Power Windows Not Working
Anjoy
Hi,
My power window is not functioning as it should. Have changed the switch and checked but the problem returns.
Please advise where/who can get it fixed.
Ride: NC
Thanks in advance.
Edited by Anjoy
check the power window motor, either brand is Bosch or french brand , can't remb exact name,
I know tis guy in Eunos who can fix it, he is specialist in all car cushion / electric power-window and chair repair )
Can call him, Mr. Foo 90294774, ( Coy name : In Siang Huat )
Thanks! Will contact Mr. Foo.
My driver's side power window has a funny sound while winding down. Winding up is fine.
Anyone knows what's the issue?
Thanks
Hi,
Ride: NC
Thanks in advance.
NC ... MX5?
Bring it back to TransEurokars Mazda AD lah!
Thanks
Many stickers on your window?
NC ... MX5?
It's a PI model.
Not sure why too. Mark can't pinpoint the problem too.
Did you just changed battery or ECU reset?
Yes. Prior to that the window is fine. Any connection between the two?
So what's your advice?
Supercharged
You mean after 3 months plus you haven't got it fixed yet ??
Hahaha. Yes! [sweatdrop]
No one knows what's wrong with it.
Supercharged
Have you checked the motor?
Or something inside is jamming it ?
Power window have only a few parts. Switch, cable, motor, level mechanism.....tot it should be easy to pinpoint the cause.
After battery change or ECU reset, the power window module needs reprogramming.
After starting the car, wind down the window by holding the down button + 1-2 sec after the action is complete. Do the same for winding up. The auto up/down will be activated again.
If all four windows have auto up/down, then repeat for every door.
I just changed mine last month. It failed me at JB custom, when wanna chop passport! Darn wrong timing.. $130 for motor, $115 for regulator, $65 for labor. I guess it's a common wear N tear, esp driver side. Try spraying some WD40 at the fringe on glass window and and those rubber, it will reduce the suction effect when u wanna use esp after parked long hours in hot sun.
Supercharged
You are opposite of me! Mine is can't wind up after I power it down one late night last year. So I had to park overnight @ MSCP and drove to WS the next day, all with the driver side window down...... Luckily it didn't rain that day or else.... [sweatdrop]
Mine is a miata so the windows (2 doors only so 2 windows) will normally drop a little as I retract the roof but as one side of the window isn't working down, so I dare not retract the roof.
My question is now the driver side is fine but the passenger side, not. Cannot move up/down, at all. So can I still try your method? The problem is that I tried moving the window. It moved down a little (maybe 3cm) then stopped. Can't move up/down anymore. So I do not want to risk having to park the car with a window half down.
I went to several miata workshops and they cannot find the root for the cause and it's been very frustrating.
Your adivce please.
Edited by Anjoy
