Mrpega Neutral Newbie August 15, 2013 Share August 15, 2013 (edited) Hi all, I heard some ticking sound when the car is moving and it got more intense when the car is moving faster. What could be the problem? I'm goin to change engine oil soon so I need to prep myself not to get tock by the ws. Mileage:90k Age: 8 year old Changed the dunno cv joint or cap or something before 1 year ago. Thanks Edited August 15, 2013 by Mrpega ↡ Advertisement Link to post Share on other sites More sharing options...
ProStreetDriver Clutched September 4, 2013 Share September 4, 2013 Could be a stone stuck in the tire. Is your car front wheel drive or rear wheel drive??? Might be the other cv joint or a uv joint. Link to post Share on other sites More sharing options...
Kurty Supercharged September 4, 2013 Share September 4, 2013 one side or both side? likelihood to be wheel bearing.. mine also got this problem.. even worst.. got metal hitting sound.. found out that i actually left a spanner in the hood, remove but the sound still remain.. going service centre this sat Link to post Share on other sites More sharing options...
Gohchaip Neutral Newbie September 4, 2013 Share September 4, 2013 i had the same issue.......it was tracked down to a piece of metal stuck in my tyre groove, luckily no puncture yet cos' discover early by agent when i complain during regular servicing. Does the freq increase with speed, almost no sound when u are rolling.....and comes only from one side of the car.....more audible during high speed. could be it.... Link to post Share on other sites More sharing options...
Rubywinniesmurf Neutral Newbie September 9, 2013 Share September 9, 2013 I got the different experience. My tyre kena a huge nail just the other day. Didn't know which tyre till the next morning Link to post Share on other sites More sharing options...
KouLouYok Clutched December 7, 2013 Share December 7, 2013 Hi guys, im driving a Getz. Recently, upon travelling above 60km/h, there would be a fast tick tick sound. It seems to be coming from the driver side. I have checked and confirmed that my tyres are ok (new by the way), and I actually just serviced my car only. Any bros able to give some possible causes? Thanks a lot! Link to post Share on other sites More sharing options...
MyCarGuru December 7, 2013 Share December 7, 2013 Clicking sound while driving could also be a worn drive shaft. As they get old the splines no longer fit snugly into the transmission and hence the clicking. This will be especially loud on full steering lock. Link to post Share on other sites More sharing options...
Pisces69 6th Gear December 7, 2013 Share December 7, 2013 Clicking sound while driving could also be a worn drive shaft. As they get old the splines no longer fit snugly into the transmission and hence the clicking. This will be especially loud on full steering lock. U sure or not. Link to post Share on other sites More sharing options...
Jtb 6th Gear December 8, 2013 Share December 8, 2013 Check little chip stone get inside the rim cover at certain angle Link to post Share on other sites More sharing options...
MyCarGuru December 14, 2013 Share December 14, 2013 U sure or not. Yes I had this once, and my car was 5 years old. Believe or not up to you. 1 Link to post Share on other sites More sharing options...
Pisces69 6th Gear December 14, 2013 Share December 14, 2013 Yes I had this once, and my car was 5 years old. Believe or not up to you. Driveshaft sud wear out at the CV joint. How come even the splines can wear? Means the power from the gearbox is not being transfered to the driveshaft n car cannot move at all. 1st time I hear the splines can wear out. Unless the mech damaged them when he remove then replace the driveshaft. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Feb 2025
COE Bidding - January 2025
2024 Suzuki Swift
2024 Suzuki Swift
COE Bidding - December 2024
Used Car, what STA Inspection grade then can buy?
