Kueijie Clutched December 15, 2013 Share December 15, 2013 Hi all, I'm currently looking at buying a 2nd hand Mazda 2 SP. After test drive, I feel that the brake don't really bite. I'm a light footer, is it the cause? Any advice from Mazda 2 owner? ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear December 15, 2013 Share December 15, 2013 check rotor/pad thickness, brake fluid need to change, and maybe lousy tyre also Link to post Share on other sites More sharing options...
octeobd2 December 16, 2013 Share December 16, 2013 it can be adjusted, is also very simple as long as adjusting screw brake pedal can be modified! hope it help to you~ Link to post Share on other sites More sharing options...
Soya Supersonic December 17, 2013 Share December 17, 2013 it can be adjusted, is also very simple as long as adjusting screw brake pedal can be modified! hope it help to you~ errrr.....how do u 'adjust screw brake pedal'??...... Hi all, I'm currently looking at buying a 2nd hand Mazda 2 SP. After test drive, I feel that the brake don't really bite. I'm a light footer, is it the cause? Any advice from Mazda 2 owner? Good choice of car. Likelihood that the brake fluid hasn't been changed or it needs bleeding. Small, simple fix. Link to post Share on other sites More sharing options...
Detach8 5th Gear December 17, 2013 Share December 17, 2013 Jap car is like that de. Get more abrasive brake pads. Change brake fluid. Yes, and tyres matter too. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear December 17, 2013 Share December 17, 2013 Hi all, I'm currently looking at buying a 2nd hand Mazda 2 SP. After test drive, I feel that the brake don't really bite. I'm a light footer, is it the cause? Any advice from Mazda 2 owner? Furry is spot on. Considering the age of the SP, I suspect that it's more likely that the rotors are worn, or the brake fluid needs to be changed and bled. Link to post Share on other sites More sharing options...
Baal Supersonic December 17, 2013 Share December 17, 2013 sorry to interject. Normally for basic cars, foot brake engage Only front & hand brake only rear? Or is footbrake, 70% front, 30% rear.? thx. Link to post Share on other sites More sharing options...
Pocus Turbocharged December 17, 2013 Share December 17, 2013 Just to confirm. Mazda 2 SP is rear disc or rear drum brakes? I know rear drum's braking power is not as spontanous as all disc brake system. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear December 17, 2013 Share December 17, 2013 sorry to interject. Normally for basic cars, foot brake engage Only front & hand brake only rear? Or is footbrake, 70% front, 30% rear.? thx. Both are engaged. Front biased based on manufacturers settings. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear December 17, 2013 Share December 17, 2013 Just to confirm. Mazda 2 SP is rear disc or rear drum brakes? I know rear drum's braking power is not as spontanous as all disc brake system. drum..... Link to post Share on other sites More sharing options...
Baal Supersonic December 17, 2013 Share December 17, 2013 Both are engaged. Front biased based on manufacturers settings. That's for footbrake only izit? Handbrake is purely rear brakes ? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear December 17, 2013 Share December 17, 2013 That's for footbrake only izit? Handbrake is purely rear brakes ? yes unless car uses front brake for parking Link to post Share on other sites More sharing options...
Baal Supersonic December 17, 2013 Share December 17, 2013 yes unless car uses front brake for parking k, thanks bro. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear December 19, 2013 Share December 19, 2013 That's for footbrake only izit? Handbrake is purely rear brakes ? Yup. Link to post Share on other sites More sharing options...
Pisces69 6th Gear December 19, 2013 Share December 19, 2013 errrr.....how do u 'adjust screw brake pedal'??...... I think better to ignore this person. Posts rubbish as far as I can see. sorry to interject. Normally for basic cars, foot brake engage Only front & hand brake only rear? Or is footbrake, 70% front, 30% rear.? thx. Alamak. Foot brake activates all 4 wheels. Handbrake is for the rear wheels only. Link to post Share on other sites More sharing options...
Yewheng Twincharged December 19, 2013 Share December 19, 2013 sorry to interject. Normally for basic cars, foot brake engage Only front & hand brake only rear? Or is footbrake, 70% front, 30% rear.? thx. For normal car, footbrake engage all brake with the equal amount of force. What usually people say that car uses more front brake then rear brake is not referring to the brake pressure applied. It is referring to the size of front and rear brake. Generally speaking front brake size will be much bigger then rear brake. So with the same amount of pressure applied, the one with bigger brake will have more stopping power then smaller brake. So hope this explain your 70%-30% not necessary is this figure as it's manufacture to do the calculation on how much waightage to the front and how much to the rear. 1 Link to post Share on other sites More sharing options...
Baal Supersonic December 21, 2013 Share December 21, 2013 For normal car, footbrake engage all brake with the equal amount of force. What usually people say that car uses more front brake then rear brake is not referring to the brake pressure applied. It is referring to the size of front and rear brake. Generally speaking front brake size will be much bigger then rear brake. So with the same amount of pressure applied, the one with bigger brake will have more stopping power then smaller brake. So hope this explain your 70%-30% not necessary is this figure as it's manufacture to do the calculation on how much waightage to the front and how much to the rear. Thanks for the indepth info bro. Link to post Share on other sites More sharing options...
Baal Supersonic December 21, 2013 Share December 21, 2013 Alamak. Foot brake activates all 4 wheels. Handbrake is for the rear wheels only. Hehe.....only realize this after driving for 8 yrs....haha. Should have guessed, how else would rear brakes wear if its only used for parking? tsk tsk tsk..... Coz for bike, right level is pure front, left lever is pure rear. Unless have "combine braking" system, where by have something like right lever activates 1 of 2 pistons rear & 4 of 6 pistons front. Then left lever maybe 2/2 pistons rear and 2 of 6 pistons front. something like that. Never owned such a bike. Understand maxi scoots are now all like that. These days bike/scoot go on to combine + ABS. Dunno over engineering or not. haha ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mazda 6e
2025 Mazda 6e
2026 Mazda EZ-60 / CX-6e
Mazda FC3S RX-7
Mazda FC3S RX-7
MAZDA 6
MAZDA 6
Win a Limited-Edition Mazda RX-7 Diecast in Sgcarmart livery!
2022 Mazda CX-5 Facelift
Original Mazda MX-5 chief designer dead 😢
2022 Mazda CX-60
2022 Mazda CX-60
