Vhtfhwlego Supercharged February 6, 2014 Share February 6, 2014 anybody wanna sell your alfa? my buddy looking for one. preferably 147/GT.The Gt for sale at sgcarmart seems like a good deal. ↡ Advertisement Link to post Share on other sites More sharing options...
Chrispie 5th Gear February 7, 2014 Share February 7, 2014 Not sure if gearbox errors are stored in the ECU. If you're interested, I can use multiecuscan to read the errors to see what they are or check the live pressure reading (that's what I saw Peter do when my gears couldn't engage at all). sounds good.. can u pm me your contacts? Link to post Share on other sites More sharing options...
Lmeng69 1st Gear February 7, 2014 Share February 7, 2014 Tot there was a 147 GTA on sale? Link to post Share on other sites More sharing options...
Crossback Clutched February 7, 2014 Share February 7, 2014 wonder if any of the SS experts can give me some direction... When: 1. At Cold start (or after parked for sometime) Observation: 1. Car starts ok. 2. Gear shifts to N without issue. 3. Gearbox error appears on dash 4. During this period, will not engage gear 5. Error clears after around 10s. 6. Gears in and whole day driving and starting without issue 99% of the time. Special note: 1. New SS pump 2. New SS accumulator. Went to Eper, tried to look up the various drawings, not too sure what could be the issue. Without your spcl note.. I have exactly the same issue...now I park at N gear Hmmm I tot it's the ss pump issue..so might not be.. Link to post Share on other sites More sharing options...
Theredstar 2nd Gear February 7, 2014 Share February 7, 2014 Without your spcl note.. I have exactly the same issue...now I park at N gear Hmmm I tot it's the ss pump issue..so might not be.. Sorry, what you mean by now u park at N gear? What should it normally be then? I always park at N leh. Link to post Share on other sites More sharing options...
Saabretooth 2nd Gear February 7, 2014 Share February 7, 2014 a lot of 159s kena this, and then 5-7 days later, battery died. Link to post Share on other sites More sharing options...
Chrispie 5th Gear February 8, 2014 Share February 8, 2014 Without your spcl note.. I have exactly the same issue...now I park at N gear Hmmm I tot it's the ss pump issue..so might not be.. If it is the pump issue, and there is not enough pressure after u open the door, you cannot even fire up the engine. I would have to plug in the key.. wait all the whining and wheeing to be over... then i can start engine. Now, i can fire engine without issue.. but gear have to stay in N until after error clears before i can gear into 1. Sorry, what you mean by now u park at N gear? What should it normally be then? I always park at N leh. by right, you have park in 1 or R as stated in manual. I always park it geared in. Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic February 8, 2014 Share February 8, 2014 Sorry, what you mean by now u park at N gear? What should it normally be then? I always park at N leh. U need to park in gear. If u park in N, the warning chime will sound when u switch off the engine. Link to post Share on other sites More sharing options...
Theredstar 2nd Gear February 8, 2014 Share February 8, 2014 U need to park in gear. If u park in N, the warning chime will sound when u switch off the engine. But any damage done ah? Just prevent rolling back rt? Does that mean red light can handbrake in gear if too long? Or only when engine is off? Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic February 8, 2014 Share February 8, 2014 But any damage done ah? Just prevent rolling back rt? Does that mean red light can handbrake in gear if too long? Or only when engine is off? I don't know if there's any damage done. I'm just following instructions and also to avoid hearing the irritating beeping sound. At red light is always good to step on brakes so that if you get hit from some bobo driver behind you will less likely hit the car in front. Link to post Share on other sites More sharing options...
Echo2623 1st Gear February 9, 2014 Share February 9, 2014 wonder if any of the SS experts can give me some direction... When: 1. At Cold start (or after parked for sometime) Observation: 1. Car starts ok. 2. Gear shifts to N without issue. 3. Gearbox error appears on dash 4. During this period, will not engage gear 5. Error clears after around 10s. 6. Gears in and whole day driving and starting without issue 99% of the time. Special note: 1. New SS pump 2. New SS accumulator. Went to Eper, tried to look up the various drawings, not too sure what could be the issue. bro i encounter similar issue too.. a few days later, my ride wouldnt even engage gear anymore.. theres this 2x O-Ring in the actuator.. due to wear, O-ring could not hold the pressure to send the 'signal' to engage/disengage clutch.. for me, it was an hour job.. cost 4 blues.. u wan can pm me for contact and I send u the pic thru watsapp.. Link to post Share on other sites More sharing options...
Torquemeister 1st Gear February 11, 2014 Share February 11, 2014 Hey Alfisti - any of you looking to fit an OEM Satnav into your 159 / Brera Sereis heres the centre console trim kit for it and at a bargain price.......... http://www.ebay.co.uk/itm/Brand-New-OEM-Aluminium-Centre-Dashboard-Trim-for-Alfa-159-Brera-Spider-939-/161222612733?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item25899dd6fd Wrong colour for me :( Link to post Share on other sites More sharing options...
Count_duku 4th Gear February 14, 2014 Share February 14, 2014 Alfa Romeo 4C on Topgear Season 21 ep2: http://www.streetfire.net/top-gear/top-gear-season-21-episode-2_part-1_2450910.htm 1 Link to post Share on other sites More sharing options...
Torquemeister 1st Gear February 15, 2014 Share February 15, 2014 Alfa Romeo 4C on Topgear Season 21 ep2: http://www.streetfire.net/top-gear/top-gear-season-21-episode-2_part-1_2450910.htm Thanks for sharing Count - no boot? Link to post Share on other sites More sharing options...
Count_duku 4th Gear February 15, 2014 Share February 15, 2014 (edited) Thanks for sharing Count - no boot? Think I saw in other reviews that there is a rear boot, just behind the engine. Other journos pitted the 4c against the cayman but these guys used a dune buggy for the challenge haha .. which is quite clever and takes the seriousness off the review. I mean the 4c reviews have been pretty bad, and Alfa fanatics are all over web trying defend the 4c. Edited February 15, 2014 by Count_duku Link to post Share on other sites More sharing options...
Torquemeister 1st Gear February 15, 2014 Share February 15, 2014 Think I saw in other reviews that there is a rear boot, just behind the engine. Other journos pitted the 4c against the cayman but these guys used a dune buggy for the challenge haha .. which is quite clever and takes the seriousness off the review. I mean the 4c reviews have been pretty bad, and Alfa fanatics are all over web trying defend the 4c. The Car review was pretty good and that is the one that matters Link to post Share on other sites More sharing options...
Chaona Clutched February 15, 2014 Share February 15, 2014 Hey Alfisti - any of you looking to fit an OEM Satnav into your 159 / Brera Sereis heres the centre console trim kit for it and at a bargain price.......... http://www.ebay.co.uk/itm/Brand-New-OEM-Aluminium-Centre-Dashboard-Trim-for-Alfa-159-Brera-Spider-939-/161222612733?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item25899dd6fd Wrong colour for me :( By any chance do you know where we can even get the OEM satnav? Link to post Share on other sites More sharing options...
T816B Clutched February 16, 2014 Share February 16, 2014 By any chance do you know where we can even get the OEM satnav? The size of the OEM satnav will not fit our non satnat dash. If you manage to find an OEM satnav, you need to purchase the dash for the OEM satnav too. ↡ Advertisement Link to post Share on other sites More sharing options...
Nissan QashQai 2014 Part 2
The 2017 Alfa Romeo Giulia
sgCarMart's Community Telegram group is now live!
