Achtung 6th Gear November 21, 2013 Share November 21, 2013 I have seen many shops and free lance painters claiming to be able to paint calipers in a day and some without even removing the wheels! My question is: What kind of paint is used? Without proper baking and prearing the surface to be painted, does the paint last? LPPL if one has gotta paint it again right? Without removing the entire caliper, does it mean the inside of the caliper will not be painted and there will be two colours? The old and the new? For those who has gone this route, please share your experience. I am aksing cause I just removed my calipers to spray them as I believe it will be more thorough. ↡ Advertisement Link to post Share on other sites More sharing options...
Maseratigood 5th Gear November 21, 2013 Share November 21, 2013 I think if the rotor can glow at nite after hard breaking, assuming the driver drives n brakes hard, the temperature at the calipers can be high and high temp paint is needed to paint it for a start The existing calipers also need to be cleaned, degreased, primed before painting. This means they have to be removed from the car for such proper preparation prior to the actual painting Link to post Share on other sites More sharing options...
Theredstar 2nd Gear November 21, 2013 Share November 21, 2013 (edited) I did with street calipers before the bro went Hendon Think he mentioned using some hammerite paint Apparently sprays are not as lasting No removal Just make sure enough access thru the spokes ( are they called spokes on cars? Lol) Simple prep of washing w some detergent Prolly degreaser too? Only visible parts are painted I guess Quite thorough Quite good quality too But need to maintain cos brake dust may bake in Hope this helps Edited November 21, 2013 by Theredstar Link to post Share on other sites More sharing options...
Skymax 5th Gear November 21, 2013 Share November 21, 2013 LOL, I handpainted my 1 week old vios front n rear calipers with normal oil based red paint in a small 1L tin years ago. The paint stayed on even after i wash the calipers weekly with old sock. Easily DIY project. Just remove the wheel. Sit down. Wipe them n paint. 2-3hr job. Link to post Share on other sites More sharing options...
Achtung 6th Gear November 21, 2013 Author Share November 21, 2013 I did with street calipers before the bro went Hendon Think he mentioned using some hammerite paint Apparently sprays are not as lasting No removal Just make sure enough access thru the spokes ( are they called spokes on cars? Lol) Simple prep of washing w some detergent Prolly degreaser too? Only visible parts are painted I guess Quite thorough Quite good quality too But need to maintain cos brake dust may bake in Hope this helps That means, the rear of the caliper cannot be painted if it is left on.... Link to post Share on other sites More sharing options...
Mockngbrd Supersonic November 22, 2013 Share November 22, 2013 Had mine done with high-temp paint. Just repaint to a generic silver/grey. I think removing wheels will do a better job. ↡ Advertisement Link to post Share on other sites More sharing options...
House painting
House painting
Please advise bodywork repair, spray painting workshop
Recommendations for wall paintings
Art / Painting gallery
Spray Painting @ Bt Indah Johor
Spray Painting
Spray Painting
