The_chanster Clutched May 31, 2014 Share May 31, 2014 Can one of you kind souls help me on this? Despite reading the Wikipedia page numerous times I still cannot derive or understand the check digit calculation of my vehicle. Using the example quoted in Wiki, how do they derive the "6 fixed numbers as (9, 4, 5, 4, 3, 2)"? and why are the 19 characters used quoted in this order?? (A, Z, Y, X, U, T, S, R, P, M, L, K, J, H, G, E, D, C, B) where A=0, Z=1, etc... Can anyone make this Wiki page a lot clearer to understand for a layman? Cheers http://en.wikipedia.org/wiki/Vehicle_registration_plates_of_Singapore#Checksum ↡ Advertisement 1 Link to post Share on other sites More sharing options...
F355 Turbocharged May 31, 2014 Share May 31, 2014 (edited) OMV ARF PARF PQP Tiered ARF CEV rebates all already so difficult to understand I don't even bother about the checksum. Edited May 31, 2014 by F355 Link to post Share on other sites More sharing options...
lausai88 Hypersonic May 31, 2014 Share May 31, 2014 use the example: SBA 1234 1) ignore the letter "S" 2) B = 2, A = 1 and 3) SBA 1234 convert to 21 1234 4) Each individual number is then multiplied by 6 fixed numbers( 9, 4, 5, 4, 3, 2). 5) use convert to 21 1234 and based on the position of the number, 2 x 9, 1 x 4, 1 x 5, 2 x 4, 3 x 3, 4 x 2 6) add the numbers, 18 + 4 + 5 + 8 + 9 + 8 = 52 7) 52 divide by 19 = 2 with remainder 14 8) match with these 19 letter, A=0, Z=1, Y=2, X=3, U=4, T=5, S=6, R=7, P=8, M=9, L=10, K=11, J=12, H=13, G=14, E, D, C, B 9) remainder 14 equal to letter G 10) so SBA 1234G 10 Link to post Share on other sites More sharing options...
Steptronic Supercharged May 31, 2014 Share May 31, 2014 Why to complicate so much leh? use the applications available in Android and Apple phones Link to post Share on other sites More sharing options...
The_chanster Clutched May 31, 2014 Author Share May 31, 2014 On 5/31/2014 at 1:56 PM, lausai88 said: 4) Each individual number is then multiplied by 6 fixed numbers( 9, 4, 5, 4, 3, 2). This is the bit which I don't understand. Are these numbers constants? i.e. are they used every time regardless of number plate combination? In other words, if my number plate was SKA 1234, would I multiply (11x9, 1x4, 1x5, 2x4, 3x3, 4x2) Summing up, 99+4+5+8+9+8 = 133 133 divided by 19 = 7 No remainder, so checksum is 0, (zero) = A Correct logic? Link to post Share on other sites More sharing options...
The_chanster Clutched May 31, 2014 Author Share May 31, 2014 I've done a quick check on the above and your method works. Thanks lausia88. 5 points from me for your help. 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic May 31, 2014 Share May 31, 2014 Calculator attached Car Registration Calculation.xlsFetching info... 1 Link to post Share on other sites More sharing options...
Evillusion Supersonic June 1, 2014 Share June 1, 2014 On 5/31/2014 at 1:56 PM, lausai88 said: use the example: SBA 1234 1) ignore the letter "S" 2) B = 2, A = 1 and 3) SBA 1234 convert to 21 1234 4) Each individual number is then multiplied by 6 fixed numbers( 9, 4, 5, 4, 3, 2). 5) use convert to 21 1234 and based on the position of the number, 2 x 9, 1 x 4, 1 x 5, 2 x 4, 3 x 3, 4 x 2 6) add the numbers, 18 + 4 + 5 + 8 + 9 + 8 = 52 7) 52 divide by 19 = 2 with remainder 14 8) match with these 19 letter, A=0, Z=1, Y=2, X=3, U=4, T=5, S=6, R=7, P=8, M=9, L=10, K=11, J=12, H=13, G=14, E, D, C, B 9) remainder 14 equal to letter G 10) so SBA 1234G kns....i read then i feel like i want to lausai.....hahahah Link to post Share on other sites More sharing options...
TVT Supercharged June 2, 2014 Share June 2, 2014 This is very interesting..... But what purpose is this last letter in the regn plate for? What kinda of checks does it have for the authorities ? Link to post Share on other sites More sharing options...
Alpha78 6th Gear June 2, 2014 Share June 2, 2014 On 6/2/2014 at 4:09 AM, TVT said: This is very interesting..... But what purpose is this last letter in the regn plate for? What kinda of checks does it have for the authorities ? So that when they summon you, if the checksum doesn't tally with the number plate, you can claim that the TP pak jiao copy the wrong number. Link to post Share on other sites More sharing options...
