Pisces69 6th Gear October 15, 2013 Share October 15, 2013 (edited) On 10/15/2013 at 3:08 PM, winson_stalin said: Yup.. w/o aircon about 900 rpm.. With aircon drop slightly to 700? Just wondering if the range is normal? Yrs old style. Sud b able to adjust by a screw on the vacuum diaphram that boost yr carb. Otherwise its old n worn n need to replace. If u dun know how to do, ask yr mech to adjust fr u. Also ask him to chk yr vacuum tubings. So old maybe some need to change cos hard n cracked already. Normal sud b abt 850-900 when engine hot n gear in neutral. Slowly adjust till the vibrations r gone. If still vibrate at 900RPM, chk yr engine mountings. Oh n 1 more thing. If yr AC compressor going to spoil, sometimes it gets very heavy n cause RPM to drop a lot. U can chk it n also if yr AC has enough oil n gas in the system. Yrs is old gas. Dunno if u can still get in SG but JB have plenty n very cheap to top up. If yr AC long time never service, can consider to suck out all the old gas/oil n fill new in JB. Edited October 15, 2013 by Pisces69 ↡ Advertisement Link to post Share on other sites More sharing options...
winson_stalin Neutral Newbie October 16, 2013 Share October 16, 2013 Tks bro! On 10/15/2013 at 3:17 PM, Pisces69 said: Yrs old style. Sud b able to adjust by a screw on the vacuum diaphram that boost yr carb. Otherwise its old n worn n need to replace. If u dun know how to do, ask yr mech to adjust fr u. Also ask him to chk yr vacuum tubings. So old maybe some need to change cos hard n cracked already. Normal sud b abt 850-900 when engine hot n gear in neutral. Slowly adjust till the vibrations r gone. If still vibrate at 900RPM, chk yr engine mountings. Oh n 1 more thing. If yr AC compressor going to spoil, sometimes it gets very heavy n cause RPM to drop a lot. U can chk it n also if yr AC has enough oil n gas in the system. Yrs is old gas. Dunno if u can still get in SG but JB have plenty n very cheap to top up. If yr AC long time never service, can consider to suck out all the old gas/oil n fill new in JB. Link to post Share on other sites More sharing options...
winson_stalin Neutral Newbie November 9, 2013 Share November 9, 2013 Tink i finally found out why can feel vibration liao! Spark plug wire worn... nw I using duct tape to tahan... Anyone know if this is ok till next servicing? Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 9, 2013 Share November 9, 2013 On 11/9/2013 at 2:33 AM, winson_stalin said: Tink i finally found out why can feel vibration liao! Spark plug wire worn... nw I using duct tape to tahan... Anyone know if this is ok till next servicing? Better to change all the wires. U wil feel the difference. More power n car smoother. Better FC too. I prefer to stick to original or OEM wires. Some of those "performance" silicon wires r all BS. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 10, 2013 Share November 10, 2013 On 11/9/2013 at 2:33 AM, winson_stalin said: Tink i finally found out why can feel vibration liao! Spark plug wire worn... nw I using duct tape to tahan... Anyone know if this is ok till next servicing? bro better get it replace. duct tape wont not solve the problem. and more over duct tape cannot without high engine heat. do it the proper way. dont wait for your next servicing. Avoid hassle of having more breakdown problem. Link to post Share on other sites More sharing options...
Jerichol 2nd Gear November 10, 2013 Share November 10, 2013 (edited) Listen to the others, quick/temporary fix never solve problems. Then again...for older car....fix one problem and another will surface. It has to do with a better/stronger part stressing a weaker/older connected part. For example, an old air-con compressor clutch can refurbish but will the compressor take it over time? So the question is .... refurbish or change the whole assembly? That is why if you go agent, they usually change all the connected parts and usually they do not re-furbish thus people tend to find them expensive and sometime consider the replacement either over-kill or not necessary. Edited November 10, 2013 by Jerichol Link to post Share on other sites More sharing options...
winson_stalin Neutral Newbie November 10, 2013 Share November 10, 2013 Thks.. Will go tye soon or pas tmr to get 4 replacement plug wire.. Anyone know if they are costly? Currently using bosch plug.. Link to post Share on other sites More sharing options...
