Kangadrool Supersonic September 22, 2014 Share September 22, 2014 Seems like there's 2 versions as I gathered from the web - one is traditional pull open type, another type is like tray type. Not too sure about those imported here. Didn't scrutinize it during the sneak preview. I wonder if the glovebox is the same size (tiny) as the rest of the French cars. more important is the acceleration figure from 0-60 km/hr. It's based on the Clio. It's small. Like the polo cross. Mini crossovers.Its engine is the same as those used in their vans. Turbodiese although has loads of torque the 0-100km/he timing can be disappointing. But that few seconds more won't feel a lot on road cars. ↡ Advertisement Link to post Share on other sites More sharing options...
Rickster 5th Gear September 22, 2014 Share September 22, 2014 I was at vivo yesterday. Saw the captur at the Renault displays. Nice exterior but interior can comfortably take 4 persons. 5 would be a squeeze unless all back passengers are very small sized. One key irritant I have is that it uses hand brake...i thought hand brake is an almost obsolete item? It's also equipped with rear drum brakes... Link to post Share on other sites More sharing options...
Kangadrool Supersonic September 22, 2014 Share September 22, 2014 (edited) Many of Renault models use this 1.5 CRDi engine including the rebranded MB Citan. Tested both Grand Scenic and Captur, Captur has better drive as far as acceleration and throttle response is concerned. Tuning is slightly different across different models. Not too sure about the Megane hatch as it's too tight and low = so never bother about it. 1.5 turbo, crdi, 88bhp@4000rpm, 220nm torque.0 to 100 13.5sec, so slow considering the high torque. Car must be very heavy. Drums can save a lot of $$$ as conti discs are normally more expensive and require earlier replacement than Japenis. It's also equipped with rear drum brakes... Edited September 22, 2014 by Kangadrool 1 Link to post Share on other sites More sharing options...
Rickster 5th Gear September 22, 2014 Share September 22, 2014 Seems like there's 2 versions as I gathered from the web - one is traditional pull open type, another type is like tray type. Not too sure about those imported here. Didn't scrutinize it during the sneak preview. more important is the acceleration figure from 0-60 km/hr. Renault bread n butter cars generally have very relaxed acceleration figures, like typical french lifestyle. Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 23, 2014 Share September 23, 2014 I wonder if the glovebox is the same size (tiny) as the rest of the French cars. The reason French cars have tiny glove boxes is that the French men only needs to put his cap in there. 4 Link to post Share on other sites More sharing options...
jarjar Clutched September 24, 2014 Share September 24, 2014 looks really interesting, how does it compare with Citroen Picasso 5 seater and Peugeot 2008? Link to post Share on other sites More sharing options...
Kangadrool Supersonic September 24, 2014 Share September 24, 2014 (edited) The main and important part of a car is gearbox and engine. For Citrus and F&N cars, they like to use the irritating EGS which majority of the people can't cope and handle. For the Diamond, it's using the 6-speed dual clutch. Take note, these are not real SUVs, just simply a jacked up hatch with 2-wheel drive functionality. looks really interesting, how does it compare with Citroen Picasso 5 seater and Peugeot 2008? Edited September 24, 2014 by Kangadrool Link to post Share on other sites More sharing options...
jarjar Clutched September 24, 2014 Share September 24, 2014 I see, besides gearbox, reliability and service wise, any ideas between these three brands? The main and important part of a car is gearbox and engine. For Citrus and F&N cars, they like to use the irritating EGS which majority of the people can't cope and handle. For the Diamond, it's using the 6-speed dual clutch. Take note, these are not real SUVs, just simply a jacked up hatch with 2-wheel drive functionality. Link to post Share on other sites More sharing options...
