Jamesc Hypersonic March 7, 2022 Share March 7, 2022 I am sure it's worse than it looks right? ↡ Advertisement Link to post Share on other sites More sharing options...
Beregond Supersonic March 7, 2022 Share March 7, 2022 On 3/7/2022 at 7:18 AM, Jamesc said: Small tear on my MIL tyre. Nothing to worry about. Use until die lah. Expand actually like this still can save. the wire not expose yet. buy 1 elephant glue 1sgd nia. and the damage is repair ( i say 1 ) 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic March 7, 2022 Share March 7, 2022 So troublesome. I just put this. On 3/7/2022 at 7:25 AM, Beregond said: actually like this still can save. the wire not expose yet. buy 1 elephant glue 1sgd nia. and the damage is repair ( i say 1 ) Expand Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 11, 2022 Share March 11, 2022 On 3/7/2022 at 4:52 AM, Darnpunk said: Asking for opinion, would you replace tyre that has patch in sidewall area nearer to the inner part? Attached picture. Some background.. I had to patch my new front left tyre last July 2021 at a tyre shop (1K mileage). Recently did 10K servicing and tyre rotation. So now it's at rear right. The mechanic advised if possible to replace the tyre as patch done on sidewall. For now to monitor regularly etc. I read online those severe sidewall damage can cause tyre to burst which sounds scary. And minor ones 1/4 inch can be patched. Can't really decide if mine can be considered minor or bad. I think if it was not repairable, the tyre workshop that I sent for patching would have advised me to replace? Thinking of driving for another 5K or so, then replace all tyres. Or just replace the rear 2 now and then at next 10K, replace all. What would you do? Expand just my sharing if you want 100% peace of Mind replace it. you can TRY a method Internal seal with special material name PRP (although the manufacturers will not recommend),one of the purpose of this Internal repair allows the tire Mechanic to inspect internally for any hidden damaged or injury which may lead to tire Explosion as someone mentioned. repair is Repair please do not ask the Service provider is it safe to use the tire lol. tires is the only 4 points between you and Road and tire only fails when working very hard like heavy load and high speed. do your Own Maths Safety against Money. just MHO 2 Link to post Share on other sites More sharing options...
Beregond Supersonic March 11, 2022 Share March 11, 2022 On 3/11/2022 at 2:58 AM, Roberttan said: just my sharing if you want 100% peace of Mind replace it. you can TRY a method Internal seal with special material name PRP (although the manufacturers will not recommend),one of the purpose of this Internal repair allows the tire Mechanic to inspect internally for any hidden damaged or injury which may lead to tire Explosion as someone mentioned. repair is Repair please do not ask the Service provider is it safe to use the tire lol. tires is the only 4 points between you and Road and tire only fails when working very hard like heavy load and high speed. do your Own Maths Safety against Money. just MHO Expand at the corner there, internal repair make it worst😂 that area is very thin, internal repair, they still need to grind it. and that area flex alot. poke a worm through, can work mean can, cannot mean change Link to post Share on other sites More sharing options...
mersaylee Hypersonic March 11, 2022 Share March 11, 2022 On 3/7/2022 at 7:18 AM, Jamesc said: Small tear on my MIL tyre. Nothing to worry about. Use until die lah. Expand How you inflict that tyre injury...aim straight at a big pothole?😁 3 Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 11, 2022 Share March 11, 2022 On 3/11/2022 at 3:46 AM, Beregond said: at the corner there, internal repair make it worst😂 that area is very thin, internal repair, they still need to grind it. and that area flex alot. poke a worm through, can work mean can, cannot mean change Expand 1 of the reason why internal repair can do is allow you to view internally for any hidden damaged which can not be seen from outside, if you Poke from outside you will not have chance to view internally and external Poke can make the Hole even bigger and may worsen the injury. 1 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged March 11, 2022 Share March 11, 2022 On 3/11/2022 at 3:54 AM, mersaylee said: How you inflict that tyre injury...aim straight at a big pothole?😁 Expand You know that he (Jxxxxc) is a masseur right?? That's how he trained his fingers.😁 2 Link to post Share on other sites More sharing options...
Mark5040 Neutral Newbie May 5, 2022 Share May 5, 2022 Hi you are asking about Do I need to change tire?, for this you have to search on google. Link to post Share on other sites More sharing options...
Yamapi 6th Gear May 10, 2022 Share May 10, 2022 Is it normal for tyres to turn brown at the sidewall? The tyres are Bridgestone Potenza Sport, about 2 months old Link to post Share on other sites More sharing options...
