Alternator fail
Tcx607
My alternator read as marginal according to my mech. Can i know is it ok to change the alternator when it read marginal?
better change to have a peace of mind. else you wouldnt know when it will fail you,
My car battery died yesterday, and I went to Autobacs to replace the battery.   In the end, they told me that my alternator is not working and needs to be replaced.   The quotation is quite high and out of my expectations, it is around 1160S$ including labor charges.   But I feel they are not honest and would like to seek advice in this forum.
And here are some excerpt of the data.
Battery Test (the brand new replaced battery)
Volts: 12.99V
Measured 483 CCA
Rating: 405CCA
Starter Test
Cranking Normal
Cranking 11.39V
Time 0.74S
Charging test:
Low output
No Load : 13.72V
Loaded : 12.93V
In case of this, Do I need to replace the alternator?  If I don't, what will happen to my car?  Any safety issue?
Thanks
Edited by Lengzq
Its a Sunday, must expect Sunday price mah. Just go to a stockist buy and go to your regular mech.
You might also want to get a 2nd opinion. I just do not trust Autobacs or Spark etc
Edited by Othello
  • Praise 2
I see othi g wrong with your alternator.
Charging test says it all.
Sorry to ask it more because I am a familiar about this.
First, my car has to be deregistrated within next 2.5 years ( It is an old car and renewed 5 years COE, there only have 2.5 years remains).
2nd, based on this situation, Is it necessary to repair the alternator?   Is the alternator doesn't charge the batter at all OR it is still charging the battery but not strong enough and this may reduce the battery life?   If it is charging the battery but without enough charging, how long for a new batter can last in such condition?     I would like to estimate which is more valuable for me.
Thanks.
Supersonic
Volts: 12.99V
Measured 483 CCA
Rating: 405CCA
Starter Test
Cranking Normal
Cranking 11.39V
Time 0.74S
Charging test:
Low output
No Load : 13.72V
Loaded : 12.93V
Thanks
no safety issue till your new battery gives up and the car stalls.
1160 is crazily expensive for an alternator.
Thanks.
Thanks.
90% of the time.
if your alternator fail. a red battery sign will light up when your car is running
most jap car alternator can be repair, about 300-400
(did u say wat car u driving??)
korea car mostly replace new parts, cos new alternator also abut 400+- only
(for most korea model)
Supersonic
Thanks.
Loaded : 12.93V
Yes, the alternator need to be fixed. It is barely charging the battery.
Over the long term, the battery will go flat, and it won't turn over the engine.
Find a w/s to repair or replaced with a re-con one.
I am driving a toyota altis.
Thanks for all your reply,  it helps a lot.
Edited by Lengzq
one of my friend kana $24** for his alternator after his kapoot on chinese new yrs eve! The shop's chopper very sharp and heavy.
WAhahaha
8years old altis they tell u 1k over for alternator.
u tell them their parang very sharp [knife]
