GS Yuasa Car Battery
Ken1898
optra 62ah i think
global batt abt 140-150
Mr GSYusa recommend their Midac battery for Conti cars but have yet to answer bro P69 questions [confused]
Bought in JB. RM200 after trade in close to 2 yr GP maintenance free battery. So far so good.
U meant u bought GP or trade in GP? So far so good from what date?
Ya dunno why he still never answer my query????? [gossip]
Han Kok Chia, Jeponese no interest.
You try buying casings and accessories for Samsung, LG phones in JP, they will tell you "no Han Kok no Han kok".
I dun think so.
Maybe he need to chk the size (Ah) for Optra first. Here any sales is good sales. [laugh]
Now I using Global MF batt. Made in Korea. [thumbsup] But if the Jap made Yuasa price reasonable then I wil try next time. [thumbsup][thumbsup]
But I know Jap stuff mostly quite ex. Thats why ty also manufacture overseas to reduce costs. Thats why now u seldom see Made in Japan in the market. Price just too high.
I dun think so.
Your Optra is based on Ang Moh Chia from GM Opel right? Most likely need high CCA type and will die w/o warning like most Ang Moh Chias.
IIRC handbook says CCA abt 660. But now I use Global CCA only abt 550 but still OK.
Chevy under GM so similar to all the GM cars. Vauxhall, Holden, Opel, etc. But GM OEM battery is AC Delco but now it seems like AC Delco battery sucks.
I wil try the Yuasa MIJ battery if its not too ex. Otherwise I just stick with the Global MIK.
My 1 year old Korean batt is a little bloated at the side and slight leak at the top (which have corroded the metal holder and turned it flaky). What's happening to the battery?
Check your alternator voltage. If more than 16V, it is overcharging battery, boiling away the electrolyte and will make it bloat.
I was quoted $145 for Yuasa battery (60Ah) for my Aveo at one of the authorized seller. He did not mentioned that it is not suitable for my car. However, Mr GSYuasa recommended Midac battery here, so I'm a little bit confused :wacko:
Sorry bro, as I was confirming the size of the battery with our supplier, you could use our Midac S2-62Ah dimension 242x175x190 price should be around S$140-150. However, currently there is no stock from all of our dealers the new stock will be available by end Nov.
We recommend that you use DIN size battery, because your car battery compartment was designed for bottom hold battery, meaning your battery had to be tighten from bottom, which DIN battery having this design.
All Japan Standard -JIS battery were designed with top hold, which means to be tighten with a bracket on the top.
You could use our Japan made ECO-R 80D23L - 69Ah, around S$140-150 as well, provided your car technician able to modified the holder at your battery compartment to hold the battery.
Thanks,
Thanks,
Sorry, typo error, 80D23L is 65Ah
Hi, all cars battery compartment are various, so some similar size JIS battery able to fit into DIN size battery compartment, the technician should be able to advice you on the battery tightening part.
I trade in gp. Bought it in Sept.
Hi, what you getting in Malaysia is also ECO-R, except that they are supplying at a lower spec type.
For example, we supply 44B19L-40Ah-CCA400 in Singapore, in Malaysia they supply 40B19L-35Ah-CCA340, we supply 60B24-CCA495, Malaysia supply 50B24-CCA380 only.
Just installed one from the Dealer Eng Heng located at 01-01 AMK Autopoint. Good service and reasonable price.
Size 105D31L
Mr. Tan have almost every size can check if anyone intend to get one.
Hi, can you recommend a shop in the east that have your batteries?
