badlammy 6th Gear September 1, 2021 Share September 1, 2021 So for Ceramic pads, are there any particular feedback on the various brands, or are they more of less the same? ↡ Advertisement Link to post Share on other sites More sharing options...
Confusedboi Supercharged September 4, 2021 Share September 4, 2021 On 9/1/2021 at 10:22 AM, badlammy said: So for Ceramic pads, are there any particular feedback on the various brands, or are they more of less the same? no idea because never use before, what I read online, generally they confirm will last longer than other types of pads and have better braking performance. And ceramic pads are more expensive for sure. https://www.bridgestone.com.sg/en/tyre-clinic/drivers-essential/ceramic-vs-metallic-brake-pads Link to post Share on other sites More sharing options...
Mkl22 Supersonic September 4, 2021 Share September 4, 2021 On 8/30/2021 at 2:10 PM, kobayashiGT said: Coated with a layer of brake dust is considered as protection. hahaha. Okay one! Brake dust stain the rims. Cannot remove in some cases. Only to respray Link to post Share on other sites More sharing options...
Mkl22 Supersonic September 4, 2021 Share September 4, 2021 (edited) On 9/1/2021 at 10:22 AM, badlammy said: So for Ceramic pads, are there any particular feedback on the various brands, or are they more of less the same? Typically ceramic pads have less bite. But they are almost dust free. I would think they need some heat in them too. In order to bite well. Maybe not an issue in SG, since we don’t have cold weather Edited September 4, 2021 by Mkl22 1 1 Link to post Share on other sites More sharing options...
Terratoss 1st Gear April 15, 2022 Share April 15, 2022 On 11/7/2016 at 11:30 PM, Apple-Tree said: My Kia Carens only use original pad once, the original pair. Stop using as it cause my rotor to wrap lor, send for skimming. After that, has been using Hi-Q soft pad, quite lasting 50~60kkm or 2 years. Cheap $25 Now Hi-Q no stock for Carens, I turned to another brand SB Nagamochi "Green Coloured Pad" $30 FR Ownself change for MAXIMUM Cost Saving and Performance. Have been like that since I drove my first car except when 1 time, the disc pad drop off. Need immediate attention at workshop. I drove there with 3 disc brake left. hi boss, happen to see yr previous post on sb nagamochi. how's the pad working for u? Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear April 16, 2022 Share April 16, 2022 20 hours ago, Terratoss said: hi boss, happen to see yr previous post on sb nagamochi. how's the pad working for u? Yes boss, It is a soft pad ...... so it is very dusty (Brake Dust). Now using NiBK, low dust pad ........Good. Link to post Share on other sites More sharing options...
Terratoss 1st Gear April 17, 2022 Share April 17, 2022 17 hours ago, Apple-Tree said: Yes boss, It is a soft pad ...... so it is very dusty (Brake Dust). Now using NiBK, low dust pad ........Good. Actually im contemplating on Hi-Q & sb nagamochi(price very gd but not much review). when u say soft I assume it has good stopping power as such pads usually produce more brake dust. How's yr NiBK compared to SB nagamochi? Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear April 18, 2022 Share April 18, 2022 On 4/17/2022 at 2:07 PM, Terratoss said: Actually im contemplating on Hi-Q & sb nagamochi(price very gd but not much review). when u say soft I assume it has good stopping power as such pads usually produce more brake dust. How's yr NiBK compared to SB nagamochi? Hmmmm ....... more brake mean wear faster baa.... Performance for these brand OK one. Use NiBK because it is cheaper, much less dust and last longer. I have a few sets of FR RR ..... ea. cost 10++ only at Fitipart during COVID lor... Link to post Share on other sites More sharing options...
AKLT Neutral Newbie May 13, 2022 Share May 13, 2022 come to brakes its better to go big (safe). Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator May 27, 2022 Share May 27, 2022 14 hours ago, katerinajuliat said: Best Brake Pads For 2022 I also never use cheap brake and dun really trust these product to stop my car. Akebono Ultra-Premium Ceramic Brake Pads. Around 70$ Power Stop Z23 Evolution Sport Carbon Fiber-Infused Brake Pads. Around 40$ StopTech Sport Brake Pads. Around 177$ TRW Automotive Premium Brake Pad. Around 98$ If you want how to install and know other information. then visit this website. Click on this link: https://infomativebeats.com/ cool stuff Link to post Share on other sites More sharing options...
Sukoo Neutral Newbie May 31, 2022 Share May 31, 2022 @katerinajuliat where did you get your brake pad? Link to post Share on other sites More sharing options...
Gnahp Turbocharged July 3 Share July 3 time to pick up the spanners this car has pad wear sensor for front and rear brake but the message didn't tell me which one 😵💫 can't tell visually too as both front and rear pads wear until the same thickness (thinness?) got to tikam and use a multimeter to check the pad wear sensor to confirm, I tikam rear brake 1 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic July 3 Share July 3 Change to originals ah? I cannot tahan Mercedes original dusty pads. Just 1-2days can see the dust liao. 2 Link to post Share on other sites More sharing options...
Gnahp Turbocharged July 3 Share July 3 wanted to ask you guys for opinion this is the brake wear sensor it has two wires, a two-prong connector this is how it worn on my previous W204, triggered the brake wear message do you guys think:- 1. the two wire is a loop, the wear breaks the wire, causing open circuit, triggering the brake wear message 2. the two wire both connected to +12V, the wear grind away the plastic insulation on the tip, allowing the probe to touch the brake rotor (GND/ground) to form a close circuit, triggering the brake wear message looking at the way it worn on my old W204, I am more incline to No.2 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged July 3 Share July 3 On 7/3/2024 at 11:16 PM, Mkl22 said: Change to originals ah? I cannot tahan Mercedes original dusty pads. Just 1-2days can see the dust liao. yes, will use the super dusty original pads while I had good experience with ATE ceramic pads, much less dust, but the braking power also not as jiak as the original my wife is a fast driver, better give her some jiak brakes Link to post Share on other sites More sharing options...
Beregond Supersonic July 3 Share July 3 On 7/3/2024 at 11:16 PM, Mkl22 said: Change to originals ah? I cannot tahan Mercedes original dusty pads. Just 1-2days can see the dust liao. use original, i rather have some dust, rather then screeching sound😅 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic July 3 Share July 3 (edited) On 7/4/2024 at 12:07 AM, Beregond said: use original, i rather have some dust, rather then screeching sound😅 I just switched to endless ssm plus for my cheapo jap. Much better than stock but yet very little dust. Super happy. Silent as a door mouse. Zero sound Edited July 3 by Mkl22 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic July 4 Share July 4 On 7/3/2024 at 11:30 PM, Gnahp said: yes, will use the super dusty original pads while I had good experience with ATE ceramic pads, much less dust, but the braking power also not as jiak as the original my wife is a fast driver, better give her some jiak brakes Maybe you try Brembo brake pad🤭 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Toyota Sienta 2016
Toyota Sienta 2016
Petrol Discounts in Singapore
[Official] 2024 Lexus LBX
Toyota Land Cruiser Mini
2022 Toyota bZ4X
2022 Toyota bZ4X
Toyota Corolla Cross
