Kb27 Supersonic November 8, 2013 Share November 8, 2013 hmmm... means to rig the needle, workshop just take out original float and replace with a new float? seem to be the same process with mine rite? if that's the case, means float is sold seperately? wats the market rate for rigging the needle then? The fuel pump and fuel filter can be bought separately to be replaced individually. So it means the fuel sender is also a separate item. However, it takes some labour to separate them, especially it there are interlocking plastics. It takes quite a bit of effort to pry open the plastics without breaking them, when I change my fuel filter that time. Maybe your ws doesn't like to do that and quote you whole piece. There is a electrical connector there. If you try to rig a fixed resistance, you could put a switch there to toggle between it and the fuel sender. Market rate I dunno. ↡ Advertisement Link to post Share on other sites More sharing options...
Nzy Twincharged November 8, 2013 Share November 8, 2013 The fuel pump and fuel filter can be bought separately to be replaced individually. So it means the fuel sender is also a separate item. However, it takes some labour to separate them, especially it there are interlocking plastics. It takes quite a bit of effort to pry open the plastics without breaking them, when I change my fuel filter that time. Maybe your ws doesn't like to do that and quote you whole piece. There is a electrical connector there. If you try to rig a fixed resistance, you could put a switch there to toggle between it and the fuel sender. Market rate I dunno. If you rig a fixed resistance with a switch, its easy to get caught when they check. The safer method is to bend the wire holding the float so that when the fuel tank is near empty, the needle will be at 3/4. So whenever you drive and see your needle reaching 3/4 you know you need to pump already. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 8, 2013 Share November 8, 2013 after pump full tank, the "DISTANCE to EMPTY" meter will always show nearing 600km.... but dare to play so close meh? 400km better kuai kuai go and pump lah... haha.... My Optra can go abt >800km b4 empty. Thats for hway driving. Tank can pump 60 lit. Link to post Share on other sites More sharing options...
Simonsoh 2nd Gear November 12, 2013 Author Share November 12, 2013 nobody know any workshop that do the 3/4 needle thing? thinking of using their expertise to help me solve this.... Link to post Share on other sites More sharing options...
Johny_walker 1st Gear January 2, 2015 Share January 2, 2015 better dont go jb , wait mata thought empty then catch [sweat] ICA wont catch you but they'll fine you $500. ↡ Advertisement Link to post Share on other sites More sharing options...
Calciphylaxis: An almost fatal disease.
Car Show 2024
Car Show 2024
