D3v1LmAn69 2nd Gear February 19, 2017 Share February 19, 2017 I did full ice setup. Yes door speakers is 6.5". After market speakers will not fit, need to custom wooden frame spacer if not window glass when rolled down will hit the speakers magnet. By the way I have a set of Focal K2 Power 2-way to let go. Thank you for reply :). Currently my ride is an Avante 2009 having front component speakers connected to 4-ch amp. Used to the good sound quality so thought of also switching to component if I replace Avante with K3. Measured the speaker bottom depth to be 5cm is still ok for Avante though. As you said K3 could be shallower. If K3 default sound is acceptable then I don't need to upgrade. Multi, thanks for reply too. i think most stock speakers are bolted to the speaker holder such that if need to replace, may have to cut through or even saw through the metal holders, ==> permanently destroy stock speakers. Speaker holder is retained to mount new speakers. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Yongtuck Clutched February 19, 2017 Share February 19, 2017 It is possible but very tedious since there's a need to add in more modules to make auto climate control work. Came across this guy who converted his 2nd-gen Honda Fit (Jazz) from manual to auto climate control, process looks really long. http://www.fitfreak.net/forums/2nd-generation-ge8-specific-diy-repair-maintenance-sub-forum/78713-diy-automatic-climate-control-conversion.html For someone looking at Cerato K3 and really want climate control, bite bullet and get SX or check if it is possible to add this feature into the lower EX / L trims at an extra cost. Link to post Share on other sites More sharing options...
Vinceng Turbocharged February 19, 2017 Share February 19, 2017 Thank you for reply :). Currently my ride is an Avante 2009 having front component speakers connected to 4-ch amp. Used to the good sound quality so thought of also switching to component if I replace Avante with K3. Measured the speaker bottom depth to be 5cm is still ok for Avante though. As you said K3 could be shallower. If K3 default sound is acceptable then I don't need to upgrade. Multi, thanks for reply too. i think most stock speakers are bolted to the speaker holder such that if need to replace, may have to cut through or even saw through the metal holders, ==> permanently destroy stock speakers. Speaker holder is retained to mount new speakers. The Kia Cerato Forte K3 uses the same Gamma engine as the 2009 Hyundai Elantra Link to post Share on other sites More sharing options...
coolbluepica 2nd Gear February 19, 2017 Share February 19, 2017 Thank you for reply :). Currently my ride is an Avante 2009 having front component speakers connected to 4-ch amp. Used to the good sound quality so thought of also switching to component if I replace Avante with K3. Measured the speaker bottom depth to be 5cm is still ok for Avante though. As you said K3 could be shallower. If K3 default sound is acceptable then I don't need to upgrade. Multi, thanks for reply too. i think most stock speakers are bolted to the speaker holder such that if need to replace, may have to cut through or even saw through the metal holders, ==> permanently destroy stock speakers. Speaker holder is retained to mount new speakers. Can destroy stock speaker to use the holder. But I'm into sq so using a customized wooden spacer for sound absorption as the stock one is plastic. My speakers can't fit the stock holder too. Link to post Share on other sites More sharing options...
13177 Hypersonic February 20, 2017 Share February 20, 2017 My take is it is better to go for EX or SX if you are going to spend a considerable amount of money for upgrades. At least these accessories and features come stock from the factory and are covered under the 5 year warranty. If these after market electric accessories are not properly fitted, may cause a short circuit and cause the car to catch fire. Agreed, if the buyer plans to spend money to upgrade the LX version, might as well take the EX or SX. LX version is quite worth to buy if you do not plan to spend any extra money on upgrades. Link to post Share on other sites More sharing options...
Multi 3rd Gear February 20, 2017 Share February 20, 2017 The Kia Cerato Forte K3 uses the same Gamma engine as the 2009 Hyundai ElantraI think 2009 Gamma engine is single cvvt whereas the later version is double cvvt. Link to post Share on other sites More sharing options...
Vinceng Turbocharged February 20, 2017 Share February 20, 2017 I think 2009 Gamma engine is single cvvt whereas the later version is double cvvt. Is the double CVVT similar in concept as Toyota's Dual VVT-i technology ? 1 Link to post Share on other sites More sharing options...
Matrix0405 5th Gear February 20, 2017 Share February 20, 2017 Agreed, if the buyer plans to spend money to upgrade the LX version, might as well take the EX or SX. LX version is quite worth to buy if you do not plan to spend any extra money on upgrades. LX got keyless start and start-stop engine? 1 Link to post Share on other sites More sharing options...
Multi 3rd Gear February 20, 2017 Share February 20, 2017 Is the double CVVT similar in concept as Toyota's Dual VVT-i technology ?Yes should be the same as almost every car manufacturers uses this feature. I think it's BMW first created this call Vano. Started with single then double. Different manufacturers will name them differently but principal the same. 2 Link to post Share on other sites More sharing options...
MrTehTarik Clutched February 20, 2017 Share February 20, 2017 Haha. My SE really give me those rubber carpet. The cloth floor mat should be stock de. I also have that. Lol. But I throw it to my boot liao. I got the 3D max spider mat, requested from SE to give me 3M trunk mat too. 1 Link to post Share on other sites More sharing options...
13177 Hypersonic February 20, 2017 Share February 20, 2017 LX got keyless start and start-stop engine? Dont think LX have. Think even EX also dont have keyless start. 1 Link to post Share on other sites More sharing options...
Multi 3rd Gear February 20, 2017 Share February 20, 2017 Dont think LX have. Think even EX also dont have keyless start.EX got keyless entry which mean press remote to unlock door but no keyless start as it is using key to start. Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear February 21, 2017 Share February 21, 2017 Any bros changed the original HID 4300K bulb before? I'm trying to change to 6000k, but was told is D8S bulb which is hard to find. Any bros got lobang for this 6000k D8S bulb that you changed before? Thanks! 1 Link to post Share on other sites More sharing options...
coolbluepica 2nd Gear February 21, 2017 Share February 21, 2017 Any bros changed the original HID 4300K bulb before? I'm trying to change to 6000k, but was told is D8S bulb which is hard to find. Any bros got lobang for this 6000k D8S bulb that you changed before? Thanks!Just change the whole set. I'm using osram hid 6000K. Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear February 21, 2017 Share February 21, 2017 Just change the whole set. I'm using osram hid 6000K.Thanks, but going to keep to stock as much as possible. Changing the bulb only not so ex too. Link to post Share on other sites More sharing options...
coolbluepica 2nd Gear February 21, 2017 Share February 21, 2017 Thanks, but going to keep to stock as much as possible. Changing the bulb only not so ex too.HID bulb will not work on your car as you don't have the ballast 1 Link to post Share on other sites More sharing options...
Mllcg 3rd Gear February 21, 2017 Share February 21, 2017 Anyone here rented the 2016 K3 from uber before? are they using the EX or SX? 1 Link to post Share on other sites More sharing options...
Multi 3rd Gear February 21, 2017 Share February 21, 2017 Anyone here rented the 2016 K3 from uber before? are they using the EX or SX?My guess is EX cause it's cheaper ↡ Advertisement Link to post Share on other sites More sharing options...
Mercedes Owners Thread
KIA EV5
KIA EV5
Radiator Cap
Radiator Cap
2025 Kia EV3
2025 Kia EV3
KIA FY24 Carnival - Hybrid
W212 owners, please check-in