Danieldoe Neutral Newbie May 23, 2022 Share May 23, 2022 (edited) Depending on the age and use of the tires, you can replace them. Read More@ car mechanic in Auckland Edited May 23, 2022 by Danieldoe Link to post Share on other sites More sharing options...
boonhat_91 6th Gear October 23, 2022 Share October 23, 2022 Hello MCFers, seeking expert opinions. Sometimes I drive my FIL's car, FD Civic stock. On more than one occasion I have experienced the rear sliding. Once was on some backroad corner in Johor, and again recently when making a u-turn from stationary in Sg. Both times, the road was wet, but speed was fairly low. Both times had 1 front passenger, both pax total weight no more than 170kg. My wife driving it on her own has also experienced multiple occasions of loss of rear traction, also on wet road on a bend she says. Tyres are not bald, mileage should be <20k. My wife and I had feedback this to my FIL before and supposedly his tyre shop checked and said all ok. 1. Could this be an alignment and/or suspension issue? 2. I know we like to bash cheap tyres here, but could these so easily lose traction (low speed turn in wet)? Fronts are Firenza ST-something and Rears are Rotalla Setula E-Race, all in stock 205/16 size. Which leads to... 3. Could the different brand/model in the front vs rear be the cause? If my FIL is really stubborn about using budget tyres, could just changing 2 tyres to follow the same brand/model be sufficient to stop these instances of low speed rear traction loss? Thanks in advance! 1 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic October 23, 2022 Share October 23, 2022 On 10/23/2022 at 5:14 AM, boonhat_91 said: Hello MCFers, seeking expert opinions. Sometimes I drive my FIL's car, FD Civic stock. On more than one occasion I have experienced the rear sliding. Once was on some backroad corner in Johor, and again recently when making a u-turn from stationary in Sg. Both times, the road was wet, but speed was fairly low. Both times had 1 front passenger, both pax total weight no more than 170kg. My wife driving it on her own has also experienced multiple occasions of loss of rear traction, also on wet road on a bend she says. Tyres are not bald, mileage should be <20k. My wife and I had feedback this to my FIL before and supposedly his tyre shop checked and said all ok. 1. Could this be an alignment and/or suspension issue? 2. I know we like to bash cheap tyres here, but could these so easily lose traction (low speed turn in wet)? Fronts are Firenza ST-something and Rears are Rotalla Setula E-Race, all in stock 205/16 size. Which leads to... 3. Could the different brand/model in the front vs rear be the cause? If my FIL is really stubborn about using budget tyres, could just changing 2 tyres to follow the same brand/model be sufficient to stop these instances of low speed rear traction loss? Thanks in advance! Expand I'd rather use same tyres for front and rear regardless of age of both sets than to use new mixed tyres for each axle or side...16" tyres are cheap...I'd just change all 4 to see if issue persist then go from there... 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic October 23, 2022 Share October 23, 2022 On 10/23/2022 at 5:14 AM, boonhat_91 said: Hello MCFers, seeking expert opinions. Sometimes I drive my FIL's car, FD Civic stock. On more than one occasion I have experienced the rear sliding. Once was on some backroad corner in Johor, and again recently when making a u-turn from stationary in Sg. Both times, the road was wet, but speed was fairly low. Both times had 1 front passenger, both pax total weight no more than 170kg. My wife driving it on her own has also experienced multiple occasions of loss of rear traction, also on wet road on a bend she says. Tyres are not bald, mileage should be <20k. My wife and I had feedback this to my FIL before and supposedly his tyre shop checked and said all ok. 1. Could this be an alignment and/or suspension issue? 2. I know we like to bash cheap tyres here, but could these so easily lose traction (low speed turn in wet)? Fronts are Firenza ST-something and Rears are Rotalla Setula E-Race, all in stock 205/16 size. Which leads to... 3. Could the different brand/model in the front vs rear be the cause? If my FIL is really stubborn about using budget tyres, could just changing 2 tyres to follow the same brand/model be sufficient to stop these instances of low speed rear traction loss? Thanks in advance! Expand $250 decision lor. Change the rears to re004 which imho is good and relatively quiet. its shit tires and or suspension. Got thread doesn’t mean got grip. In the end not your car unless you want to change for him for free. Also how often you drive. Just heck it la. Wait till he langar then rub it in and say “limpeh tell to change, you stubborn old man don’t want to! Now langar lor, deserve it! “ 🤣 2 3 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 23, 2022 Share October 23, 2022 There’s always Tourandor. 