Kb27 Supersonic June 2, 2014 Share June 2, 2014 On 6/2/2014 at 4:09 AM, TVT said: This is very interesting..... But what purpose is this last letter in the regn plate for? What kinda of checks does it have for the authorities ? It's a checksum, a sort of confirmation. Example, if a car ran a red light and the photo is not clear or licence plate is missing a digit, you can fill in the blank conclusively like belonging to this red car, model X. Link to post Share on other sites More sharing options...
Mockngbrd Supersonic June 2, 2014 Share June 2, 2014 wow.... finally see the formula Link to post Share on other sites More sharing options...
Crossangel Neutral Newbie June 2, 2014 Share June 2, 2014 On 5/31/2014 at 1:56 PM, lausai88 said: use the example: SBA 1234 1) ignore the letter "S" 2) B = 2, A = 1 and 3) SBA 1234 convert to 21 1234 4) Each individual number is then multiplied by 6 fixed numbers( 9, 4, 5, 4, 3, 2). 5) use convert to 21 1234 and based on the position of the number, 2 x 9, 1 x 4, 1 x 5, 2 x 4, 3 x 3, 4 x 2 6) add the numbers, 18 + 4 + 5 + 8 + 9 + 8 = 52 7) 52 divide by 19 = 2 with remainder 14 8) match with these 19 letter, A=0, Z=1, Y=2, X=3, U=4, T=5, S=6, R=7, P=8, M=9, L=10, K=11, J=12, H=13, G=14, E, D, C, B 9) remainder 14 equal to letter G 10) so SBA 1234G he deserve 100 points.. ha ha Link to post Share on other sites More sharing options...
Jimmylim 4th Gear June 2, 2014 Share June 2, 2014 good for doing project which may need such info, just like the letter in our NRIC. Link to post Share on other sites More sharing options...
Chowyunfatt Turbocharged June 2, 2014 Share June 2, 2014 On 5/31/2014 at 1:56 PM, lausai88 said: use the example: SBA 1234 1) ignore the letter "S" 2) B = 2, A = 1 and 3) SBA 1234 convert to 21 1234 4) Each individual number is then multiplied by 6 fixed numbers( 9, 4, 5, 4, 3, 2). 5) use convert to 21 1234 and based on the position of the number, 2 x 9, 1 x 4, 1 x 5, 2 x 4, 3 x 3, 4 x 2 6) add the numbers, 18 + 4 + 5 + 8 + 9 + 8 = 52 7) 52 divide by 19 = 2 with remainder 14 8) match with these 19 letter, A=0, Z=1, Y=2, X=3, U=4, T=5, S=6, R=7, P=8, M=9, L=10, K=11, J=12, H=13, G=14, E, D, C, B 9) remainder 14 equal to letter G 10) so SBA 1234G So Terror ... 👏 Link to post Share on other sites More sharing options...
Benarsenal Turbocharged June 2, 2014 Share June 2, 2014 On 5/31/2014 at 1:56 PM, lausai88 said: use the example: SBA 1234 1) ignore the letter "S" 2) B = 2, A = 1 and 3) SBA 1234 convert to 21 1234 4) Each individual number is then multiplied by 6 fixed numbers( 9, 4, 5, 4, 3, 2). 5) use convert to 21 1234 and based on the position of the number, 2 x 9, 1 x 4, 1 x 5, 2 x 4, 3 x 3, 4 x 2 6) add the numbers, 18 + 4 + 5 + 8 + 9 + 8 = 52 7) 52 divide by 19 = 2 with remainder 14 8) match with these 19 letter, A=0, Z=1, Y=2, X=3, U=4, T=5, S=6, R=7, P=8, M=9, L=10, K=11, J=12, H=13, G=14, E, D, C, B 9) remainder 14 equal to letter G 10) so SBA 1234G How come you know the formula ah? Never see LTA publish anywhere before leh... Link to post Share on other sites More sharing options...
Ekiden Clutched June 3, 2014 Share June 3, 2014 On 5/31/2014 at 4:10 PM, Kb27 said: Calculator attached I guess the calculator only calculate S plate only right? how about E plates? Link to post Share on other sites More sharing options...
Kb27 Supersonic June 3, 2014 Share June 3, 2014 On 6/3/2014 at 4:23 AM, Ekiden said: I guess the calculator only calculate S plate only right? how about E plates? Calculator seems to work for E plates, but the first letter you must input S, then followed by E x xxxx ↡ Advertisement Link to post Share on other sites More sharing options...
Anyone missing a car plate?
Get a new car plate number for used car
Class 4 Driving License
Clear your plates or kena orh gong ah
DPM Lawrence Wong rides a Royal Enfield Classic for charity ride
