bingkok 1st Gear November 22, 2014 Share November 22, 2014 Anyone had installed this model for car video recording??? Looking 1 for my new car. I wasn't very familiar with car video recorder. My concern is will the recorder able to record after i off the engine and left?? So that I can look back the video if my car kena bang when I am not around. Does it necessary to have the GPS function and the power magic if I were to connect to my car battery?? ↡ Advertisement Link to post Share on other sites More sharing options...
Cicada1810 1st Gear May 21, 2015 Share May 21, 2015 Hi Mine is a Blackvue DR650 2Ch with Wifi. What u r referring to is parking mode where it runs after engine is off. With this, you need to buy a Power Magic Pro. This baby helps to monitor the battery usage during parking mode. Once the battery is drained till a certain level, the power magic pro will shut down the cam to conserve your car battery. The power magic pro also allows you to turn it off if you dun want parking mode You can leave the cam on and the duration can be set by you - from 6 hrs to Infinity. What i do for my new car is I set to 12 hr duration at 12 volts (as stated in my battery). Before I drive off, I do a round car check to make sure no knocks, scratchez, denta, damage etc. If have, check ur cam. This cam is also linked to your smartphone to view and save videos. It comes with a 16gb card. You might want to change to 64 Gb.i did, so that my recording will not be so be frequently overwritten. Anyone had installed this model for car video recording??? Looking 1 for my new car. I wasn't very familiar with car video recorder. My concern is will the recorder able to record after i off the engine and left?? So that I can look back the video if my car kena bang when I am not around. Does it necessary to have the GPS function and the power magic if I were to connect to my car battery?? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear May 22, 2015 Share May 22, 2015 make sure u use a UHS-1 rated card with 30-45mb/s WRITE SPEED, not read speed...for SINGLE CHANNEL for DOUBLE CHANNEL 1080hd front + 720hd rear, at least 45-60mb WRITE for DUAL 1080 cams, get higher than 60 ideally samsung evo , samsung pro strontium nitro, nitro plus dont bother sandisk, too high failure rate Link to post Share on other sites More sharing options...
Kippei 3rd Gear May 24, 2015 Share May 24, 2015 DR750 dont need magic pro. Depend on where you buy. The cable given might be different. Link to post Share on other sites More sharing options...
angmoh 1st Gear May 24, 2015 Share May 24, 2015 The power magic pro also allows you to turn it off if you dun want parking mode if without Magic Pro, can we still turn off the Parking Mode from the cam itself? ↡ Advertisement Link to post Share on other sites More sharing options...
Green fingers anyone?
Aquatic Plants - Anyone into it as well?
Give aways
Give aways
