DMSG
I'm driving a honda stream 2007 this morning on my way to work the engine just went dead when I was about to drive off at the traffic light junction. I manage to start the engine quickly and drive off. What could be the problem?
Hi Sir,
Your throttle body or air flow sensor might be having some problems. Minor issue only require cleaning. However, do drive by DM for a check.
Give us a call at 6363 5112 should u need any urgent assistance.
Cheers!
Thks for your quick reply, will monitor the situation, if it happen again will make my way down to you for further checks.
Hi
My honda stream 2008 starts to feel vibrate when idle
What could be the cause? I have replaced the front 2 engine mount recently
Thanks
Dear Sir,
Honda RN6 has four mounts to be replaced. Which mounts u replaced? It's always advisable to change all fours to avoid vibrations and better engine performances. It could be due to the other two unchanged mounts (worn mounts giving problems). You might wanna drive down to DM for a check.
Cheers!
Can advise what is the cost to change auto gearbox for Subaru Impreza 2007?
Thanks!
Dear Sir,
For gearbox repair or replacement, we will need to diagnose your car in details. We cannot give any quotes without checking the conditions or any malfunction parts here online. Please drive in DM for a free check.
Cheers!
Hi, how much do you charge for a car "check up"?
Hi Sir,
What type of check up you need? We do have a Pre Inspection or full car review check services at $78. For normal checks on existing problems faced on the vehicles are free with quotes for repair. No obligations even if you decided not to go ahead with the repair.
Cheers!
Hello,
My car is facing some problems with gear changes, air con, noisy engine sound when idling, suspension squeaking etc...
My car is reaching the end of its 3 year warranty with Wearnes and they are offering to do a end-of-warranty check up and repairs for me.
So i want to find out as much problems as possible (from 2nd opinion) so that i can get Wearnes to fix everything.
So you do FOC checks to identify my engine, gear and suspension problems?
Hi Sir,
if you are still under warranty with them for end of warranty check up, please proceed with them. For the requested checks on engine, gear and suspension problems, you will need to go for the $78 comprehensive checks package by us.
DMSG,
if i bring a 2nd hand car to you to check before i purchase the car, the cost is $78 right?
But may i know what does the check consists of?
Hi DM. Noticed my Honda Fit having acceleration issues. Car doesn't seem like it wants to go. Power loss/power lag. Have to floor the pedals and end up accelerating harshly instead of gradual acceleration. Any idea what's the issue?
Hi Sir,
Many things can cause an engine to lose power: fuel pressure ,bad timing, airflow obstructions going into or out of the engine, carbon buildup, worn spark plugs, bad petrol and improper fuel burn in the cylinders, Dirty Fuel Filter airflow variations and so on....
Anymore misfiring experience ? Do advice us further ... Alternatively, drive by DM for a free check on your problem.
Cheers!
Edited by DMSG
DMSG,
Hi Sir,
We will perform a details checks on the undercarriage, suspension system, drive shaft mechanism, steering mechanism, all mechanical joints, perform road worthiness testes, electrical functions, possible accident damage checks, previous body repairs, engine checks, gearing ratio checks, gearing system, Fluid checks, Pump checks, Brake system, A/C components check, Exos pipe Checks.
We have done many comprehensive checks for second hand car seekers. If interested, can arrange by calling us at 6363 5112.
Thank you for your interest with us.
Cheers!
1457707_697936663551067_521746498_n.jpgCheck us out at : www.facebook.com/dynamicsmechanic
Edited by DMSG
What is the normal process like? Do we ask the car dealer to drives the car to you directly for the check?
Hi Sir,
Cheers!
Edited by AWC
i think this is up to you... but for such cases, it is usually the buyer that foot the bill not dealer.... thus usually the dealer will ensure you be there to foot the bill regardless if the results by DMSG is to your satisfaction to purchase the said car
DMSG job is to check the car as long as the fee is paid...
Hi Sir,
Cheers!
Thanks... i am still looking for a car and thinking where to bring for inspection... based on your reply, it seems quite comprehensive.... Volvo no problem hor
Edited by Galantspeedz
Hi Sir,
Both ways are ok with us. To save you the trouble, you can ask your dealers to send the car for our checks. We will only give the report to the buyer. To make arrangements for such checks, give us a call at 6363 5112.
Cheers!
Thanks Bro for doubling up for us. Cheers! Appreciated!
Hi DM Team,
I drive a 2005 Lancer GLX. I recently went for a normal car servicing at a WS in autobay kaki bukit. Beside servicing, I also mentioned to them that I heard some noise coming from the front left wheel. It's especially obvious when going up slope and also uneven road.
I was quoted to change the following:
- Engine Mounting
- Lower Arm (front)
- Absorber
- Absorber Mounting
- Absorber Stopper
- Absorber Bearing
Do i really need to change all these since as my car only left a year or less to drive? Pls advise
Thanks,
Peter
Hi Team DM,
My car is Mazda 3 (2007), rpm shoot up around 2000 when starting my car, after air-con on or push to D mode the rpm normal. Something on N mode rpm shoot up. What is the problem ?
Already change:
1. New plug
2. New E.O
Thanks
MFKW500
Hi DM Team,
- Engine Mounting
- Lower Arm (front)
- Absorber
- Absorber Mounting
- Absorber Stopper
- Absorber Bearing
Thanks,
Peter
Hi Peter,
don't worry... just turn up for a second opinion with us. We will check all those as mentioned above for you. If you need to change them then will advice you.
We wont be able to confirm anything without checking your vehicle. The Checks will be totally FOC and no hidden cost. Please look for our Manager Superman when you are in DM. Cheers!
Hope to see you soon Mr Peter.
Hi Team DM,
Already change:
1. New plug
2. New E.O
Thanks
MFKW500
Hi Sir,
your throttle controller might be dirty or some sensor problems. Please drive by for us to rectify. No charges for the checks and no hidden cost.
Cheers and hope to see you soon Sir.
Hi Team DM
Hybrid Car
as the battery is guarantee for 10years, what happens after 10years, do we need to change
if yes do I need to go to the authorised dealer or can we come to change at your place
lastly would the savings be significant at your place
thank you
Hi Team DM
Hybrid Car
thank you
Hi sir
A battery pack stores and supplies the energy necessary to power a hybrid car's electric motor and it can be used up over a period of time. You will need to get back to manufacturer workshop for your replacement which guarantee warranty period for their original hybrid battery. Check the conditions of the battery before 10 years usage.
Cheers!
