Gnomish 2nd Gear June 7, 2018 Share June 7, 2018 Your battery is getting weak, time to change liao. I also kenna this around 2 years old. Did my change aftermarket instead of agent, save about $200. One advice from the aftermarket is that don't drive until restart also keep blinking then will be messy, need computer to reset. change istop battery at AD workshop is abt $300.. means do outside only $100? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Law_wish Clutched June 7, 2018 Share June 7, 2018 Your battery is getting weak, time to change liao. I also kenna this around 2 years old. Did my change aftermarket instead of agent, save about $200. One advice from the aftermarket is that don't drive until restart also keep blinking then will be messy, need computer to reset. Thanks for the info bro. I suspect the battery too. Again, cost around $300 at agent. Saw at carousell is around $160, Q85 model. Wondering if it is the same model we are using now. And the problem is I don't use i stop often. Link to post Share on other sites More sharing options...
Kawasaki June 8, 2018 Share June 8, 2018 change istop battery at AD workshop is abt $300.. means do outside only $100? You are lucky, i was quoted $360 by AD. Did my for $170 aftermarket. Link to post Share on other sites More sharing options...
Shonshu 1st Gear July 20, 2018 Share July 20, 2018 Dear bros of M5, Hi all, may I check for engine oil, do you stick back to Mazda oil when you service with outside workshop? I have finished my 3 years of free maintenance with TE. And I am planning to go outside workshop for my next servicing(which is pretty soon). I have not changed the spark plugs and auto gear box oil since day 1. Any advice? THank you all! cheers Link to post Share on other sites More sharing options...
Cwinedine 1st Gear July 20, 2018 Share July 20, 2018 Dear bros of M5, Hi all, may I check for engine oil, do you stick back to Mazda oil when you service with outside workshop? I have finished my 3 years of free maintenance with TE. And I am planning to go outside workshop for my next servicing(which is pretty soon). I have not changed the spark plugs and auto gear box oil since day 1. Any advice? THank you all! cheers Mazda recommends using 0W20 oil so as long as you stick to this viscosity, it should be fine. Please change out your other fluids if TE has not replaced them (Brake, Coolant) besides the auto gear oil. I replace my sparkplugs between 30-40k km interval. The rest should be normal servicing. What's your mileage now? Link to post Share on other sites More sharing options...
Shonshu 1st Gear July 20, 2018 Share July 20, 2018 Mazda recommends using 0W20 oil so as long as you stick to this viscosity, it should be fine. Please change out your other fluids if TE has not replaced them (Brake, Coolant) besides the auto gear oil. I replace my sparkplugs between 30-40k km interval. The rest should be normal servicing. What's your mileage now? Hi Cwinedine, Thank you for your information. My mileage is at 58000KM and have completed 6 servicing with TE. Is there any other things that I should look out for? Thank you again! cheers Link to post Share on other sites More sharing options...
Cwinedine 1st Gear July 20, 2018 Share July 20, 2018 Hi Cwinedine, Thank you for your information. My mileage is at 58000KM and have completed 6 servicing with TE. Is there any other things that I should look out for? Thank you again! cheers My pleasure, at this mileage, you should also check your rotors & pads, the front ones should be pretty worn if you have not replaced them before and if there's any funny sound, do check the shock absorbers for leakage and also end-links. You should be fine with the rest. With free servicing, I've little or low expectation from TE. Link to post Share on other sites More sharing options...
Shonshu 1st Gear July 20, 2018 Share July 20, 2018 My pleasure, at this mileage, you should also check your rotors & pads, the front ones should be pretty worn if you have not replaced them before and if there's any funny sound, do check the shock absorbers for leakage and also end-links. You should be fine with the rest. With free servicing, I've little or low expectation from TE. Got it! This coming servicing is gonna be a little pricey with the changes.... Hahaha Thank you so much again!!! Link to post Share on other sites More sharing options...
