Lawkoh 1st Gear May 9, 2015 Share May 9, 2015 On 5/9/2015 at 6:35 AM, Mirage6580 said: Hi Strange , I dont have this problem.. I can continue the song when re start the engine(SD card). I have yet to try the USB thumb drive... May I know your firmware version? ↡ Advertisement Link to post Share on other sites More sharing options...
Mirage6580 1st Gear May 9, 2015 Share May 9, 2015 On 5/9/2015 at 8:12 AM, Lawkoh said: May I know your firmware version? Same.. 1.06 ,pioneer singapore web site, Link to post Share on other sites More sharing options...
Lawkoh 1st Gear May 10, 2015 Share May 10, 2015 On 5/9/2015 at 8:39 AM, Mirage6580 said: Same.. 1.06 ,pioneer singapore web site, Can you recall after your 1.06 firmware update, did the system restore back to factory setting? Meaning the FM presets and other settings are all gone. Need to redo everything again. Link to post Share on other sites More sharing options...
Mirage6580 1st Gear May 10, 2015 Share May 10, 2015 On 5/10/2015 at 9:41 AM, Lawkoh said: Can you recall after your 1.06 firmware update, did the system restore back to factory setting? Meaning the FM presets and other settings are all gone. Need to redo everything again. Hi Actually ,I was prepare to do all setting again after the refresh of the firmware .. Surprisingly , it didn't restore to factory setting.. Hope it help.. Link to post Share on other sites More sharing options...
Lawkoh 1st Gear May 10, 2015 Share May 10, 2015 On 5/10/2015 at 2:03 PM, Mirage6580 said: Hi Actually ,I was prepare to do all setting again after the refresh of the firmware .. Surprisingly , it didn't restore to factory setting.. Hope it help.. Thank you for the reply. Same thought here and the setting remain unchanged. According to the instructions, the last step after the firmware update is to press the "home" button which I believe I didn't do that. I think I pressed the mode instead. Home button could reset the system to factory setting. Anyway, I solved the problem by doing a hard reset. Manual enter all settings. So far, it can resume the play back for the pass few times today. The new firmware 1.06 did help to read the file much faster than previously. It's around 5 second after loading completed. Link to post Share on other sites More sharing options...
Stocksiao Neutral Newbie May 19, 2015 Share May 19, 2015 On 5/10/2015 at 2:44 PM, Lawkoh said: Thank you for the reply. Same thought here and the setting remain unchanged. According to the instructions, the last step after the firmware update is to press the "home" button which I believe I didn't do that. I think I pressed the mode instead. Home button could reset the system to factory setting. Anyway, I solved the problem by doing a hard reset. Manual enter all settings. So far, it can resume the play back for the pass few times today. The new firmware 1.06 did help to read the file much faster than previously. It's around 5 second after loading completed. Thanks for the tip bro. I had same problem and solved by hard reset. Link to post Share on other sites More sharing options...
Lawkoh 1st Gear May 19, 2015 Share May 19, 2015 On 5/19/2015 at 8:53 AM, Stocksiao said: Thanks for the tip bro. I had same problem and solved by hard reset. No problem, at least I know that I am not the only one now. Another issue is the Alphabetical order, they are not really in order? Link to post Share on other sites More sharing options...
SaeedHA Neutral Newbie May 23, 2015 Share May 23, 2015 (edited) AVH-X8650BT support SDHC up to which capacity? will be work with 32 GB? what's difference between AVH-X8750BT and AVH-X8650BT? Edited May 23, 2015 by SaeedHA Link to post Share on other sites More sharing options...
Mirage6580 1st Gear May 23, 2015 Share May 23, 2015 On 5/23/2015 at 11:01 AM, SaeedHA said: AVH-X8650BT support SDHC up to which capacity? will be work with 32 GB? what's difference between AVH-X8750BT and AVH-X8650BT? Hi Yes , It do support 32GB , I do have one. I don't see much different between 8750 and 8650 , but I understand that 8750 do not require third party module to link those control on the steering wheel. Hop it helps.. Link to post Share on other sites More sharing options...
