Steering vibration at 80kmh
LauYaChia
After replacement of 4 pieces of aft mkt brake hoses, drove out of workshop and found my braking problems solved...but steering wheel start to vibrate slightly uopn reaching 80kmh at expressway.
Went bk to same w.shop. Checked and infd due to "wear off centric hub ring" as its only 2mm in thickness, plastic ring will wear off over time.
Custom make 4 pieces of alluminium Hub ring which fittted perfectly in centre bore and hv wheel balance done on both front tyres.
Now the steering vibration at 80kmh still persist! Tyres still in gd condition.
What could hv went wrong? Need help...trillion thx in advance!!!
i had this problem after some repair but i don't remember what the mechanic did to rectify it. He knew what the problem was and fixed it. I am sorry i can't help much here but at least i am sharing with you that your problem is not unique and it can be fixed.
  On 5/29/2014 at 1:06 PM, LauYaChia said:
Thks for the inputs:)
Tmr morn will drive to workshop and let them inspect again.
maybe front tyre needs balancing
Is it the wear & tear of the what ring that caused the tires to have uneven wear? The hub ring wear caused the tires to have too much movement causing uneven wear. Naked eye cannot see. Trust me.
I had simillar experience just last Saturday. Driving up to KL thru Tuas checkpoint and everyhing was smooth, stop at Gelang Patah R&R for quick breakfirst. After driving about 5km I felt my steering wheel vibrated but kept driving at 90-100km/h. Stop at one of the petrol kios before Simpang Renggam checked my tyre pressure and slightly reduced the pressure. Visually checked my 4 tyres seem ok.Continue driving and this time the vibration bacame worst, which can only drive below 80km/h. Two weeks before went for tyre rotation the guy told me my tyre still in good condition. Found a tyre workshop in Simpang Renggam and they found out that one of my tyre bulging and the rim warp...
Hi guys,
Happen to see this steering wheel vibration. I had this issue recently and until today I still cannot figure the cause.
It started when I changed the brake pad. After changed, the steering wheel vibrate when car go above 90 km/hr. Sent back to agent 2 times and only the second time, the agent thought they had solve the problem by changing new caliber of the brake on the other paasenger side of the car. However, 2 days later i found the back tyre punctured and sent to stamford to patch up. Until today I could had the slightest thought that the vibration could had cause by tyre punctured earlier and not the caliper or balancing. I just feel that experience of the mechanic is important in the after sales market as honestly there are not many nowadays....
  On 9/11/2014 at 3:05 PM, Storm88 said:
Hi guys,
Need to do high speed balancing. There are a few workshop that does that....vibration only be felt at high speed....
Hi guys,
When steering wheel sudenly start to wobble/vibrate (if u have not been to WS to have anything done) 1st thing is to do balancing of yr wheels.
Did u hit some pot-holes recently? That cud also cause it. Have it checked at WS.
Badly balanced wheels cud cause it. Also aftermarket Sports Rims where the center hole is too large for the hub ....U need to put the plastic adapter to make a tight fit so wheel is perfectly center on the hub.
Plastic ring only costs abt $5 each. I put one on each wheel, front n back last time. No need to waste money on aluminium rings. The plastic ring is cheap n good enough n can last many many years.
If u just had some work done then vibration start, No matter what the mech tell u..... I say it was caused by him.
Either change WS or get them to rectify the vibration. Usually lousy mech wil blame everybodys father n mother for the problem n never admit he is a lousy mech. [nod]
Oh and another reason why the steering suddenly start to wobble is those small lead balancing weight came off. [:/]
Always balance all 4 wheels regularly, not just the front 2 wheels.
I do mine every 10K km n rotate the wheels at the same time. U protect all the steering n suspension components n tires too. They wil last much longer without having problems.
For your tire bulging n rim warp might b caused by hitting a pot hole or kerb.
Edited by Pisces69
Hi guys,
U wanna try loosen ur wheel a lil n retighten by gradually tighten bolts in oppo direction order.? Or brake pad is orig part?
Agree, esp centre plastic ring.
