DarkFly3r 1st Gear May 7, 2014 Share May 7, 2014 Hey guys, im driving a vios and for the past few weeks, my car will start to hesitate especially when i accelerate hard from stop. The feeling is like it will pull you back and then regain back its power. It will not happen if i accelerate slowly. Thanks for any help. ↡ Advertisement Link to post Share on other sites More sharing options...
UncleAtas Turbocharged May 7, 2014 Share May 7, 2014 Your car is old and very tired liao.. Why need to floor hard? Supersprint to the next traffic light?? Link to post Share on other sites More sharing options...
Zxcvb Turbocharged May 7, 2014 Share May 7, 2014 Maybe gear going to kaput, assuming you're on auto. Link to post Share on other sites More sharing options...
Ezfaun 3rd Gear May 7, 2014 Share May 7, 2014 Fuel blockage, most likely. Faulty fuel pump, clogged fuel filter, fuel pressure regulator, injectors, injection map. Or worse gearbox. If you frequently pump msia oil 97 and below, your fuel filter will choke in no time. 1 Link to post Share on other sites More sharing options...
Baal Supersonic May 7, 2014 Share May 7, 2014 my take is fueling, throttle issues. 1 Link to post Share on other sites More sharing options...
DarkFly3r 1st Gear May 7, 2014 Author Share May 7, 2014 Your car is old and very tired liao.. Why need to floor hard? Supersprint to the next traffic light?? I did not floor the pedal. Just accelerate slightly harder. Link to post Share on other sites More sharing options...
Aurora 1st Gear May 7, 2014 Share May 7, 2014 It could be the ignition coil... I recently also faced this problem (but i driving Mit Lancer)... Accelerate up till 80km/h or more and the car seems to suffer from a slight pull back with bit of stuttering but slow speed is fine... Diagnosed that one out of the two ignition coil is spoil... I kiasu a bit and changed both... The car is fine after that.... I did not floor the pedal. Just accelerate slightly harder. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 7, 2014 Share May 7, 2014 Many issues can cause a sudden loss of power. The question is which one? Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 7, 2014 Share May 7, 2014 misfiring......change the SP and ignition coil. Link to post Share on other sites More sharing options...
Earthboy 4th Gear May 7, 2014 Share May 7, 2014 Bro don't wast time with nonsensical post. Such post just waste time and bandwidth I did not floor the pedal. Just accelerate slightly harder. Link to post Share on other sites More sharing options...
TJX Turbocharged May 7, 2014 Share May 7, 2014 Hey guys, im driving a vios and for the past few weeks, my car will start to hesitate especially when i accelerate hard from stop. The feeling is like it will pull you back and then regain back its power. It will not happen if i accelerate slowly. Thanks for any help. Accelerate hard from stop but not referring to flooring to pedal?? A bit hard to understand... Cld be u got used to the acceleration till diminishing returns set in... It's time to add some poison or change car liaoz... Normal.. Link to post Share on other sites More sharing options...
DarkFly3r 1st Gear May 8, 2014 Author Share May 8, 2014 Accelerate hard from stop but not referring to flooring to pedal?? A bit hard to understand... Cld be u got used to the acceleration till diminishing returns set in... It's time to add some poison or change car liaoz... Normal.. Ok, let me elaborate my issue again to prevent from further misunderstandings. Im usually a light footer and most of the time my throttle position is at about 20-30%. There are times when i need to increase my acceleration to 30-50% position due to traffic conditions. That is when the car will start to have hiccup/jerking feell when i accelerate from stop. Hope i have made myself clear. Thanks. misfiring......change the SP and ignition coil. My plugs are new but not the ignition coils. I have no issue when comes to idling. It could be the ignition coil... I recently also faced this problem (but i driving Mit Lancer)... Accelerate up till 80km/h or more and the car seems to suffer from a slight pull back with bit of stuttering but slow speed is fine... Diagnosed that one out of the two ignition coil is spoil... I kiasu a bit and changed both... The car is fine after that.... I only have the jerk issue when i accelerate from stop. Cruising no issue. Will have the coils checked. Thanks. Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 8, 2014 Share May 8, 2014 Ok, let me elaborate my issue again to prevent from further misunderstandings. Im usually a light footer and most of the time my throttle position is at about 20-30%. There are times when i need to increase my acceleration to 30-50% position due to traffic conditions. That is when the car will start to have hiccup/jerking feell when i accelerate from stop. Hope i have made myself clear. Thanks. My plugs are new but not the ignition coils. I have no issue when comes to idling. I only have the jerk issue when i accelerate from stop. Cruising no issue. Will have the coils checked. Thanks. a soon to be konked out coil pack would perform normally but will misfire upon load. If possible, get a similar car and change out all 4. This could be it..... Link to post Share on other sites More sharing options...
Ahgong Supercharged May 8, 2014 Share May 8, 2014 hmmm... could your CPU or ECU be out of sync? it is very common in the waja, i heard. but for Vios, i not sure. Link to post Share on other sites More sharing options...
Eds Neutral Newbie May 8, 2014 Share May 8, 2014 (edited) When station idling get out of ur car ,go and listen to ur muffler ......can hear pop pop sound if yes ....is Ignition coil. Edited May 8, 2014 by Eds Link to post Share on other sites More sharing options...
Fitvip Supersonic May 9, 2014 Share May 9, 2014 (edited) Is your air filter clear. If it is choked up, the car can behave this way too! Edited May 9, 2014 by Fitvip Link to post Share on other sites More sharing options...
DarkFly3r 1st Gear May 16, 2014 Author Share May 16, 2014 My air filter is new. Will probably get my coils checked. Thanks. :) Link to post Share on other sites More sharing options...
Volvobrick Hypersonic May 16, 2014 Share May 16, 2014 Ok, let me elaborate my issue again to prevent from further misunderstandings. Im usually a light footer and most of the time my throttle position is at about 20-30%. There are times when i need to increase my acceleration to 30-50% position due to traffic conditions. That is when the car will start to have hiccup/jerking feell when i accelerate from stop. Hope i have made myself clear. Thanks. My plugs are new but not the ignition coils. I have no issue when comes to idling. I only have the jerk issue when i accelerate from stop. Cruising no issue. Will have the coils checked. Thanks. Sounds like ignition coils. If the vehicle has more than 110K km on the clock, you should replace them. Not sure how much for Toyota, but it is about $110 each for Volvo. If you want to save some money, take out individual coils (one at a time) from the plug and attached a spare spark plug and rev the engine. If no sparks or intermittent sparks, then that coil is gone. Just replace that coil. But usually others will fail within months. Or check engine fault codes - it will tell you which engine misfire. Good Luck! Is your air filter clear. If it is choked up, the car can behave this way too! Unlikely - air filter has negligible impact on the engine, not like this anyway - jerking/hiccups. ↡ Advertisement Link to post Share on other sites More sharing options...
Lancer ex 1.6 can't accelerate
First time buyer looking to buy Fit/Civic/transport car.
15" or 16" for Toyota Vios?
Vios returns to BM in 2018
1.5A Vios may 2008 worth to renew COE?
