Donut Supercharged April 29, 2014 Share April 29, 2014 i realised that my ciggy slot is not working. I used it to charge my car cam recorder through usb charger. recently it's not charging at all. I tried couple of brand new usb chargers, also not working. I also tried my unused Garmin GPS ciggy charger, also not working. Any one can advise on what might be the problem? fuse blow? wire loose inside? Will a dying car battery caused this too? My car batt is about 2.5 years old. ↡ Advertisement Link to post Share on other sites More sharing options...
GLZT 6th Gear April 29, 2014 Share April 29, 2014 Check the fuse first. Its the easiest and most likely problem. Link to post Share on other sites More sharing options...
Ahgong Supercharged April 29, 2014 Share April 29, 2014 yep. i was going to suggest that as well. if the fuse looks ok, it could be loose wiring. happened to my ride when i first got it. got my mechanic to fixed it for me during my servicing. he threw it in free for me. so happy~! :) Link to post Share on other sites More sharing options...
Baal Supersonic April 29, 2014 Share April 29, 2014 Mine wasn't the ciggy charger but the 12v outlet. WS checked & found it was the fuse. Link to post Share on other sites More sharing options...
Matoonia 6th Gear April 29, 2014 Share April 29, 2014 Mine is different problem. 12V plug working but the lighter socket does not heat up. Anyway i use it as charger so don't really bother me Link to post Share on other sites More sharing options...
RadX Moderator April 29, 2014 Share April 29, 2014 i realised that my ciggy slot is not working. I used it to charge my car cam recorder through usb charger. recently it's not charging at all. I tried couple of brand new usb chargers, also not working. I also tried my unused Garmin GPS ciggy charger, also not working. Any one can advise on what might be the problem? fuse blow? wire loose inside? Will a dying car battery caused this too? My car batt is about 2.5 years old. change car 4 Link to post Share on other sites More sharing options...
Donut Supercharged April 29, 2014 Author Share April 29, 2014 change car yeah... paper car soon....... CHOY!!!!!!!!!!!!!!!!!!!!! Link to post Share on other sites More sharing options...
RadX Moderator April 29, 2014 Share April 29, 2014 yeah... paper car soon....... CHOY!!!!!!!!!!!!!!!!!!!!! this month oni, i give u RR down there...ai mai? I throw in Aston for the maid for down there too... Link to post Share on other sites More sharing options...
Car_man 2nd Gear April 29, 2014 Share April 29, 2014 Can go autobac to look for the fuse. But must get the same amp as original Link to post Share on other sites More sharing options...
Agalvilaku 2nd Gear April 29, 2014 Share April 29, 2014 It has to be blown fuse. I have had similar experience before, paid $5 to replace one. But, recently having another problem, if I tried to charge phone, it actually drains the battery rather charging, but the lights are still working on the charger. Read in another post that this too can be due the fuse issue, but have not time to check that yet Link to post Share on other sites More sharing options...
Turboguy 5th Gear April 29, 2014 Share April 29, 2014 most likely is fuse. There are spares fuses in your car fuse box, in the engine bay area, right next to the battery. open up the box cover, the fuses and the fuse removal tool should be behind the box cover. Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 29, 2014 Share April 29, 2014 there must be something that have triggered and blow the fuse. Fuse dont just blow for no reason and its there for that reason. Link to post Share on other sites More sharing options...
Watwheels Supersonic April 29, 2014 Share April 29, 2014 My bro's Lancer EX also had the same problem. It cannot be fixed. I dunno why. Fed up, he went to an audio shop, got an aftermarket twin power socket and install it on an empty space or slot. The damage was like $10 or smth. Somemore they made it look like original, like part of the center console, nicely done. LoL... Link to post Share on other sites More sharing options...
EXO 4th Gear April 29, 2014 Share April 29, 2014 Last time my family's Altis kana this problem twice. Luckily both times are due to a blown fuse, each replace at Borneo Motors is less than $10. After the 2nd time, replace the cig port hub and the problem never comes back. I believe the main thing is not to plug in and out cig port usb charger as sometimes due to lousy build quality could cause the fuse to blow. Link to post Share on other sites More sharing options...
Kb27 Supersonic April 29, 2014 Share April 29, 2014 (edited) DC or ciggie socket is exposed and it's very easy to short circuit the centre pin to the side casing, which is shorting 12V to ground. It just take a badly build plug, a slip, a screw/bolt dropped inside to short and blow the fuse, but that's what the fuse is there for. When you're replacing that fuse, replaced with the same rating. It's never more than 15A. The fuse is to protect the wiring from overheating and catching fire. And if you're plugging those 3-in-1 extension socket in, look at the wiring. If it's very thin, you have to be careful, unless there's another smaller fuse to protect it. Edited April 29, 2014 by Kb27 1 Link to post Share on other sites More sharing options...
Kman08 3rd Gear April 30, 2014 Share April 30, 2014 Last time my family's Altis kana this problem twice. Luckily both times are due to a blown fuse, each replace at Borneo Motors is less than $10. After the 2nd time, replace the cig port hub and the problem never comes back. I believe the main thing is not to plug in and out cig port usb charger as sometimes due to lousy build quality could cause the fuse to blow. I could have sworn fuses were like a dollar or 2 at the most. Link to post Share on other sites More sharing options...
Astrid 4th Gear April 30, 2014 Share April 30, 2014 i realised that my ciggy slot is not working. I used it to charge my car cam recorder through usb charger. recently it's not charging at all. I tried couple of brand new usb chargers, also not working. I also tried my unused Garmin GPS ciggy charger, also not working. Any one can advise on what might be the problem? fuse blow? wire loose inside? Will a dying car battery caused this too? My car batt is about 2.5 years old. Let me guess - you own a German brand car built between 2006-2010? BMWs and VW/Audi had that common problem. At first workshop diagnosed to be the plunger knob open circuit. Changed knob and replaced fuse ... worked for a while, then kaput again. They had to replace the whole module as fault was the OEM design from German supplier ... apparently supplying same to BMW and VAG cars. Either that or you keep on replacing the fuse. Or switch to a Merc - which does not use the same OEM. ↡ Advertisement Link to post Share on other sites More sharing options...
Nearly 2,000 HDB car parks to have at least 3 EV charging points each by 2025
Charging phone in car and impact on car battery
The Electric Vehicle Charging Problem
Recirculation mode not working
Redmart charges a "Slot Fee" from 15 June
First mobile fast-charging service for electric vehicles in Singapore
