Acewin 4th Gear May 13, 2019 Share May 13, 2019 Yep I will. Lucky my workshop just above Kenny alignment. Thanks. Mcf here is info or knowledge sharing. You are always welcome, ↡ Advertisement Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 14, 2019 Share May 14, 2019 Mcf here is info or knowledge sharing. You are always welcome, Yah man, thanks bro. The rear got nothing to change? Just the shock absorbers I guess? Link to post Share on other sites More sharing options...
Ichibawa 5th Gear May 14, 2019 Share May 14, 2019 Yah man, thanks bro. The rear got nothing to change? Just the shock absorbers I guess? It depends on your car type. Some cars will have 16 control arms/links or another macpherson struts setup while others have just a simple torsion beam with small shock absorbers. Best person to advise is yourself the driver to confirm if there are any irregular noise or movement from the rear. 1 Link to post Share on other sites More sharing options...
Wallaw819 4th Gear May 14, 2019 Share May 14, 2019 Yah man, thanks bro. The rear got nothing to change? Just the shock absorbers I guess? Maybe if you advise your car model then some experts will advise as too many type of rear suspension system. However most of them will have some bushings that can be changed, just how many. 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 14, 2019 Share May 14, 2019 Mine’s just a Swift so seems to be torsion beam with shock absorbers. Changed that and the bushings 2 years back. Thanks. Link to post Share on other sites More sharing options...
JayDazzler Neutral Newbie September 2, 2020 Share September 2, 2020 Can recommend the workshop? So far for my mitsubishi suv... 9.5years liao and i need suspension change and engine mounting for next renewal of life. Price between 1.8k to 2.5k++ Wondering if the usual rates are lower using ori/oem parts. Link to post Share on other sites More sharing options...
Volvobrick Hypersonic September 2, 2020 Share September 2, 2020 3 hours ago, JayDazzler said: Can recommend the workshop? So far for my mitsubishi suv... 9.5years liao and i need suspension change and engine mounting for next renewal of life. Price between 1.8k to 2.5k++ Wondering if the usual rates are lower using ori/oem parts. mitsubishi parts so expensive meh? Renew, cross 10 year mark, than replace. You never know may anything can happen in the 6 months. Link to post Share on other sites More sharing options...
Albeniz Turbocharged February 8, 2021 Share February 8, 2021 For lower arms, would OEM parts be good enough? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic February 8, 2021 Share February 8, 2021 (edited) 2 hours ago, Albeniz said: For lower arms, would OEM parts be good enough? I would stick to original. Price difference a lot? Check with a few Nissan stockist bro. Edited February 8, 2021 by Fcw75 3 Link to post Share on other sites More sharing options...
Kklim Supercharged September 2, 2022 Share September 2, 2022 Changing front absorbers: other than absorber, bump stop, and absorber mounting, is there a need to change the absorber mounting bearing? Link to post Share on other sites More sharing options...
Volvobrick Hypersonic September 2, 2022 Share September 2, 2022 10 minutes ago, Kklim said: Changing front absorbers: other than absorber, bump stop, and absorber mounting, is there a need to change the absorber mounting bearing? If no funny noise no need lah! Link to post Share on other sites More sharing options...
Mkl22 Supersonic September 2, 2022 Share September 2, 2022 (edited) 27 minutes ago, Kklim said: Changing front absorbers: other than absorber, bump stop, and absorber mounting, is there a need to change the absorber mounting bearing? Depends on how old. I would one time replace everything. I have learnt my lesson with toyota Markx when the workshop claimed the top mount looked ok and didn’t replace it. was plagued with knocking noises for the longest time. @Vratenza would attest to the same crap he endured. the old suspension was worn but no knocking. Edited September 2, 2022 by Mkl22 Link to post Share on other sites More sharing options...
Kklim Supercharged September 2, 2022 Share September 2, 2022 14 minutes ago, Volvobrick said: If no funny noise no need lah! Thanks! There are so many funny sounds I can't figure out which is from where 😆 13-year-old car. Just changed top engine mounts and car is now quieter. 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic September 2, 2022 Share September 2, 2022 3 minutes ago, Kklim said: Thanks! There are so many funny sounds I can't figure out which is from where 😆 13-year-old car. Just changed top engine mounts and car is now quieter. I also plan to replace the lower arms soon. Bushings all cracked. Link to post Share on other sites More sharing options...
Kklim Supercharged September 13, 2022 Share September 13, 2022 (edited) On 9/2/2022 at 2:50 PM, Kklim said: Thanks! There are so many funny sounds I can't figure out which is from where 😆 13-year-old car. Just changed top engine mounts and car is now quieter. Loudest sound (tok tok tok when staring up, softer when moving) turned out to be from air filter housing hitting firewall coz bushes had hardened or broken off. Had them replaced and quiet now. Also changed front absorbers and other suspension parts so only hear road and tyre sounds now 👍 Edited September 13, 2022 by Kklim 1 Link to post Share on other sites More sharing options...
N00b 4th Gear September 21, 2022 Share September 21, 2022 was told my 2015 Kia K3 front bushings cracked. was quoted $540 incl labour to change both sides. anybody know if this is a reasonable price? any place to recommend to bring own parts and pay for labour? Link to post Share on other sites More sharing options...
Kklim Supercharged September 21, 2022 Share September 21, 2022 12 minutes ago, N00b said: was told my 2015 Kia K3 front bushings cracked. was quoted $540 incl labour to change both sides. anybody know if this is a reasonable price? any place to recommend to bring own parts and pay for labour? Check part prices here: https://www.fitinpart.sg/ $540 quote: I just changed practically all the front suspension parts (incl absorbers) for about this amount in Malaysia (not JB). Link to post Share on other sites More sharing options...
N00b 4th Gear September 21, 2022 Share September 21, 2022 @Kklim anyway we can find out the exact part needed for the front arm? according to the person in the workshop, there are 3 parts? ↡ Advertisement Link to post Share on other sites More sharing options...
ACG Performance - Official Distributor For Brembo, AirBFT Air Suspensions & GFG Forged Wheels!
Questions about Toyota Mark X
Washing machine front loading
Car inspection questions
Top 5 questions to ask every used car dealer
Questions about Gearbox overhaul
