Palad1m 1st Gear November 5, 2014 Share November 5, 2014 Hi guys, any of you VW owners have this problem? i need to lock/ unlock whilst singing a song to unlock the fuel flap went down VW, need $120 to fix anyway the fuel flap can be manually opened? ↡ Advertisement Link to post Share on other sites More sharing options...
Soya Supersonic November 5, 2014 Share November 5, 2014 No problem lah. Since DSG broke down, car wun be moving so no need to refuel. 1 Link to post Share on other sites More sharing options...
TVT Supercharged November 5, 2014 Share November 5, 2014 What did the VW say was wrong with the fuel flap that means $120 to fix ? Link to post Share on other sites More sharing options...
Quantum 5th Gear November 5, 2014 Share November 5, 2014 Hi guys, any of you VW owners have this problem? i need to lock/ unlock whilst singing a song to unlock the fuel flap went down VW, need $120 to fix anyway the fuel flap can be manually opened? if manually open, you will permanently damage the lock, is your car under warranty? if not go outside WS, Link to post Share on other sites More sharing options...
Palad1m 1st Gear November 5, 2014 Author Share November 5, 2014 wahaha, choi! No problem lah. Since DSG broke down, car wun be moving so no need to refuel. Link to post Share on other sites More sharing options...
Keithchue 5th Gear November 5, 2014 Share November 5, 2014 is it the locking mechanism??see if you can talk to them. the fuel door should not breakdown.. but then again, what do I know Link to post Share on other sites More sharing options...
Enye Hypersonic November 5, 2014 Share November 5, 2014 Mine just press the fuel flap to open then press again to close. Link to post Share on other sites More sharing options...
Watwheels Supersonic November 5, 2014 Share November 5, 2014 http://www.golfmk7.com/forums/showthread.php?t=433 http://www.golfmk7.com/forums/showthread.php?t=2354 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged November 5, 2014 Share November 5, 2014 vw quality really can, i 干拜下风 2 Link to post Share on other sites More sharing options...
Mrmilktooth Supercharged November 5, 2014 Share November 5, 2014 i need to lock/ unlock whilst singing a song to unlock the fuel flap sorry but i dont get you.. you sang to your fuel flap to get it to open??.. like ali baba movie... "open sesame" ... Link to post Share on other sites More sharing options...
Quantum 5th Gear November 5, 2014 Share November 5, 2014 Mine just press the fuel flap to open then press again to close. like that people easily steal petrol by suction pump 1 Link to post Share on other sites More sharing options...
TVT Supercharged November 5, 2014 Share November 5, 2014 Mine just press the fuel flap to open then press again to close. U mean like those soft-close mechanism we used in cabinet/drawer doors ?? Link to post Share on other sites More sharing options...
Jamesc Hypersonic November 5, 2014 Share November 5, 2014 Aiyah no need to waste $120 to fix this lah. Just use this. Cheap and effective. 2 Link to post Share on other sites More sharing options...
Furrynadz 5th Gear November 5, 2014 Share November 5, 2014 best dont let pump attendant touch some really try to "giao" your door till spoil those press to release they try pry it those must die die open in car they keep press and press and press those flap open and need key open cap they try giao the damn cap Link to post Share on other sites More sharing options...
Palad1m 1st Gear November 5, 2014 Author Share November 5, 2014 i am surprised VW dun allow a manual over ride to open the fuel flap. at least some form of fail safe to open, if not no petrol how? call tow truck meh Link to post Share on other sites More sharing options...
Camrysfa Turbocharged November 5, 2014 Share November 5, 2014 Put on white gloves . . . 1 Link to post Share on other sites More sharing options...
Phillim 3rd Gear November 5, 2014 Share November 5, 2014 If in such a case, try opening and closing with the remote several times while de-pressing the flap to open, it happened to mine as well. Cheers PS it might take quite some time before it finally opens, when it does, try spraying some lithium lubricant to help in future. Philip Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 5, 2014 Share November 5, 2014 normally the latch is made of plastic. Try using metal rule/flat head screw driver to push it a bit. ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Volkswagen ID. Buzz
Xpeng is Coming to Town
Volkswagen Sharan..
Volkswagen Sharan..
Where to mod fuel needle?
800-seat Bukit Canberra Hawker Centre with 44 stalls to open on Dec. 17
2022 Toyota GR Corolla
