SaeedHA Neutral Newbie June 2, 2015 Share June 2, 2015 (edited) the most disadvantage things for 8650BT is about song management. it's very disappointed that this HU didn't have any favorite song option on the main play zoom. Edited June 2, 2015 by SaeedHA ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Lawkoh 1st Gear June 3, 2015 Share June 3, 2015 the most disadvantage things for 8650BT is about song management. it's very disappointed that this HU didn't have any favorite song option on the main play zoom. Does other models or brand has this feature?? Link to post Share on other sites More sharing options...
neilaa69 Neutral Newbie June 4, 2015 Share June 4, 2015 I updated my firmware to 1.06 and now I’m having issue with Bluetooth Media Audio. In order for me to connect with Media Audio , I need to clear the Bluetooth memory from the HU and pair it again. As such media audio will work, but if I turn off the engine, then start the engine... I need to do the same process again. No issue observed in phone audio as it automatically connect every time I turn the HU on. Done multiple reset to factory but still the same. Someone here having the same issue? Any advice please Link to post Share on other sites More sharing options...
Xuan_Son Clutched June 4, 2015 Share June 4, 2015 I updated my firmware to 1.06 and now I’m having issue with Bluetooth Media Audio. In order for me to connect with Media Audio , I need to clear the Bluetooth memory from the HU and pair it again. As such media audio will work, but if I turn off the engine, then start the engine... I need to do the same process again. No issue observed in phone audio as it automatically connect every time I turn the HU on. Done multiple reset to factory but still the same. Someone here having the same issue? Any advice please Let try this 1. Restart your phone, if not OK, then try another phone. 2. If 1 useless, then try re-upgrade firmware and do reset all setting to factory right after upgrade Link to post Share on other sites More sharing options...
neilaa69 Neutral Newbie June 5, 2015 Share June 5, 2015 Let try this 1. Restart your phone, if not OK, then try another phone. 2. If 1 useless, then try re-upgrade firmware and do reset all setting to factory right after upgrade Tried #1 with another phone and I got the same behavior. I will try to re-upgrade soon to see if it will work. Thanks. Link to post Share on other sites More sharing options...
neilaa69 Neutral Newbie June 6, 2015 Share June 6, 2015 Let try this 1. Restart your phone, if not OK, then try another phone. 2. If 1 useless, then try re-upgrade firmware and do reset all setting to factory right after upgrade Tried #1 with another phone and I got the same behavior. Tried #2 re-upgrade and but issue still the same.. Any advise please... Link to post Share on other sites More sharing options...
SaeedHA Neutral Newbie June 6, 2015 Share June 6, 2015 (edited) I updated my firmware to 1.06 and now I’m having issue with Bluetooth Media Audio. In order for me to connect with Media Audio , I need to clear the Bluetooth memory from the HU and pair it again. As such media audio will work, but if I turn off the engine, then start the engine... I need to do the same process again. No issue observed in phone audio as it automatically connect every time I turn the HU on. Done multiple reset to factory but still the same. Someone here having the same issue? Any advice please i have 1.08 and i don't have any problem with audio bluetooth Edited June 6, 2015 by SaeedHA Link to post Share on other sites More sharing options...
neilaa69 Neutral Newbie June 6, 2015 Share June 6, 2015 i have 1.08 and i don't have any problem with audio bluetooth Where did you downloaded version 1.08?, in Pioneer Australia only 1.06 is available for download. Link to post Share on other sites More sharing options...
SaeedHA Neutral Newbie June 6, 2015 Share June 6, 2015 Where did you downloaded version 1.08?, in Pioneer Australia only 1.06 is available for download. i bought my HU 3 weeks ago and 1.08 pre-installed . pdf for instruction: http://www.pioneerelectronics.com/StaticFiles/PUSA/Car%20Electronics/Firmware%20Update%20Files/iDataLink%20Maestro%20&%20Apple%20CarPlay%20v1.07_1.08/1.08%20Maestro%20FW%20Update%20Letter%20FINAL_AVH-4000NEX.pdf 1.08 firmware download link: https://pioneer-usa.app.box.com/s/h3evuiqjg43pn75tkdlx pls read instruction carefully and make sure about compatibility with your HU build number Link to post Share on other sites More sharing options...
