EXO 4th Gear May 18, 2014 Share May 18, 2014 I am driving a Legacy 2.5 GT BL9. Whenever I go over hump or roads whereby my front wheels will leave the ground (momentarily) I get this "Groaking" sound from the under carriage. This sound is more pronounce when I first drive the car early in the morning (I assume when its cold, some rubber parts have not fully expanded). Any idea what could be the issue? ***No there is no frog living under my car ↡ Advertisement Link to post Share on other sites More sharing options...
Fuelsaver Supercharged May 18, 2014 Share May 18, 2014 Can be bushing? Morning stiffer then during day when driven a while feel less stiff? Link to post Share on other sites More sharing options...
Fei_de_Li May 18, 2014 Share May 18, 2014 Check your suspension mounting. It can be this problem surface Link to post Share on other sites More sharing options...
EXO 4th Gear May 19, 2014 Author Share May 19, 2014 My front lower arm bushing (the one that is bigger) recently replaced. Which bushing you referring to? Can be bushing? Morning stiffer then during day when driven a while feel less stiff? Link to post Share on other sites More sharing options...
Kb27 Supersonic May 19, 2014 Share May 19, 2014 My front lower arm bushing (the one that is bigger) recently replaced. Which bushing you referring to? I replaced my van lower arm bushing recently and need to go for wheel alignment. After the alignment, the boss took it for a test drive. And says it's making gloaking noise and due to shock absorbers. He's probably right. Link to post Share on other sites More sharing options...
Dream 5th Gear May 19, 2014 Share May 19, 2014 I also have this issue but have yet to resolve it... Could it be the sway bar endlink worn out? Search for it in the net/youtube.. Link to post Share on other sites More sharing options...
Celicar Turbocharged May 19, 2014 Share May 19, 2014 Can be bushing? Morning stiffer then during day ... I personally experience this too and in my case, yes it is related to bushing. Link to post Share on other sites More sharing options...
evidence 2nd Gear May 19, 2014 Share May 19, 2014 (edited) hello bro, i faced with the same prob w my verna... changed Steering rack bush, steering socket end and stabilizer bush (total w labour $280) hope it helps Edited May 19, 2014 by EvidenceProtocol 1 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged May 19, 2014 Share May 19, 2014 My front lower arm bushing (the one that is bigger) recently replaced. Which bushing you referring to? i suspect subframe bushing? a number of bushings in undercarriage. i went to 1st auto semb to diagnose the croaking n found was subframe & sway bar bushings after replaced steering rack. for a few mths, car driving like new; now occasionally hear this sound early morning. maybe i also need to check front lower arm - can change bushing only or must change whole arm? price smthg like double if chg arm & bush ass'y. I personally experience this too and in my case, yes it is related to bushing. looks like i mus re-visit this issue again. 1 Link to post Share on other sites More sharing options...
Darky8888 4th Gear May 19, 2014 Share May 19, 2014 i am having the same issue too on my back wheels when making turns and on uneven roads... brought it back to AD and they said it is due to the stabilizer link faulty.. have them replaced and seem the prob is resolved... but then, now my front wheels are "croaking" as well. 1 Link to post Share on other sites More sharing options...
Simpleonly 5th Gear May 19, 2014 Share May 19, 2014 Hahahah... So many cars having this groaking sound...... Like TS case mine also have morning sickness... Having the groaking sound in the morning when going down mscp or over a hump... After warm up it seem the sound is gone.... My is 8 yes old cars... It seem all this ages of cars the sound is there.. Tough to trouble shoot... change 1 part Liao another sound come.. Change another 2nd part another 3rd sound come again... :( Give up... As long no safety is comprises .. Will just bear w it.... Link to post Share on other sites More sharing options...
Sykco Neutral Newbie May 19, 2014 Share May 19, 2014 90% of the time this noise is caused by the anti-roll bar bushing. 1 Link to post Share on other sites More sharing options...
Dream 5th Gear May 19, 2014 Share May 19, 2014 Just fixed mine... replace the mounting for the suspension and one linkage duno what is call... btw the sway bar endlink is ok... in case you are wondering how much... it is $226. Now no more cloak cloak sound. 1 Link to post Share on other sites More sharing options...