Clkken Neutral Newbie November 10, 2013 Share November 10, 2013 On 9/24/2013 at 11:47 AM, D4rkFly3r said: Hi guys, just wondering how did you solve your vibration on idle problem despite having changed the engine mountings. The vibration lessen alot but the vibration is still there especially when AC is on. I noticed it only happen when i am on Drive mode. Help and advises would be greatly appreciated. Hi, I'm having the same problem with my Harrier as well. I have changed many parts but the vibration still there. Parts that have been replaced were; Engine Mounting full set Spark plugs Air filter Plug coil ECU check and reset TB serviced I'm going to check on my A/C now, hope I can solve it. Will update you. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 10, 2013 Share November 10, 2013 On 11/10/2013 at 4:22 AM, Clkken said: Hi, I'm having the same problem with my Harrier as well. I have changed many parts but the vibration still there. Parts that have been replaced were; Engine Mounting full set Spark plugs Air filter Plug coil ECU check and reset TB serviced I'm going to check on my A/C now, hope I can solve it. Will update you. If its yr AC compressor, just switch it on n off n see if the vibrations come n go. If the vibrations r there when the AC is on or off, then its not the AC problem. Also chk yr RPM when u switch the AC on n off. The RPM sud b stable n remain the same. Hv u chk yr plug wires? Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 10, 2013 Share November 10, 2013 On 11/10/2013 at 4:08 AM, winson_stalin said: Thks.. Will go tye soon or pas tmr to get 4 replacement plug wire.. Anyone know if they are costly? Currently using bosch plug.. Just stick to original or OEM plug leads. Some aftermarket hv wrong resistance n wil affect performance. Sorry but I dun know the price. U sud call them n chk if theirs is Original/OEM n the price to compare which shop has better prices. On 11/10/2013 at 1:43 PM, Pisces69 said: If its yr AC compressor, just switch it on n off n see if the vibrations come n go. If the vibrations r there when the AC is on or off, then its not the AC problem. Also chk yr RPM when u switch the AC on n off. The RPM sud b stable n remain the same. Hv u chk yr plug wires? Another thing u can chk if still cannot solve. Maybe yr ECU hv some wrong readings. U can re-set to factory settings by disconnect the + battery terminal wire for a couple of hours n see if it helps when the ECU goes back to factory settings. Link to post Share on other sites More sharing options...
Clkken Neutral Newbie November 19, 2013 Share November 19, 2013 On 11/10/2013 at 1:51 PM, Pisces69 said: Just stick to original or OEM plug leads. Some aftermarket hv wrong resistance n wil affect performance. Sorry but I dun know the price. U sud call them n chk if theirs is Original/OEM n the price to compare which shop has better prices. Another thing u can chk if still cannot solve. Maybe yr ECU hv some wrong readings. U can re-set to factory settings by disconnect the + battery terminal wire for a couple of hours n see if it helps when the ECU goes back to factory settings. Hi Pisces69, Thank you for your advice, After replaced 4 plugs coil, it seen better and more stable. I'm not sure should I proceed to check on my A/C compressor. Still have a little vibrate will the A/C running. I have not reset the ECU. Should I do a reset on the ECU first before further diagnose ? Clkken Link to post Share on other sites More sharing options...
D4rkFly3r Neutral Newbie November 19, 2013 Author Share November 19, 2013 On 11/19/2013 at 1:30 AM, Clkken said: Hi Pisces69, Thank you for your advice, After replaced 4 plugs coil, it seen better and more stable. I'm not sure should I proceed to check on my A/C compressor. Still have a little vibrate will the A/C running. I have not reset the ECU. Should I do a reset on the ECU first before further diagnose ? Clkken Hi, just checking how much you changed your ignition coil? Thanks. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 19, 2013 Share November 19, 2013 On 11/19/2013 at 1:30 AM, Clkken said: Hi Pisces69, Thank you for your advice, After replaced 4 plugs coil, it seen better and more stable. I'm not sure should I proceed to check on my A/C compressor. Still have a little vibrate will the A/C running. I have not reset the ECU. Should I do a reset on the ECU first before further diagnose ? Clkken U can do a soft re-set of yr ECU first n see if there is an improvement. Now yr vibrations r almost gone so maybe the ECU re-set might eliminate it altogether. Otherwise u need to chk yr AC compressor if it has any problems. U can send to Markcool n see Ah Huat for checking. Sometimes some AC ws wil overfill the gas which put a heavy load on the compressor n cause vibrations when it comes on. Ah Huat can check these for u n advise u if any repairs r needed. Link to post Share on other sites More sharing options...
Clkken Neutral Newbie November 20, 2013 Share November 20, 2013 On 11/19/2013 at 1:04 PM, D4rkFly3r said: Hi, just checking how much you changed your ignition coil? Thanks. PM you... On 11/19/2013 at 1:44 PM, Pisces69 said: U can do a soft re-set of yr ECU first n see if there is an improvement. Now yr vibrations r almost gone so maybe the ECU re-set might eliminate it altogether. Otherwise u need to chk yr AC compressor if it has any problems. U can send to Markcool n see Ah Huat for checking. Sometimes some AC ws wil overfill the gas which put a heavy load on the compressor n cause vibrations when it comes on. Ah Huat can check these for u n advise u if any repairs r needed. Thank you for your advice. Will update you once I do the reset. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 20, 2013 Share November 20, 2013 On 11/20/2013 at 2:47 AM, Clkken said: Thank you for your advice. Will update you once I do the reset. OK good luck. Link to post Share on other sites More sharing options...
Clkken Neutral Newbie June 17, 2014 Share June 17, 2014 Hi Pisces69, Finally, solved my car idle problem. It due to the after market battery voltage regulator. So happy now. Thank you for your advice. Clkken Link to post Share on other sites More sharing options...
QQDreamer 4th Gear June 23, 2014 Share June 23, 2014 On 6/17/2014 at 1:50 PM, Clkken said: Hi Pisces69, Finally, solved my car idle problem. It due to the after market battery voltage regulator. So happy now. Thank you for your advice. Clkken wah you spend so much but in the end is just the voltage regulator problem. but guess no choice. Link to post Share on other sites More sharing options...
Hamburger Hypersonic June 23, 2014 Share June 23, 2014 Finally, solved my car idle problem. It due to the after market battery voltage regulator. So happy now. Thank you for your advice. as in those capacitors in blue colour boxes??? ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
Discussion on Gout problem
HDB season parking renewal problem
Singapore Problem Gambling
