Deranged 2nd Gear September 20, 2014 Share September 20, 2014 Any suggestions from any bros out there? Would the generic power steering fluid that petrol kiosks sell be suitable? I saw from my car manual that it should be WSS-M2C204-A2 type. Any suggestions for similar / eqivalent? Thanks in advance! ↡ Advertisement Link to post Share on other sites More sharing options...
Trex101 3rd Gear September 20, 2014 Share September 20, 2014 Any suggestions from any bros out there? Would the generic power steering fluid that petrol kiosks sell be suitable? I saw from my car manual that it should be WSS-M2C204-A2 type. Any suggestions for similar / eqivalent? Thanks in advance! Any fully syn atf will do, i'm using Mobil 1 syn atf for my Ford. Link to post Share on other sites More sharing options...
Deranged 2nd Gear September 20, 2014 Author Share September 20, 2014 Any fully syn atf will do, i'm using Mobil 1 syn atf for my Ford. Thanks vm! BTW isn't there a difference between ATF fluids & power steering fluids? I know for older cars (i.e. those from 1990s) there prob isn't an issue using ATF for both transmission & power steering but for newer models? Link to post Share on other sites More sharing options...
Trex101 3rd Gear September 21, 2014 Share September 21, 2014 Thanks vm! BTW isn't there a difference between ATF fluids & power steering fluids? I know for older cars (i.e. those from 1990s) there prob isn't an issue using ATF for both transmission & power steering but for newer models? Depends on car model, not all can use ATF as PSF, check your owner manual as it will state if your power steering can use ATF or not. In fact, PSF are simple hydraulic fluid while ATF even though are hydraulic fluid but have loads of anti-foam and anti-wear additives added in. So if your power steering can use ATF, then using Syn ATF would be more beneficial to the system. ↡ Advertisement Link to post Share on other sites More sharing options...
Ford invents retractable exhausts
2022 Tesla Cybertruck and the Ford Executive Challenge
Let's talk about American pickup trucks.
Steering leather wrapping
Comparing Opel Astra 1.6 Twinport and Ford Focus 1.6 H/B
Porsche’s First Steer-By-Wire System Is Designed For Less Feedback, Not More
