tanbk 4th Gear February 6, 2014 Share February 6, 2014 (edited) I have a set of bluetooth headphones and would like to watch my tv with it. Problem is that my TV is not blue-tooth enabled. But it has USB ports. How do I bluetooth enable it? Will just any bluetooth adapter work? Like this http://list.qoo10.sg/item/NEW-802-11N-MINI-NANO-WIFI-LAN/406825004 Edited February 6, 2014 by tanbk ↡ Advertisement Link to post Share on other sites More sharing options...
Dark 5th Gear February 6, 2014 Share February 6, 2014 You have to find one supported by your TV model cos your TV is not like a PC where you can install a driver. I hardly heard of bluetooth dongle support for TV (mostly wifi) but I might be wrong. Link to post Share on other sites More sharing options...
Vid Hypersonic February 6, 2014 Share February 6, 2014 I have a set of bluetooth headphones and would like to watch my tv with it. Problem is that my TV is not blue-tooth enabled. But it has USB ports. How do I bluetooth enable it? Will just any bluetooth adapter work? Like this http://list.qoo10.sg/item/NEW-802-11N-MINI-NANO-WIFI-LAN/406825004 TV is not a computer. Cannot simply just make it bluetooth. If your TV has a 3.5mm headphone jack, buy a bluetooth audio transmitter (NOT receiver) and plug into it. Pair it with your bluetooth headphone and you sort of get a bluetooth enabled TV. I do that too so I can turn up the volume and not disturb anyone at night when I watch movie. 1 Link to post Share on other sites More sharing options...
Jman888 Moderator February 6, 2014 Share February 6, 2014 nobody use this anymore? Link to post Share on other sites More sharing options...
tanbk 4th Gear February 6, 2014 Author Share February 6, 2014 TV is not a computer. Cannot simply just make it bluetooth. If your TV has a 3.5mm headphone jack, buy a bluetooth audio transmitter (NOT receiver) and plug into it. Pair it with your bluetooth headphone and you sort of get a bluetooth enabled TV. I do that too so I can turn up the volume and not disturb anyone at night when I watch movie. My TV has the 3.5mm jack. So I get something like this? http://list.qoo10.sg/item/3-5MM-STEREO-AUDIO-BLUETOOTH-DONGLE/403812968?jaehuid=2000119881 How come it has a wall power plug? Link to post Share on other sites More sharing options...
Vid Hypersonic February 6, 2014 Share February 6, 2014 My TV has the 3.5mm jack. So I get something like this? http://list.qoo10.sg/item/3-5MM-STEREO-AUDIO-BLUETOOTH-DONGLE/403812968?jaehuid=2000119881 How come it has a wall power plug? Yes. Some of them look like that. But you must make sure it is transmitter and not receiver. It has a battery inside so need to charge but you can just use your USB port on your tv to charge it. Just checked your link. It is the transmitter so it'll work fine Link to post Share on other sites More sharing options...
tanbk 4th Gear February 6, 2014 Author Share February 6, 2014 Yes. Some of them look like that. But you must make sure it is transmitter and not receiver. It has a battery inside so need to charge but you can just use your USB port on your tv to charge it. Boss, so I plug 1 end into usb port. 1 end into 3.5mm audio jack. The wall power plug no need to use? This one by Q100 is $30. Where did you go to buy yours? Link to post Share on other sites More sharing options...
Vid Hypersonic February 6, 2014 Share February 6, 2014 Boss, so I plug 1 end into usb port. 1 end into 3.5mm audio jack. The wall power plug no need to use? This one by Q100 is $30. Where did you go to buy yours? Yes. No need to use power plug but if you charge while using the transmitter, you might get noise in your headphone as it interferes with the signal. Best to charge it before use. Can last around 2-3 hrs I got mine in Hong Kong. Cheaper at around $22. Not much difference. Link to post Share on other sites More sharing options...
tanbk 4th Gear February 6, 2014 Author Share February 6, 2014 Yes. No need to use power plug but if you charge while using the transmitter, you might get noise in your headphone as it interferes with the signal. Best to charge it before use. Can last around 2-3 hrs I got mine in Hong Kong. Cheaper at around $22. Not much difference. Thanks!! Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear February 6, 2014 Share February 6, 2014 You can also try the Ranger Bluetooth Audio Transceiver... receive and transmit audio signals to and from TV... but more ex la.. S$69... Amazon sells same one for S$50 , plus free shipping Link to post Share on other sites More sharing options...
Jman888 Moderator February 6, 2014 Share February 6, 2014 can this thing work? http://sg.creative.com/p/accessories/creative-bluetooth-audio-bt-d1-usb-transmitter Link to post Share on other sites More sharing options...
Vid Hypersonic February 6, 2014 Share February 6, 2014 can this thing work? http://sg.creative.com/p/accessories/creative-bluetooth-audio-bt-d1-usb-transmitter pdt_19724.png.png For computers only lah. TV will not be able to recognize it. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Bluedriver - Bluetooth OBD2
Bose SoundSport Free - wireless headphone
Whats the best bluetooth earpiece?
Bluetooth Audio - ZC31S Swift Sport CM Model
My criteria is here - please suggest a suitable unit ?
Bluetooth system in car?
OB2 bluetooth adapter
Car DVD player recommendation