SaeedHA Neutral Newbie May 24, 2015 Share May 24, 2015 On 5/23/2015 at 2:20 PM, Mirage6580 said: Hi Yes , It do support 32GB , I do have one. I don't see much different between 8750 and 8650 , but I understand that 8750 do not require third party module to link those control on the steering wheel. Hop it helps.. hi dude tnx a lot for your information. i have problem with 8650 and steering wheel. i have connect2 interface and work very well with pioneer 5150. but with 8650 didn't work. i think , i must use power for steering remote from HU. in 5150 , interface get power from battery, but in 8650 i think , it works only with power from 8650. Link to post Share on other sites More sharing options...
Mirage6580 1st Gear May 24, 2015 Share May 24, 2015 On 5/24/2015 at 6:38 AM, SaeedHA said: hi dude tnx a lot for your information. i have problem with 8650 and steering wheel. i have connect2 interface and work very well with pioneer 5150. but with 8650 didn't work. i think , i must use power for steering remote from HU. in 5150 , interface get power from battery, but in 8650 i think , it works only with power from 8650. Hi It should work with third party module. Vol up down, mode and channel up down..these 5 should work as standard. But for voice commander, phone pick up and hang might need the module.. thanks.. Link to post Share on other sites More sharing options...
Xuan_Son Clutched May 25, 2015 Share May 25, 2015 On 5/5/2015 at 4:10 AM, Lawkoh said: I have updated to firmware 1.06 And now having the problem of mp3 song not able to resume after I restart the engine. It always start from the first song. Any setting for this? Anyone esle facing the same problem? Just do Restore Factory Setting after firmware upgrading. it will fixes the problem. I faced this problem last year when upgraded to 1.06 firmware. Link to post Share on other sites More sharing options...
Xuan_Son Clutched May 25, 2015 Share May 25, 2015 On 5/24/2015 at 6:38 AM, SaeedHA said: hi dude tnx a lot for your information. i have problem with 8650 and steering wheel. i have connect2 interface and work very well with pioneer 5150. but with 8650 didn't work. i think , i must use power for steering remote from HU. in 5150 , interface get power from battery, but in 8650 i think , it works only with power from 8650. My posts at #62, #64, #67 could help you to fix this problem. But it's required to modify resistor value of steering buttons. You have to do it by your self or asking someone to help p/s: I cannot directly help this because of very far distance (I live in Vietnam) Link to post Share on other sites More sharing options...
SaeedHA Neutral Newbie May 25, 2015 Share May 25, 2015 On 5/25/2015 at 2:33 AM, Xuan_Son said: My posts at #62, #64, #67 could help you to fix this problem. But it's required to modify resistor value of steering buttons. You have to do it by your self or asking someone to help p/s: I cannot directly help this because of very far distance (I live in Vietnam) tnx dude i fixed this problem. right now works very well. i have another question. 8650 in bluetooth audio , couldn't show artwork. is it ok? Link to post Share on other sites More sharing options...
Fishy 4th Gear May 26, 2015 Share May 26, 2015 does 8650BT works well with a reverse camera? Link to post Share on other sites More sharing options...
SaeedHA Neutral Newbie May 26, 2015 Share May 26, 2015 On 5/26/2015 at 12:21 AM, Fishy said: does 8650BT works well with a reverse camera? yes it is good. Link to post Share on other sites More sharing options...
Fishy 4th Gear May 26, 2015 Share May 26, 2015 (edited) On 5/26/2015 at 5:01 AM, SaeedHA said: yes it is good. thanks, is 8650 laggy ? Edited May 26, 2015 by Fishy Link to post Share on other sites More sharing options...
SaeedHA Neutral Newbie May 27, 2015 Share May 27, 2015 On 5/26/2015 at 11:21 AM, Fishy said: thanks, is 8650 laggy ? sometimes, i think the processor is a little weak, sometimes you want to run two things at a same time, it have lag. for example, if you played music and change splash screen, music will be pause or play with lag. ↡ Advertisement Link to post Share on other sites More sharing options...