neilaa69 Neutral Newbie June 6, 2015 Share June 6, 2015 i bought my HU 3 weeks ago and 1.08 pre-installed . pdf for instruction: http://www.pioneerelectronics.com/StaticFiles/PUSA/Car%20Electronics/Firmware%20Update%20Files/iDataLink%20Maestro%20&%20Apple%20CarPlay%20v1.07_1.08/1.08%20Maestro%20FW%20Update%20Letter%20FINAL_AVH-4000NEX.pdf 1.08 firmware download link: https://pioneer-usa.app.box.com/s/h3evuiqjg43pn75tkdlx pls read instruction carefully and make sure about compatibility with your HU build number Ops.. I dont have the courage to install 1.08 version as it is not shown in Australian site. does any one other than SaeedHA done this? Link to post Share on other sites More sharing options...
Mirage6580 1st Gear June 6, 2015 Share June 6, 2015 Ops.. I dont have the courage to install 1.08 version as it is not shown in Australian site. does any one other than SaeedHA done this? Hmm.. This version 1.08 is release in 2014 , far before IOS 8.13 release .. U brought the set from local , I brought it on sept 2014, but is version 1.05... Also got no courage to install.. Link to post Share on other sites More sharing options...
SaeedHA Neutral Newbie June 7, 2015 Share June 7, 2015 (edited) Ops.. I dont have the courage to install 1.08 version as it is not shown in Australian site. does any one other than SaeedHA done this? you can contact local distributor and ask them about compatibility. i always download firmware from US site and trust them. usually it's ok. This firmware update (version 1.08) contains the following improvements: Compatibility with iDatalink Maestro Minor bug fixes and audio related issues All items from the previous update (version 1.06): Apple CarPlay support for iPhone® 6 Plus, iPhone 6, iPhone 5s, iPhone 5c, and iPhone 5 iTunes® Radio support for iPhone 6 Plus, iPhone 6, iPhone 5s, iPhone 5c, and iPhone 5 Support for MPEG-2 playback Edited June 7, 2015 by SaeedHA Link to post Share on other sites More sharing options...
neilaa69 Neutral Newbie June 7, 2015 Share June 7, 2015 <p> you can contact local distributor and ask them about compatibility. i always download firmware from US site and trust them. usually it's ok. This firmware update (version 1.08) contains the following improvements: Compatibility with iDatalink Maestro Minor bug fixes and audio related issues All items from the previous update (version 1.06):Apple CarPlay support for iPhone® 6 Plus, iPhone 6, iPhone 5s, iPhone 5c, and iPhone 5 iTunes® Radio support for iPhone 6 Plus, iPhone 6, iPhone 5s, iPhone 5c, and iPhone 5 Support for MPEG-2 playback thanks Saeed for the advise. . Link to post Share on other sites More sharing options...
Kelyeo8104 Neutral Newbie June 8, 2015 Share June 8, 2015 Our head unit doesn't allow U.S. version to be installed. Link to post Share on other sites More sharing options...
kelvinlbl 1st Gear July 2, 2015 Share July 2, 2015 Just collected my new car, and come with a new set of AVH-X8650T. As I plan to get another brand of audio system, so have to sell it off. Anyone interest can PM me to discuss. it still in a new pack box. Link to post Share on other sites More sharing options...
Mirage6580 1st Gear July 4, 2015 Share July 4, 2015 Hi The car play for the HU is very unstable.. Anyone had tried?? I have also updated the IOS to the latest 8.4, same.. Link to post Share on other sites More sharing options...
SaeedHA Neutral Newbie July 4, 2015 Share July 4, 2015 (edited) Hi The car play for the HU is very unstable.. Anyone had tried?? I have also updated the IOS to the latest 8.4, same.. hi yes, me too. it is very unstable. and 8.4 is same. it's not about iphone, i think the HU must update firmware for remove this bug. Edited July 4, 2015 by SaeedHA Link to post Share on other sites More sharing options...
Melbs 1st Gear July 7, 2015 Share July 7, 2015 carplay is very stable for me. it helps if you guys state what "instability" you are experiencing as i'm pretty much using car play all the time and not the pioneer os, nor appradio live, etc. ↡ Advertisement Link to post Share on other sites More sharing options...
