Sash1401 4th Gear May 24, 2014 Share May 24, 2014 Fellow bro, Would like to find out if any avante driver experiencing quite strong vibrations during when the car is idling. I've changed the engine mounting few months back n it seemed the improvement is not much. I've heard about ignition coils misfiring n tat might cause the vibration. Any bro who encountered this prob b4? Any tell tale signs and recommended ws to solve dis prob? Care to share abt the damage? Thanks in advance ↡ Advertisement Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged May 24, 2014 Share May 24, 2014 You changed only 1 engine mount or all engine mounts? Fellow bro,Would like to find out if any avante driver experiencing quite strong vibrations during when the car is idling. I've changed the engine mounting few months back n it seemed the improvement is not much.I've heard about ignition coils misfiring n tat might cause the vibration. Any bro who encountered this prob b4? Any tell tale signs and recommended ws to solve dis prob? Care to share abt the damage? Thanks in advance Link to post Share on other sites More sharing options...
Sash1401 4th Gear May 25, 2014 Author Share May 25, 2014 I've changed all of them You changed only 1 engine mount or all engine mounts? Link to post Share on other sites More sharing options...
ER-3682 Supersonic May 25, 2014 Share May 25, 2014 Check the idiling control valve & the Thorttle body.. Link to post Share on other sites More sharing options...
Heartbreakid 6th Gear May 25, 2014 Share May 25, 2014 If it is ignition coils, the engine will be weak. Most probably is the throttle idling valve. Check during idling speed with air cond on/ off too see if the rpm maintains as it was with air cond off or it drops further and caused the vibration to increase. Link to post Share on other sites More sharing options...
Kchew21 1st Gear May 25, 2014 Share May 25, 2014 Check your spark plugs too Link to post Share on other sites More sharing options...
Watwheels Supersonic May 25, 2014 Share May 25, 2014 Your so called vibration is very vague. Ppl varies in their tolerance in "vibration". Between 1-10 how strong is the "vibration"? Where is it felt the most? Is there any abnormal sound? Anything of the unusual. The one word "vibration" doesn't say a lot if you haven't notice. Ignition coil got issue dan you will most likely see the engine stall easily at idling engine speeds. Did you experience that? Link to post Share on other sites More sharing options...
Sash1401 4th Gear May 25, 2014 Author Share May 25, 2014 Is there any way I can check on my own or do I have to bring it to a workshop? If yes any recommendation? Thanks in advance Check the idiling control valve & the Thorttle body.. The strength is Ard a 3 to 5 ba. The vibration varies. Mostly felt at my driver seat. The engine dun seemed going to stall but at times can feel it's a bit weak. Hope dis helps. Thanks Your so called vibration is very vague. Ppl varies in their tolerance in "vibration". Between 1-10 how strong is the "vibration"? Where is it felt the most? Is there any abnormal sound? Anything of the unusual. The one word "vibration" doesn't say a lot if you haven't notice. Ignition coil got issue dan you will most likely see the engine stall easily at idling engine speeds. Did you experience that? Link to post Share on other sites More sharing options...
ER-3682 Supersonic May 25, 2014 Share May 25, 2014 T/B can clean yourself if you know a bit of mechanic's skill....Remove the air intake,spray "Carburretor cleaner",use a clean cloth & wipe the T/B... Link to post Share on other sites More sharing options...
Ahgong Supercharged May 26, 2014 Share May 26, 2014 Is there any way I can check on my own or do I have to bring it to a workshop? If yes any recommendation? Thanks in advance The strength is Ard a 3 to 5 ba. The vibration varies. Mostly felt at my driver seat. The engine dun seemed going to stall but at times can feel it's a bit weak. Hope dis helps. Thanks check your spark plugs. one of them could be dead, causing the combustion to stall when the revolution reaches that plug. i had this same problem when i collected my ride. got the dealer to replace the plugs and everything is working fine and dandy since. 1 Link to post Share on other sites More sharing options...
Rajoana 1st Gear June 12, 2014 Share June 12, 2014 my take is could be the cam or crank sensor. was told this is a common thing for avante n forte above 5 yrs of age....n similar symptoms. need more cranking during cold start. idling not stable moving off no power higher FC Link to post Share on other sites More sharing options...
13177 Hypersonic June 13, 2014 Share June 13, 2014 my take is could be the cam or crank sensor. was told this is a common thing for avante n forte above 5 yrs of age....n similar symptoms. need more cranking during cold start. idling not stable moving off no power higher FC You mean Korean cars sure to have such problems after 5 years? Looks like Korean cars only good for first 5 years? Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 13, 2014 Share June 13, 2014 The vibration varies. Mostly felt at my driver seat. Cool car. Thats the kind of car women love. If you sell it try to a find a lady owner, especially single ones and make sure she goes for a test drive. If she is happy after the test drive, she will give you a better price. 1 Link to post Share on other sites More sharing options...
Rajoana 1st Gear June 14, 2014 Share June 14, 2014 You mean Korean cars sure to have such problems after 5 years? Looks like Korean cars only good for first 5 years? Err...not everyone will experience this. I wouldn't just condemned anycar because of such minor issues. All models n makes do have some common problems of their own. Its only about u knowing them or not n how much they bother u. ↡ Advertisement Link to post Share on other sites More sharing options...
New Hyundai Ioniq 5 N now available for purchase in Singapore
2011 Hyundai Elantra
