Zakkwylde 5th Gear July 29, 2013 Share July 29, 2013 stick to stock will do. But, perform some basic measures to ensure longer batt life including powering down electronic devices when arriving your carpark, off radio, satnav, aircon before reaching home. I will ensure everytime the car is parked, I would switch off the aircon and also the head unit. If I don't off it, the sudden power surge could damage my electronic equipment in the long run. ↡ Advertisement Link to post Share on other sites More sharing options...
Kb27 Supersonic July 29, 2013 Share July 29, 2013 is there an aftermarket alternator in the market? Alternator must fit your car in terms of mountings/space available/drive belt type/length, and some wiring connections. They are usually sold as oem fit. If you want to modify and drop in a bigger alternator, you need to find a workshop willing to do the mix and match work. Link to post Share on other sites More sharing options...
Zakkwylde 5th Gear July 29, 2013 Share July 29, 2013 Alternator must fit your car in terms of mountings/space available/drive belt type/length, and some wiring connections. They are usually sold as oem fit. If you want to modify and drop in a bigger alternator, you need to find a workshop willing to do the mix and match work. SO would that be a recon set or brand new? Any cons to using a bigger alternator for your car? Link to post Share on other sites More sharing options...
Kb27 Supersonic July 29, 2013 Share July 29, 2013 SO would that be a recon set or brand new? Any cons to using a bigger alternator for your car? Doesn't matter if recon or new, it must fit your car. A workshop can also fabricate mounting bars to accommodate different alternator, but mounting must fit into the tight space available. Con would probably be higher fuel consumption. Some people also play with pulley size to spin faster or slower. However, it will not change the alternator capability since the components are rated to produce that much power only. Link to post Share on other sites More sharing options...
Zapp 1st Gear July 29, 2013 Share July 29, 2013 ECU, Alarm, ERP unit & Head unit are drawing current. Link to post Share on other sites More sharing options...
Joemit7850 1st Gear July 29, 2013 Author Share July 29, 2013 thanks everyone for your advise. Amaron is correct , I didn't buy from Amazon... went to my previous ICE installer and they found out is my power pack for my car camera are not working, he change to a new set , guess this should solve the problem for time being.... Link to post Share on other sites More sharing options...
Gdspd08 2nd Gear July 29, 2013 Share July 29, 2013 (edited) its only a vios. nothing to be proud of Yup, you are right. Nothing to be proud of. Just that small car that pack so many gadget. Just that I now also start to worry how long my alternator can last. This thread had at least wake me up. Better monitor my battery and alternator. Edited July 29, 2013 by Gdspd08 Link to post Share on other sites More sharing options...
Forte3737 5th Gear July 30, 2013 Share July 30, 2013 Yup, you are right. Nothing to be proud of. Just that small car that pack so many gadget. Just that I now also start to worry how long my alternator can last. This thread had at least wake me up. Better monitor my battery and alternator. perhaps you are tyring to show off or what? but a vios is just an entry level car in the toyota range. Link to post Share on other sites More sharing options...
Columbian78 6th Gear July 30, 2013 Share July 30, 2013 I think the reason why many forumers feel Gdspd08 is showing off is because he tried to list as many things he has added to his vehicle, to the extent that he even listed those things that are not electrical and not relevant to the title of this thread. Fire extinguisher draw current? But it's ok, it's interesting, just my observation. Link to post Share on other sites More sharing options...
Gdspd08 2nd Gear July 30, 2013 Share July 30, 2013 (edited) I think the reason why many forumers feel Gdspd08 is showing off is because he tried to list as many things he has added to his vehicle, to the extent that he even listed those things that are not electrical and not relevant to the title of this thread. Fire extinguisher draw current? But it's ok, it's interesting, just my observation. Wah liew..I cut and paste this whole thing without checking those unrelated stuff. Very sorry. Anyway, good to standby those stuff for emergency. Next time I will check properly before I post. Sorry for inconvenience cause. Just want to share something that I have installed and yet still voltage and current quite stable. If really that bad, I will delete my thread off. Once again, my sincere apologies. Edited July 30, 2013 by Gdspd08 Link to post Share on other sites More sharing options...
Columbian78 6th Gear July 30, 2013 Share July 30, 2013 (edited) Wah liew..I cut and paste this whole thing without checking those unrelated stuff. Very sorry. Anyway, good to standby those stuff for emergency. Next time I will check properly before I post. Sorry for inconvenience cause. Just want to share something that I have installed and yet still voltage and current quite stable. If really that bad, I will delete my thread off. Once again, my sincere apologies. Very nice of you to offer your sincerest apologies. I didn't think you were showing off but i observed and tried to explain why you were perceived as such. I usually use the preview function to review my postings before submit. Only the moderator can delete the thread. Furthermore you are not the thread starter, you shouldn't delete it. You cannot even edit or delete your old posts. Or the more to exercise responsible postings. Edited July 30, 2013 by Columbian78 Link to post Share on other sites More sharing options...
TVT Supercharged July 30, 2013 Share July 30, 2013 Wah liew..I cut and paste this whole thing without checking those unrelated stuff. Very sorry. Anyway, good to standby those stuff for emergency. Next time I will check properly before I post. Sorry for inconvenience cause. Just want to share something that I have installed and yet still voltage and current quite stable. If really that bad, I will delete my thread off. Once again, my sincere apologies. Its OK lah...no need to delete. People can say what they want but if you conscience is clear then no worries. Anyway, its good of you to share info to us. Link to post Share on other sites More sharing options...
TVT Supercharged July 30, 2013 Share July 30, 2013 ECU, Alarm, ERP unit & Head unit are drawing current. How come Head unit is drawing current if it is off ? Cash card just take it out and the ERP unit won't draw current liao. Link to post Share on other sites More sharing options...
winson_stalin Neutral Newbie November 18, 2013 Share November 18, 2013 Hi guys.. anyone know if faulty car lock (i.e. car key inserted at driver door, but other doors do not open automatically and has to open manually) will cause battery to short circuit? Thks Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged November 18, 2013 Share November 18, 2013 Hi guys.. anyone know if faulty car lock (i.e. car key inserted at driver door, but other doors do not open automatically and has to open manually) will cause battery to short circuit? Thks don't think so. Link to post Share on other sites More sharing options...
Cerberus Neutral Newbie September 22, 2015 Share September 22, 2015 Sorry to revive an old topic but anyone knows of any workshop in sg that can perform a parasitic drain test? Link to post Share on other sites More sharing options...
Kklee 6th Gear September 24, 2015 Share September 24, 2015 Sorry to revive an old topic but anyone knows of any workshop in sg that can perform a parasitic drain test? If test only, can use a current clamp. I have one. Can explore to let you use for on the stop test. PM me. 1 Link to post Share on other sites More sharing options...
JamesHarry Neutral Newbie September 30, 2015 Share September 30, 2015 It is better that you should get it checked from company person, who will guide you in the right direction. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Mar 2025
Car of Politician
Car of Politician
Anyone missing a car plate?
Battery for Honda Vezel
