Need advice on pulling back
Donut
Supercharged
Yo,
Today I got a problem with the ride
Ride is honda. 7 yrs old. CVTF gear. 100km mileage. Last servicing was in Dec 2013. New Iridium sparks changed. Usual EO used. New air filter changed.
First, I feel that car doesn't accelerate as much as normal. Hit 80km/h or so, the car doesn't feel the power to go higher speed. Something holding back the car.
Then when I had to stop the car and wait for someone, I put gear to N and pull hand brake. After 1 min, the engine died! It just died..... I can restart the engine without problem.
The idling is not stable, and I feel the engine is weak.
I suspect its ignition coil? I thought it might be the fuel filter, but I change it 30k km before. And I don't pump MY petrol.
Any advice?
The symptoms for coils are jerkiness, rough idling, like coughing. Your car's symptoms points more like what you suspects - fuel filter, or maybe Air Mass Sensor.
Yes, it could be one of the 4 coils that is faulty. Hence in one of the cylinders the spark plug is not firing properly or not firing at all. That might be of the reasons for the loss of power and engine dieding LoL...stalling.
Other possibility is the throttle body that requires cleaning. Or a faulty O2 sensor. If you have a OBD scanner you could see if the sensors are working or detect any fault.
Edited by Watwheels
Supercharged
  On 5/22/2014 at 12:44 AM, Earthboy said:
ddi you check your battery?
batt just changed new Amaron one month ago.
Moderator
tht this another of those threads again, since you mentioned 'pulling back' and that you jus become father, so thot u had enuf [laugh]
TS, get it checked ASAP. It happened to one of my cars.
Engine died a few times when idling at traffic lights but able to restart.
Delayed sending to workshop and almost crashed while driving when engine died suddenly when making a turn - steering locked and brakes failed !!
Supercharged
when comes to that, i NEVER HOLD BACK............... [laugh][laugh]
Thanks.
thats why i not driving today and likely tml..... BMW today.. will send the car to ws on Sat.
BTW, any trusted ws to recommend?? the one i always go is a v simple ws for simple jobs, the one at Caltex upper thomson road. Not sure if they are capable of diagnosing my problem.
Thanks.
I sent mine to AD. Simple job - had some kind of electronic sensor replaced.
Was upset with AD because car was serviced there just 2 weeks prior to incident, but they claimed that this can't be detected. Was a bloody scary experience......luckily didn't crash into other cars or pedestrian!
Unable to recommend workshop. Good Luck with the diagnostic and repair!
Turbocharged
  On 5/22/2014 at 9:38 AM, Mr_b20 said:
go wash throttle body. about $30+/-
This kind of statement can be easily misconstrued in this forum.
Supercharged
lol. KNN..... u r damm right
Moderator
muahahahah....salient point to note...kekeke
first....
steering wheel will not lock, it just got heavier.
second,
brake dont fail, its just need more foot power as its not vacuum assisted anymore.
unless you took out the key, then its a different thing.
  On 5/22/2014 at 10:18 AM, Hamburger said:
first....
second,
Guess you are narrating your own experience right?
since you weren't the one at the control of my car!
All I could recall was the car heading for centre divider on my right, after just one turn of the steering (intended to turn left to exit main road). Engine sudden cut off, Steering was definitely locked in one turn position.
Couldn't recall whether brake pedals were locked or just stepping on air. All I knew was that they weren't
responding and the car was still moving towards the divider!
Luckily had tapped on brake earlier to slow down b4 the turn and also for the quick recall that I had to step on ebrake!
FYI, that car has keyless start.
Edited by TameDriver
