Opel17 6th Gear July 21, 2013 Share July 21, 2013 Saab is indeed different. Check after 3 mins you stopped the car. if its cold when you do the checking, its unreadable with oil all over the marking Usually, we need to wipe the dipstick before insert again, then remove to read the level marking. ↡ Advertisement Link to post Share on other sites More sharing options...
TVT Supercharged July 21, 2013 Share July 21, 2013 Here's an old thread about EO - some bros say a bit overfill is OK, some say only up to max... http://www.mycarforum.com/index.php?showto...672283&st=0 My car's engine capacity is slightly less than 4 ltrs, but my mech pour in every drop in a 4 ltr EO, and the dipstick reaches MAX level. But I understand overtime the engine will "eat" EO so I didn't bother to drain it out to 3/4 level.... Link to post Share on other sites More sharing options...
TVT Supercharged July 21, 2013 Share July 21, 2013 if the workshop really over filled for you,go back and make noise and ask them to drain out the excess foc last time when i found out,i went back and they took it out Yes, exactly. Go back to that WS and demand they drain out the excess oil. Link to post Share on other sites More sharing options...
TVT Supercharged July 21, 2013 Share July 21, 2013 So which is correct way to check engine oil dipstick level...cold overnight or warm ??? Cold overnight should be the best reading. Warm is OK too, but must take out, wipe with cloth clean clean then reinsert to get the reading. I've tried both ways before, and both results are not much difference. Only difference is cold reading is clearer and easier to see the level. Link to post Share on other sites More sharing options...
Stanchiam 1st Gear July 22, 2013 Share July 22, 2013 take a look at this, i diy with free or left over stuff https://picasaweb.google.com/10143873464241...omeMadePumpDIY# Link to post Share on other sites More sharing options...
TVT Supercharged July 22, 2013 Share July 22, 2013 take a look at this, i diy with free or left over stuff https://picasaweb.google.com/10143873464241...omeMadePumpDIY# Thanks for sharing. Now I got a better picture of how the DIY can be done, with the shampoo bottle and fish tank tube! Link to post Share on other sites More sharing options...
Ming99 1st Gear July 22, 2013 Share July 22, 2013 Too much Engine oil, At most, you damage the oil seals, destroy conrod / crankshaft bearing nia, change engine only mah ....no big deal...beri beri cheap lah. So don't worry too much. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 25, 2013 Share July 25, 2013 This link/video will give you a better idea. It's not cheap to support one's hobby http://www.mycarforum.com/index.php?s=&...t&p=4938079 Link to post Share on other sites More sharing options...
KristinLee Neutral Newbie July 25, 2013 Share July 25, 2013 Some people use special tools some only use host to extract the those oil.In Finland country many of driver are ready to different kind of mechanical stuff which is amazing because every driver has their own complete s Link to post Share on other sites More sharing options...
Acemundo Supercharged July 25, 2013 Share July 25, 2013 (edited) Best get the WS to drain some out. just curious. my car manual state 6 litres. when the workshop used the dipstick to check they say 5 litres is enough. am i right to say most likely 5 litre is the minimum and 6 litre is the maximum? i see the dipstick has 2 markings. Edited July 25, 2013 by Acemundo Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 25, 2013 Share July 25, 2013 Your mech should ran the engine, one litre will end up in the filter Link to post Share on other sites More sharing options...
Acemundo Supercharged July 25, 2013 Share July 25, 2013 Your mech should ran the engine, one litre will end up in the filter oh, so means 6 litre is more likely? basket, inexperienced mechanic. Link to post Share on other sites More sharing options...
Airwaver 4th Gear July 25, 2013 Share July 25, 2013 just curious. my car manual state 6 litres. when the workshop used the dipstick to check they say 5 litres is enough. am i right to say most likely 5 litre is the minimum and 6 litre is the maximum? i see the dipstick has 2 markings. The Owner Manual is usually accurate. When it states 6L, probably means 6L dry fill. When WS drain the old oil out, they can't possibly drain 6L cos there due to be old oil inside the engine. But 1L difference I think is too much. Link to post Share on other sites More sharing options...
TVT Supercharged July 25, 2013 Share July 25, 2013 just curious. my car manual state 6 litres. when the workshop used the dipstick to check they say 5 litres is enough. am i right to say most likely 5 litre is the minimum and 6 litre is the maximum? i see the dipstick has 2 markings. When your mech say 5 litres is enough, what did the dipstick shows? Ideally it should be between MIN and MAX but preferred level should be 1/2-3/4 mark towards MAX. Link to post Share on other sites More sharing options...
Acemundo Supercharged July 25, 2013 Share July 25, 2013 The Owner Manual is usually accurate. When it states 6L, probably means 6L dry fill. When WS drain the old oil out, they can't possibly drain 6L cos there due to be old oil inside the engine. But 1L difference I think is too much. maybe like what yeobh stated, if run the engine some will be at the filter? it is true that day he didn't run the engine and the filter is brand new. Link to post Share on other sites More sharing options...
Acemundo Supercharged July 25, 2013 Share July 25, 2013 When your mech say 5 litres is enough, what did the dipstick shows? Ideally it should be between MIN and MAX but preferred level should be 1/2-3/4 mark towards MAX. that day i didn't take look unfortunately. and this is first time i patronising this workshop. my regular workshop always charge me 6 litres......so i am wondering whether regular workshop overcharge or new workshop is inexperienced. Link to post Share on other sites More sharing options...
TVT Supercharged July 25, 2013 Share July 25, 2013 maybe like what yeobh stated, if run the engine some will be at the filter? it is true that day he didn't run the engine and the filter is brand new. Actually my mech also never run engine. He just take out dipstick, wipe it, re-insert and pull out to read the level. And the level is exactly at MAX. I always stand beside him when he does that, so I can be sure he didn't overfill or underfill. Link to post Share on other sites More sharing options...
Myxilplix Turbocharged July 25, 2013 Share July 25, 2013 Also take note that if the oil is cold it might bypass the filter until it heats up and thins. I might start a topic about the checking oil hot vs cold thing. ↡ Advertisement Link to post Share on other sites More sharing options...
What do you really spend on and how much?
Eating too much protein?
How much did you spend on house renovation?
How much to install Retractable Awning for home?
Side mirror back cover replacement. where and how much?
