Stevle 5th Gear April 25, 2014 Share April 25, 2014 Found this video on the internet... amazing feat indeed.. http://www.youtube.com/watch?feature=player_embedded&v=MQm5BnhTBEQ ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Evillusion Supersonic April 25, 2014 Share April 25, 2014 waliao...your title is misleading siak! I thought you were going to do a stunt! But please dont change your tyres while driving....its dangerous and i dont think its doable! Link to post Share on other sites More sharing options...
2BDriver Hypersonic April 25, 2014 Share April 25, 2014 (edited) The minimum requirements of a terrorist are as follows : Face Mask Strong Guts Smart in Crazy Creative Ideas Believe in Life is Worthless Raise both arms high up and shouting it is " Art Lah ! " Able to make others head shakings and Jaw Dropping Edited April 25, 2014 by Fongmy 3 Link to post Share on other sites More sharing options...
Watwheels Supersonic April 25, 2014 Share April 25, 2014 Haha...these ppl are too free. Life must be boring over there. Link to post Share on other sites More sharing options...
Jman888 Moderator April 25, 2014 Share April 25, 2014 is that possible? to hold on to 2 wheel for so long? Link to post Share on other sites More sharing options...
Vega Turbocharged April 25, 2014 Share April 25, 2014 how come those wheels off the ground totally loss transmission where those on the ground still rotating? Link to post Share on other sites More sharing options...
BabyBlade Internal Moderator April 25, 2014 Share April 25, 2014 wow. i was waiting till the end to see how the driver was gonna put those wheels down the road again. Link to post Share on other sites More sharing options...
drivinghazard 2nd Gear April 25, 2014 Share April 25, 2014 On 4/25/2014 at 1:27 AM, Vega said: how come those wheels off the ground totally loss transmission where those on the ground still rotating? Maybe it's a RWD drive that's why? RWD = Right wheels drive 1 Link to post Share on other sites More sharing options...
Acemundo Supercharged April 25, 2014 Share April 25, 2014 English fail.......created confusion 1 Link to post Share on other sites More sharing options...
Ahgong Supercharged April 25, 2014 Share April 25, 2014 On 4/25/2014 at 2:25 AM, Acemundo said: English fail.......created confusion yep. saw the head subject line tot the driver gonna do a knight rider side drive stunt and still be able to change tire at the same time~! chey~! Link to post Share on other sites More sharing options...
1fast1 Supersonic April 25, 2014 Share April 25, 2014 Someone said this has no practical application in the real world. Au contraire. If you're driving a car-bomb laden vehicle which is set to go off a fixed interval after the car is switched off, and you spring a flat en route to your destination/target, you simply cannot afford to stop to change it out. The only option is to change out your flat on the go. That's where this excellent Saudi-perfected skill set comes into play. Link to post Share on other sites More sharing options...
Ahgong Supercharged April 25, 2014 Share April 25, 2014 On 4/25/2014 at 2:52 AM, Turboflat4 said: Someone said this has no practical application in the real world. Au contraire. If you're driving a car-bomb laden vehicle which is set to go off a fixed interval after the car is switched off, and you spring a flat en route to your destination/target, you simply cannot afford to stop to change it out. The only option is to change out your flat on the go. That's where this excellent Saudi-perfected skill set comes into play. in the scenario you listed, it is usually a one man show. how to achieve the feat seen in the video woh? Link to post Share on other sites More sharing options...
Vega Turbocharged April 25, 2014 Share April 25, 2014 On 4/25/2014 at 2:52 AM, Turboflat4 said: Someone said this has no practical application in the real world. Au contraire. If you're driving a car-bomb laden vehicle which is set to go off a fixed interval after the car is switched off, and you spring a flat en route to your destination/target, you simply cannot afford to stop to change it out. The only option is to change out your flat on the go. That's where this excellent Saudi-perfected skill set comes into play. What I can think of is tire rotation on the go. Hee.. .... 1 Link to post Share on other sites More sharing options...
1fast1 Supersonic April 25, 2014 Share April 25, 2014 On 4/25/2014 at 2:57 AM, Ahgong said: in the scenario you listed, it is usually a one man show. how to achieve the feat seen in the video woh? No lah, one man show is suicide bomber. You can use a team effort for this, as long as people can siam from the car once bomb is armed. Link to post Share on other sites More sharing options...
2BDriver Hypersonic April 25, 2014 Share April 25, 2014 On 4/25/2014 at 3:03 AM, Vega said: What I can think of is tire rotation on the go. Hee.. .... Bro Vega, You are not aware of your 4 tires is always "in rotation" while you're on the Go I'm smart enough to remember that except your spare tire is lying and sitting very still in your car boot ! Link to post Share on other sites More sharing options...
2BDriver Hypersonic April 25, 2014 Share April 25, 2014 On 4/25/2014 at 1:06 AM, Jman888 said: is that possible? to hold on to 2 wheel for so long? Older ones need viagra to holding longer mah ! Sir, how old are you ? how long you can holds ? On 4/25/2014 at 1:27 AM, Vega said: how come those wheels off the ground totally loss transmission where those on the ground still rotating? Could be camera tricks Link to post Share on other sites More sharing options...
1fast1 Supersonic April 25, 2014 Share April 25, 2014 On 4/25/2014 at 3:25 AM, Fongmy said: Could be camera tricks More likely a limited slip differential plus selectable parking brake. I'm not entirely sure. But the stunt looks legit. Link to post Share on other sites More sharing options...
2BDriver Hypersonic April 25, 2014 Share April 25, 2014 (edited) On 4/25/2014 at 3:30 AM, Turboflat4 said: More likely a limited slip differential plus selectable parking brake. I'm not entirely sure. But the stunt looks legit. My first wise question is.... ......How come the wheel nuts are easily loosen by the cross spanner I needs my 57 years ago S26 milk powder power to loose all my 5 nut in one wheel Never trys to argue with their deep believes in "Art Lah" is greatest Edited April 25, 2014 by Fongmy ↡ Advertisement Link to post Share on other sites More sharing options...
Drink Driving Is An Act Of Irresponsibility!
Boomers on the road should take mandatory tests
Petlas Or Giti?
Petlas Or Giti?
Worth to be a Grab Driver now?