Cwinedine 1st Gear July 20, 2018 Share July 20, 2018 Got it! This coming servicing is gonna be a little pricey with the changes.... Hahaha Thank you so much again!!! My pleasure...It will still be cheaper outside so no worries, my only regret was not getting the car earlier to enjoy it 1 Link to post Share on other sites More sharing options...
Shonshu 1st Gear July 21, 2018 Share July 21, 2018 My pleasure...It will still be cheaper outside so no worries, my only regret was not getting the car earlier to enjoy it I fully agree! It was an awesome feeling when I have 4 adults and 2 toddlers( 2 car seats) with 8 bags and a pram altogether driving the M5 to JB. Everyone was pretty comfortable. Haha... The drive was decent and powerful too... Cheers!!! 1 Link to post Share on other sites More sharing options...
Shonshu 1st Gear July 26, 2018 Share July 26, 2018 Dear bros, I have just finished my servicing at Monster Garage. I changed engine oil( Mazda oil) and also the ATF.Left as a happy customer.... Will be back there for my next servicing... 1 Link to post Share on other sites More sharing options...
Erictl76 1st Gear July 26, 2018 Share July 26, 2018 Dear bros, I have just finished my servicing at Monster Garage. I changed engine oil( Mazda oil) and also the ATF.Left as a happy customer.... Will be back there for my next servicing... Did they check your brake pad & rotor? Any bro here changed their brake pad? to the original brake pad? 1 Link to post Share on other sites More sharing options...
Shonshu 1st Gear July 26, 2018 Share July 26, 2018 They checked the brake pads and no need to change yet. Link to post Share on other sites More sharing options...
Cwinedine 1st Gear July 27, 2018 Share July 27, 2018 Dear bros, I have just finished my servicing at Monster Garage. I changed engine oil( Mazda oil) and also the ATF.Left as a happy customer.... Will be back there for my next servicing... what's the damage like so that we can take reference Link to post Share on other sites More sharing options...
Shonshu 1st Gear July 27, 2018 Share July 27, 2018 Total $330. $150 for mazda engine oil package + $180 for mazda ATF. I wanted to change the spark plugs too but no stock. Haha... Link to post Share on other sites More sharing options...
Erictl76 1st Gear July 27, 2018 Share July 27, 2018 (edited) Total $330. $150 for mazda engine oil package + $180 for mazda ATF. I wanted to change the spark plugs too but no stock. Haha... Need to check how much will these services cost with TE..... Any bro knows? Edited July 27, 2018 by Erictl76 1 Link to post Share on other sites More sharing options...
Cwinedine 1st Gear July 28, 2018 Share July 28, 2018 Total $330. $150 for mazda engine oil package + $180 for mazda ATF. I wanted to change the spark plugs too but no stock. Haha... Prices are reasonable workshop prices if they're using all Genuine Parts. Engine oil OW20 is about $60/bot of 4L (Idemitsu) but workshop prices will be about 20-40% more I have no idea if there's any original mazda engine oil in Singapore as i've yet to see one. Engine oil Filter about $20 Labour to change Engine oil & filter is between $30-50 Mazda ATF is about $100-130/4L (Skyactiv) There's 2 variant MV (normal) & FZ (skyactiv) so please use the correct one. Thanks for sharing 1 Link to post Share on other sites More sharing options...
Shonshu 1st Gear August 3, 2018 Share August 3, 2018 Hi guys, I have been facing bad radio reception recently. I'm using the Alpine head unit that came with the car. Not too sure what is wrong? Any advice? Thank you ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mazda 6e
2025 Mazda 6e
2014 Honda Odyssey
2014 Honda Odyssey
[Official] 2025 Hyundai Ioniq 9
Kia PV5 - An Exceptional MPV
2026 Mazda EZ-60 / CX-6e
Xpeng X9
Xpeng X9
Mazda FC3S RX-7
Mazda FC3S RX-7
MAZDA 6
MAZDA 6
