Kklee 6th Gear October 28, 2014 Share October 28, 2014 Just feel like sharing these videos on ABS. The more interesting ones will be the Camry e-braking. Bigger cars definitely need ABS ! Toyota Vios Brake Test without ABS and Dry Surface @ 120 kph Toyota Vios Brake Test with ABS and Dry Surface @ 120 kph Toyota Camry Brake Test without ABS and Dry Surface @ 120 kph Toyota Camry Brake Test with ABS and Dry Surface @ 120 kph ↡ Advertisement 5 Link to post Share on other sites More sharing options...
Typhoonz 4th Gear October 28, 2014 Share October 28, 2014 (edited) First clip forward to 30 sec mark unless you like to see grown men standing around... 2nd clip 10 sec mark... Edited October 28, 2014 by Typhoonz 2 Link to post Share on other sites More sharing options...
Contipro 5th Gear October 28, 2014 Share October 28, 2014 in terms of stopping distance, don't see much different between the w/ ABS and w/o ABS.. so what's the conclusion ? Link to post Share on other sites More sharing options...
LoverofCar 6th Gear October 28, 2014 Share October 28, 2014 May be i blur like sotong...the two video suppose to provide us a visual judgement of having and without ABS? I see no different ,.. Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic October 28, 2014 Share October 28, 2014 Might as well without abs, maybe cheaper price Link to post Share on other sites More sharing options...
ST69 4th Gear October 28, 2014 Share October 28, 2014 you'll see more difference when its tested on wet road. Prevents brakes from locking & hence skidding. seems that the test is done in Thailand. Didnt know Camry also made there. 4 Link to post Share on other sites More sharing options...
Shibadog Turbocharged October 28, 2014 Share October 28, 2014 uhm...why test on dry surface? shld test abs on wet/icy/slippery surface to see the effect, on a non-professional driver. 3 Link to post Share on other sites More sharing options...
Friendstar Supercharged October 28, 2014 Share October 28, 2014 Jam brake in the Wet plus directional change. True test. Btw. Nearly all cars come with abs. So what's the purpose of this? 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged October 28, 2014 Share October 28, 2014 ABS make alot of drivers "Overconfident" ,drive closer,results.??Also alot of accident,with or without ABS,we still to leave a distance between cars. 2 Link to post Share on other sites More sharing options...
Kklee 6th Gear October 28, 2014 Author Share October 28, 2014 (edited) In my comparison, assuming they never shift the truck truck in the background. Vios - with or without ABS, the stopping distance seems the same Camry - without ABS, the stopping distance is way longer compared with VIOS. With ABS, the distance seems shorter compared with Vios. Here are the wet ones. Toyota Corolla Altis Brake Test without ABS and Wet Surface @ 80 kph https://www.youtube.com/watch?v=zmBeE6mvSgQ Toyota Corolla Altis Brake Test with ABS and Wet Surface @ 80 kph https://www.youtube.com/watch?v=iUZR_XGVsFc Toyota Fortuner Brake Test without ABS and Wet Surface @ 80 kph https://www.youtube.com/watch?v=4GPGzCseXqc Toyota Fortuner Brake Test with ABS and Wet Surface @ 80 kph https://www.youtube.com/watch?v=hwZEx-Rt0gw Edited October 28, 2014 by Kklee Link to post Share on other sites More sharing options...
Earthboy 4th Gear October 28, 2014 Share October 28, 2014 ABS make alot of drivers "Overconfident" ,drive closer,results.??Also alot of accident,with or without ABS,we still to leave a distance between cars. such people are ill informed. ABS is anti lock, not brake more jiak. ironically, in dry surface ABS kick in may cause accident. it free up the brake and the car cant stop on time/need a longer distance to come to a complete stop. 4 Link to post Share on other sites More sharing options...
Kklee 6th Gear October 28, 2014 Author Share October 28, 2014 (edited) such people are ill informed. ABS is anti lock, not brake more jiak. ironically, in dry surface ABS kick in may cause accident. it free up the brake and the car cant stop on time/need a longer distance to come to a complete stop. If you see the Camry videos with and without ABS, you may think otherwise. Edited October 28, 2014 by Kklee Link to post Share on other sites More sharing options...
Typhoonz 4th Gear October 28, 2014 Share October 28, 2014 Might as well without abs, maybe cheaper price In this case for the Vios with or without ABS it's the same... But perhaps result might differs with a full load? Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 28, 2014 Share October 28, 2014 ABS is not about braking distance. Its maintaining steering control when your wheel is locked up without ABS assistance . 2 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic October 28, 2014 Share October 28, 2014 ABS is not about braking distance. Its maintaining steering control when your wheel is locked up without ABS assistance . Yes its about steering control, without abs ur braking will be out of lane and brake will also stuck Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 28, 2014 Share October 28, 2014 In another word, Car without ABS: When the wheel locked up under hard braking, no matter how you steer L or R to avoid frontal collision, it will just go straight on. Link to post Share on other sites More sharing options...
Soya Supersonic October 28, 2014 Share October 28, 2014 Duhh.....what a pointless ABS test in the dry n straight line. ABS is abt maintaining control n swerving around the danger in the wet. 2 Link to post Share on other sites More sharing options...
Watwheels Supersonic October 28, 2014 Share October 28, 2014 (edited) In real life situations I dun think conditions will be like these tests. What I dun like about Japanese cars here is that they dun come with ESP or stability control. Some dun even have traction control that comes as standard. ABS is to stop your wheels from slipping or lose traction on dry/wet surface...when you are stopping. Traction control stops your wheels from slipping when your car is accelerating. Stability control or ESP stops your car from sliding sideways by cutting power whenever neccessary. We saw here how the Altis w/o ABS on the wet tried to stop. It slided sideways. Imagine this Altis even with ABS tries to avoid obstacles by swerving left & right before coming to a full stop. W/o ESP it will most likely slide sideways. Start from 6:04 to watch the ESP test. Like what Tiff mentioned, ABS and traction control works well on the straight line... http://www.youtube.com/watch?v=Wkzbavyv7Vo In reality we need all three, ABS, Traction Control & ESP to avoid potential accidents. Edited October 28, 2014 by Watwheels ↡ Advertisement 4 Link to post Share on other sites More sharing options...
Toyota Corolla Cross
K-DENT P.D.R & Windshield Repair
2018 3rd Generation Toyota Century
Toyota Voxy/Noah/Esquire
4th Gen - 2020 Toyota Harrier
Toyota Land Cruiser Mini