Heman75 Supercharged September 24, 2014 Share September 24, 2014 The main and important part of a car is gearbox and engine. For Citrus and F&N cars, they like to use the irritating EGS which majority of the people can't cope and handle. For the Diamond, it's using the 6-speed dual clutch. Take note, these are not real SUVs, just simply a jacked up hatch with 2-wheel drive functionality. Can share what so irritating about ESG gear box? 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic September 24, 2014 Share September 24, 2014 LOL, it's jerky like changing gear without clutch or with poor clutch control. Very unintuitive and unnatural. You need to control and time very well on your gas pedal based on the robotized GB's shift. Otherwise, kick kock kick kock....... Can share what so irritating about ESG gear box? Service wise, I will take the Diamond. I see, besides gearbox, reliability and service wise, any ideas between these three brands? Link to post Share on other sites More sharing options...
Heman75 Supercharged September 24, 2014 Share September 24, 2014 LOL, it's jerky like changing gear without clutch or with poor clutch control. Very unintuitive and unnatural. You need to control and time very well on your gas pedal based on the robotized GB's shift. Otherwise, kick kock kick kock....... Service wise, I will take the Diamond. Then any good thing about ESG GB? Link to post Share on other sites More sharing options...
Kangadrool Supersonic September 24, 2014 Share September 24, 2014 nothing. Then any good thing about ESG GB? Link to post Share on other sites More sharing options...
jarjar Clutched September 26, 2014 Share September 26, 2014 Any idea comparing with new Honda Vezel. seems quite similar..... 1 Link to post Share on other sites More sharing options...
Currahee Clutched September 29, 2014 Share September 29, 2014 tried the car... abit tight in space.. think it is almost same or smaller than the swift for the rear passengers.. torque present since diesel.. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 5, 2014 Share October 5, 2014 Any idea comparing with new Honda Vezel. seems quite similar.....Think go for vezel should b wiser for few reasons like resale value, reliability, spaciousness. Just went for captur test drive. Diesel version performance seemed ok but in manual mode gb not as responsive or immediate as I'd liked it to be, si nice it being dct. Cvt w paddle shift should feel better IMHO. Link to post Share on other sites More sharing options...
Kangadrool Supersonic October 5, 2014 Share October 5, 2014 Think the rear seats were pushed forward (enlarged boot)? If it's pushed backward (normal boot position), the leg room is spacious. My complaint is, the rear seats are rather flat. tried the car... abit tight in space.. think it is almost same or smaller than the swift for the rear passengers.. torque present since diesel.. Link to post Share on other sites More sharing options...
Sweeney 4th Gear October 7, 2014 Share October 7, 2014 nothing. If the ESG is somewhat like the Duologic in Fiat, then my 2 cents on the advantage is that it is a manual GB that the driver can play with. I often do that in my Fiat. Downshifting for corners gives more me more control that normal ATs. On rare occasions, I would downshift once to over-take with almost immediate response. Can also drag on gear (when FULL manual mode) to higher RPMs before shifting up. I am happy to have the dulogic, but the jerkiness that some forummers mentioned is there, but have gotten used to the idiosyncrasies and adapted to it. Link to post Share on other sites More sharing options...
Kangadrool Supersonic October 7, 2014 Share October 7, 2014 I rather stick to real manual as it's more natural, can half-clutch when needed. Most modern clutch pedals are very light. In fact, Fiat is the lightest of all I tested. So, no reason not to drive real manual. If the ESG is somewhat like the Duologic in Fiat, then my 2 cents on the advantage is that it is a manual GB that the driver can play with. I often do that in my Fiat. Downshifting for corners gives more me more control that normal ATs. On rare occasions, I would downshift once to over-take with almost immediate response. Can also drag on gear (when FULL manual mode) to higher RPMs before shifting up. I am happy to have the dulogic, but the jerkiness that some forummers mentioned is there, but have gotten used to the idiosyncrasies and adapted to it. ↡ Advertisement 4 Link to post Share on other sites More sharing options...
Renault Fluence 1.5 dci
2024 Renault 5 E Tech
2016 Renault Kadjar
2016 Renault Kadjar
2024 5th Generation Renault Scenic
2024 6th Generation Renault Espace
2023 ASX Unveiled!
2023 ASX Unveiled!
Renault Kangoo
Renault Kangoo
