DarkFly3r 1st Gear October 2, 2014 Share October 2, 2014 Hi, i am driving Vios NCP93. I have recently replaced my shock absorbers to KYB in JB. Now whenever i go over hump, it makes noise especially when going over at a faster speed. No noise issue during cruising.Please recommend me a experience workshop locally that could solve this issue. Thank you guys. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Suhaimiebrahim 1st Gear October 2, 2014 Share October 2, 2014 Hi Bro, You may try calling Eric of Jeep Chee Trading. Contact no:6745 4700 or mobile no 9635 0350 cheers 1 Link to post Share on other sites More sharing options...
Pms 3rd Gear October 2, 2014 Share October 2, 2014 Did you change the top rubber mounts aka strut mounts. Probably it is due worn mounts or the bearing in it is worn and maybe one of the bolts that tighten both the mounts and shocks is loose. You should inspect in a reverse order of the above. 2 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 2, 2014 Share October 2, 2014 (edited) sry TS borrow ur thread for question - when turning into parking lot in reverse til certain point, there is a tok sound from rear. what could be the issue? other than that, no leaking in shocks & normal travel no sound, though travelling over paving blocks may have slight "loose clocking" sound from rear. Edited October 2, 2014 by Fuelsaver 1 Link to post Share on other sites More sharing options...
GAN59 Clutched October 3, 2014 Share October 3, 2014 u could try hanip automotive sent my car there and problem solve 1 Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear October 3, 2014 Share October 3, 2014 (edited) Fuelsaver, I suspect it's the ball bearing worn out. Driving big car? Big rims? Aging car? Edited October 3, 2014 by Ladykillerz 1 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 4, 2014 Share October 4, 2014 Fuelsaver, I suspect it's the ball bearing worn out. Driving big car? Big rims? Aging car?Bro it's at the rear only n during normal driving no sound very smooth. My wheels big bt not rims, ride is 7yo n 115k km Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear October 4, 2014 Share October 4, 2014 is it a loud thumb sound when the rear compresses after a hump? Link to post Share on other sites More sharing options...
Pms 3rd Gear October 4, 2014 Share October 4, 2014 Most people never replace the rubber mounts when replacing the shocks. The fact is both have to be replaced together. Link to post Share on other sites More sharing options...
Vicsaw Clutched October 4, 2014 Share October 4, 2014 sry TS borrow ur thread for question - when turning into parking lot in reverse til certain point, there is a tok sound from rear. what could be the issue? other than that, no leaking in shocks & normal travel no sound, though travelling over paving blocks may have slight "loose clocking" sound from rear. It could be sway bar links or sway bar bush. Fuelsaver, I suspect it's the ball bearing worn out. Driving big car? Big rims? Aging car? If wheel bearing worn out, will have constant helicopter sound. 1 Link to post Share on other sites More sharing options...
bigmikal Neutral Newbie October 4, 2014 Share October 4, 2014 It could be the bushing issue. My experience is when going to the humps, it has the "crack" sound. The mechanic told me it was the bushing that has worn out. Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear October 4, 2014 Share October 4, 2014 (edited) It could be sway bar links or sway bar bush. If wheel bearing worn out, will have constant helicopter sound. vios rear suspension is torsion beam setup dont have sway bar one unless you install after market. I suspect is when mechanic replace the absorber they never install back the abosrber bump or cushion that when it completely compress the spring the bump act as a cushion. Another possibility is that the bushes that hold the torsion beam is worn out and need to be replace. see the parts in square. Edited October 4, 2014 by Ivanpaseo Link to post Share on other sites More sharing options...
Othello Supersonic October 4, 2014 Share October 4, 2014 Hi, i am driving Vios NCP93. I have recently replaced my shock absorbers to KYB in JB. Now whenever i go over hump, it makes noise especially when going over at a faster speed. No noise issue during cruising. Please recommend me a experience workshop locally that could solve this issue. Thank you guys. why not go back to the workshop where you changed? Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 5, 2014 Share October 5, 2014 It could be sway bar links or sway bar bush. If wheel bearing worn out, will have constant helicopter sound. Coming fr rear only bro. Link to post Share on other sites More sharing options...
Vicsaw Clutched October 5, 2014 Share October 5, 2014 Coming fr rear only bro.[/quote Rear also have. My car has them. Link to post Share on other sites More sharing options...
Brobear 2nd Gear October 7, 2014 Share October 7, 2014 Hi, i am driving Vios NCP93. I have recently replaced my shock absorbers to KYB in JB. Now whenever i go over hump, it makes noise especially when going over at a faster speed. No noise issue during cruising. Please recommend me a experience workshop locally that could solve this issue. Thank you guys. Mine also have the same issue but my ride is an Altis. Please share if you found out what is causing the sound, . Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear October 7, 2014 Share October 7, 2014 Mine also have the same issue but my ride is an Altis. Please share if you found out what is causing the sound, . rear top mount might be faulty. but this part seldom spoil as compare to front one as front has bearing but not impossible. Link to post Share on other sites More sharing options...
Ken_leong 2nd Gear October 7, 2014 Share October 7, 2014 I'm driving a MAZDA a nd currently have the same problem. Changed the bushing, absorber and rear rubber stop at the top of the shocks. Problem persists. Workshops I been to can't find the problem and only put grease on the bushing and absorbers. One even dare tell me it's because my exos is hitting the bumper. So do recommend a good workshop for us if anyone has any. ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Land Cruiser Mini
Toyota Corolla Cross
Next Generation Toyota Crown
Toyota shows how GR Yaris is made, hints at more GR cars
8th Gen Toyota Camry (XV70)
2020 Toyota GranAce Premium
