Here's one cite that says 1.2 litres / hr for a 3.8 litre V6 Final Cite ....max seems to be around 0.36 gallons per hour with air-con running...which would be 1.36 litres per hour. So my best estimate - you can assume between 1 and 1.5 litres per hour 2 Link to post Share on other sites More sharing options...
Kklee 6th Gear November 24, 2014 Share November 24, 2014 Just off topic a bit,my 2013 Mazda 6 clocked 96 Hrs in the i-Stop[start/stop system],used a total of less than 23,000km,just changed my battery,it needs a so called Q-85 battery,costed $319.00 ,so does the start/stop system actually save $$.?Yes.. for a greener enviroment ,but for my pocket..no .a normal 2.0 or 2.5 Japanese car battery costed the most $150.00,but this Q-85 costed more than double.! Assumption a) At idle, the FC of a vehicle is 1.5 litres per hour. b) Cost of petrol is $2.05 For a total of 96 hours, if with the start-stop system, the cost is 96hrs x 1.5 LPH x $2.05 = $ 295.20 Effectively, deducting this cost from the $319 (cost of the Q-85 battery), your loss is $23.80 Link to post Share on other sites More sharing options...
Detach8 5th Gear November 24, 2014 Share November 24, 2014 If one really want to know how idle consumption is, Very close estimation will be: 1) Fill the tank to the brim 2) Move slowly to the carwash behind (auto cars, don't accelerate. Manual cars, slip into 1st gear and let go clutch and don't accelerate as well). 3) idle while washing. 4) go back to pump. Use the time at 2-4 and fuel use for the 2nd top up. I think cannot like that. Isn't there a minimum. for the number of litres to top up? Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged November 24, 2014 Share November 24, 2014 I think cannot like that. Isn't there a minimum. for the number of litres to top up? In UK I know there is a min. In Singapore I didn't know there is. So what if one cannot meet the minimum? Waive or have to top up? Then if have to top up, the system itself betrays the min require fuel. If I were to top up $0.20, I place back the nozzle. Go to cashier say payment, cashier say there is a minimum purchase require say $2.00 Then I go to top up $1.80 and $0.20 previous purchase, it still lack of the minimum $2.00 per top up right. Then, where is the notice for the minimum top up require? If there isn't any notice, the seller forces buyer to top up more than require. Like jover chew case, buy phone without warranty and top up for warranty. 1 Link to post Share on other sites More sharing options...
Darryn Turbocharged November 24, 2014 Share November 24, 2014 If not wrong I think pumps do have a minimum delivery volume, I think it is a technical requirement of how they are set up rather than a policy of kiosk. Last time I think it was 2 litres, not sure if still like that or not. Link to post Share on other sites More sharing options...
Detach8 5th Gear November 24, 2014 Share November 24, 2014 I think the entire hose takes 1-2L of fuel. It's impossible to deliver you 10ml if the pump has to push 2L out into the hose before it reaches your car. 1 Link to post Share on other sites More sharing options...
Nicfoo Turbocharged November 24, 2014 Share November 24, 2014 I wonder mah since car manufacturers dont provide these details Moreover I am not elites neither ASK le My on board com only show max 25km/100l Unless my fuel level shows the litre of petrol left in the tank I am not sure if you are Elite or not, but I am here long enough to know you are known as the MCF in house ASK. LOL 2 Link to post Share on other sites More sharing options...
Vyeron 4th Gear November 24, 2014 Share November 24, 2014 Long hours of idling.. isnt it accumulating carbon? Link to post Share on other sites More sharing options...
Nicfoo Turbocharged November 24, 2014 Share November 24, 2014 hmmm sleep? In the day or at night? LOL 1 Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged November 24, 2014 Share November 24, 2014 Later this week I go pump petrol and squeeze the min litre out. If can squeeze $0.20, I will pump back pump and re-pump again to $65. See whether the cashier black face to me or not. Link to post Share on other sites More sharing options...
Super7 Turbocharged November 24, 2014 Share November 24, 2014 And why would you car be idling for so long................ Sit inside car using 手机 surf mcf, need engine running to keep aircon cold? 行吧!? KekekeElse don't ask him embarrassing questions lor. Link to post Share on other sites More sharing options...
Super7 Turbocharged November 24, 2014 Share November 24, 2014 Long hours of idling.. isnt it accumulating carbon? No problem. This will give him a good excuse to burn / clear carbon!!! Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic November 24, 2014 Author Share November 24, 2014 In the day or at night? LOL normally when? lol ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Share Your Car Fuel Consumption
Very bad fuel consumption 🥴
Is your car's fuel meter accurate?
FC and performance for drivers
Show your car Driver Info System (a.k.a how is your FC?)
Ban on idling engines