Jordanplus 1st Gear May 19, 2014 Share May 19, 2014 Hahahah... So many cars having this groaking sound...... Like TS case mine also have morning sickness... Having the groaking sound in the morning when going down mscp or over a hump... After warm up it seem the sound is gone.... My is 8 yes old cars... It seem all this ages of cars the sound is there.. Tough to trouble shoot... change 1 part Liao another sound come.. Change another 2nd part another 3rd sound come again... :( Give up... As long no safety is comprises .. Will just bear w it.... My ride same as yours, during morning got groaking sound after warm up it seen gone. This groaking sound since from new till now coming 8 yrs liao in july. Link to post Share on other sites More sharing options...
EXO 4th Gear May 19, 2014 Author Share May 19, 2014 Probably not my shock absorbers, changed to a set of coil overs and the sound is still present. I replaced my van lower arm bushing recently and need to go for wheel alignment. After the alignment, the boss took it for a test drive. And says it's making gloaking noise and due to shock absorbers. He's probably right. Thanks I will look into this I also have this issue but have yet to resolve it... Could it be the sway bar endlink worn out? Search for it in the net/youtube.. Definitely helps bro, thanks will look into it. hello bro, i faced with the same prob w my verna... changed Steering rack bush, steering socket end and stabilizer bush (total w labour $280) hope it helps Link to post Share on other sites More sharing options...
TameDriver Twincharged May 19, 2014 Share May 19, 2014 My SUV had same noise when going over humps at low speed. Got both front lower links replaced and the croaking sound gone after that. Link to post Share on other sites More sharing options...
EXO 4th Gear May 19, 2014 Author Share May 19, 2014 This is something new to me, subframe bushing. Will check it out. Thanks i suspect subframe bushing? a number of bushings in undercarriage. i went to 1st auto semb to diagnose the croaking n found was subframe & sway bar bushings after replaced steering rack. for a few mths, car driving like new; now occasionally hear this sound early morning. maybe i also need to check front lower arm - can change bushing only or must change whole arm? price smthg like double if chg arm & bush ass'y. looks like i mus re-visit this issue again. Thanks thanks, will check it out. i am having the same issue too on my back wheels when making turns and on uneven roads... brought it back to AD and they said it is due to the stabilizer link faulty.. have them replaced and seem the prob is resolved... but then, now my front wheels are "croaking" as well. Yes! I'm surprised too! Din't know so many bros here encounter the same problem Hahahah... So many cars having this groaking sound......Like TS case mine also have morning sickness... Having the groaking sound in the morning when going down mscp or over a hump... After warm up it seem the sound is gone....My is 8 yes old cars... It seem all this ages of cars the sound is there.. Tough to trouble shoot... change 1 part Liao another sound come.. Change another 2nd part another 3rd sound come again... :(Give up... As long no safety is comprises .. Will just bear w it.... Wah bro you seem confident, think I will get my work shop to check on this. 90% of the time this noise is caused by the anti-roll bar bushing. Thanks! Just fixed mine... replace the mounting for the suspension and one linkage duno what is call... btw the sway bar endlink is ok... in case you are wondering how much... it is $226.Now no more cloak cloak sound. Great! Thanks My SUV had same noise when going over humps at low speed. Got both front lower links replaced and the croaking sound gone after that. Thanks for the advice, so many ppl having the same problem, Sorry guys not enough praise to go around, will come back and praise once my points get restored. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged May 19, 2014 Share May 19, 2014 This is something new to me, subframe bushing. Will check it out. Thanks Thanks thanks, will check it out. Yes! I'm surprised too! Din't know so many bros here encounter the same problem Wah bro you seem confident, think I will get my work shop to check on this. Thanks! Great! Thanks Thanks for the advice, so many ppl having the same problem, Sorry guys not enough praise to go around, will come back and praise once my points get restored. bro, u read my feedback on 1st auto semb. They nvr chg any bushing. According to mech Meng, only removed bushings, sand away rust on bushing surface n frame bore, apply grease on bore, put back bushing, retighten. But I guess gd for few mths probably since initial sounds oredi present. I'll need to go back again. Btw, if steer at an angle have a tok sound, what might be issue? Lower arm, shock mount, bump stop? http://www.sgcarmart.com/directory/merchant_reviews.php?MID=14292 ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant level going down
2015 Forester 2.0
2015 Forester 2.0
Advice on exhaust.
Advice on exhaust.
New Subaru XV
New Subaru XV
Going to Batam. Where to park overnight ?
