Quekahwhye Clutched February 19, 2014 Share February 19, 2014 Occasion my manual verna gear 'stuck' cannot shift gear but car still moving on that gear. Any bro or sis know what happen???????? THANKS. ↡ Advertisement Link to post Share on other sites More sharing options...
Ahgong Supercharged February 19, 2014 Share February 19, 2014 Occasion my manual verna gear 'stuck' cannot shift gear but car still moving on that gear. Any bro or sis know what happen???????? THANKS. gear box oil levels ok or not? or your clutch got problem? Link to post Share on other sites More sharing options...
Kb27 Supersonic February 19, 2014 Share February 19, 2014 Maybe common clutch problem, like master/slave cylinder leaking. If you pump the clutch a few times and the gear can shift in, that's the leak. Link to post Share on other sites More sharing options...
Earthboy 4th Gear February 19, 2014 Share February 19, 2014 sounds like clutch problem Link to post Share on other sites More sharing options...
Spiderman302 2nd Gear February 19, 2014 Share February 19, 2014 sounds like clutch problem Its a ring prob at the gear stick. Need to replace. Link to post Share on other sites More sharing options...
Watwheels Supersonic February 19, 2014 Share February 19, 2014 It's the linkages that are worn out. Link to post Share on other sites More sharing options...
Old-driver 5th Gear February 19, 2014 Share February 19, 2014 Its All of the Above Go to a mechanic and have a check would be a better option Link to post Share on other sites More sharing options...
Kenken 1st Gear May 6, 2014 Share May 6, 2014 Dear All, What about auto gear no cutch. AT on n off. Down shift from 3 to 1, ear 1 to 2jjerk.any ideal. ATF n filter changed. Thanks Link to post Share on other sites More sharing options...
Ezfaun 3rd Gear May 6, 2014 Share May 6, 2014 (edited) Dear All, What about auto gear no cutch. AT on n off. Down shift from 3 to 1, ear 1 to 2jjerk.any ideal. ATF n filter changed. Thanks If your car is using a normal Planetary gearbox, something in your valve body has worn out. The valve body actuates the clutches in the gearbox and so, directly affects the shifting. The only other things that would affect your shifting would be the modulator, ecu or tcm. That's why autoboxes are so ex to repair. It's not just the gears. If the above goes kaput, It could affect other parts of your g'box and may ruin it completely. Same goes for the valve body in conjunction with several sensors in your car like the cam/crank position sensor, speed sensor, etc.. If it's CVT, it's basically the same but instead of using a normal valve body, it uses a complex pulley positioning system which is even more expensive to repair. Good luck Edited May 6, 2014 by Ezfaun Link to post Share on other sites More sharing options...
Kenken 1st Gear May 7, 2014 Share May 7, 2014 Thanks a lot Bro. Just called mazda for next monday appt. To check what the damage.learn new things today. BTW, obd scan code but no faulty code. After erase every thing gone, some how come back again. Link to post Share on other sites More sharing options...
Kenken 1st Gear May 18, 2014 Share May 18, 2014 Yesterday changed 6 nos solenoid sensor, hope it will solve the problem. ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Toyota GR Corolla
Hyundai Sonata (2015)
About the new Hyundai Accent 1.4 litre
2026 Hyundai Palisade: This Is It
Hyundai Has a New CEO