😁 5 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged October 23, 2022 Share October 23, 2022 On 10/23/2022 at 5:14 AM, boonhat_91 said: Hello MCFers, seeking expert opinions. Sometimes I drive my FIL's car, FD Civic stock. On more than one occasion I have experienced the rear sliding. Once was on some backroad corner in Johor, and again recently when making a u-turn from stationary in Sg. Both times, the road was wet, but speed was fairly low. Both times had 1 front passenger, both pax total weight no more than 170kg. My wife driving it on her own has also experienced multiple occasions of loss of rear traction, also on wet road on a bend she says. Tyres are not bald, mileage should be <20k. My wife and I had feedback this to my FIL before and supposedly his tyre shop checked and said all ok. 1. Could this be an alignment and/or suspension issue? 2. I know we like to bash cheap tyres here, but could these so easily lose traction (low speed turn in wet)? Fronts are Firenza ST-something and Rears are Rotalla Setula E-Race, all in stock 205/16 size. Which leads to... 3. Could the different brand/model in the front vs rear be the cause? If my FIL is really stubborn about using budget tyres, could just changing 2 tyres to follow the same brand/model be sufficient to stop these instances of low speed rear traction loss? Thanks in advance! Expand Seems that rear tyres have less traction than the front. So are the rear tyres older than the front tyres? You can see the 4-digit month & year of manufacture on the tyre sidewall. Otherwise swap the rear tyres to the front and vice versa and see if symptom persists. 3 Link to post Share on other sites More sharing options...
Shibadog Turbocharged October 23, 2022 Share October 23, 2022 On 10/23/2022 at 5:14 AM, boonhat_91 said: Hello MCFers, seeking expert opinions. Sometimes I drive my FIL's car, FD Civic stock. On more than one occasion I have experienced the rear sliding. Once was on some backroad corner in Johor, and again recently when making a u-turn from stationary in Sg. Both times, the road was wet, but speed was fairly low. Both times had 1 front passenger, both pax total weight no more than 170kg. My wife driving it on her own has also experienced multiple occasions of loss of rear traction, also on wet road on a bend she says. Tyres are not bald, mileage should be <20k. My wife and I had feedback this to my FIL before and supposedly his tyre shop checked and said all ok. 1. Could this be an alignment and/or suspension issue? 2. I know we like to bash cheap tyres here, but could these so easily lose traction (low speed turn in wet)? Fronts are Firenza ST-something and Rears are Rotalla Setula E-Race, all in stock 205/16 size. Which leads to... 3. Could the different brand/model in the front vs rear be the cause? If my FIL is really stubborn about using budget tyres, could just changing 2 tyres to follow the same brand/model be sufficient to stop these instances of low speed rear traction loss? Thanks in advance! Expand Noted you and your wife have both experienced it multiple times, but has your FIL experienced it himself? Is the car in Msia? i noticed this Rotalla brand getting popular there. suggestions: 1) chk tyre age. Tyre mileage low but could it be old due to low use during covid? 2) chk tyre pressure 3) if tyre age n pressure ok, chk alignment n suspension (inld bushings) for wear. FD is a car which usually has good mechanical grip 4) change new set of 4 better tyres. Also seriously consider going to a different tyre shop. 2 Link to post Share on other sites More sharing options...
boonhat_91 6th Gear October 23, 2022 Share October 23, 2022 On 10/23/2022 at 5:32 AM, Mkl22 said: its shit tires and or suspension. Got thread doesn’t mean got grip. Expand On 10/23/2022 at 6:21 AM, Shibadog said: Noted you and your wife have both experienced it multiple times, but has your FIL experienced it himself? Is the car in Msia? i noticed this Rotalla brand getting popular there. suggestions: 1) chk tyre age. Tyre mileage low but could it be old due to low use during covid? 2) chk tyre pressure 3) if tyre age n pressure ok, chk alignment n suspension (inld bushings) for wear. FD is a car which usually has good mechanical grip 4) change new set of 4 better tyres. Also seriously consider going to a different tyre shop. Expand Thanks for the advices! If you don't mind entertaining me further, could you elaborate on how sub-optimal or worn alignment and suspension could lead to rear traction loss? The car is in Sg but driven frequently in msia as my FIL has a biz there. I don't think he has experienced it himself, neither has my SIL who also drives the car regularly. Tyre pressure is likely to be underinflated as I'm aware it is not checked regularly. I would think that underinflated tyre actually has more traction, but do correct me if I'm wrong. ↡ Advertisement Link to post Share on other sites More sharing options...
Change Disc Rotors
Change Disc Rotors
Need Advice on Self Storage
Tool to change Spark Plug
