flashbang Turbocharged May 17, 2015 Share May 17, 2015 Tyre pressure should be based on tyre or car? ↡ Advertisement Link to post Share on other sites More sharing options...
Kklee 6th Gear May 17, 2015 Share May 17, 2015 Tyre pressure should be based on tyre or car? Car. 1 Link to post Share on other sites More sharing options...
Pinobii Hypersonic May 17, 2015 Share May 17, 2015 Tyre pressure should be based on tyre or car? There's a label that u might be able to find at the door area which states the recommended pressure for your car, I don't follow 100% Plus a little should be ok too Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear May 19, 2015 Share May 19, 2015 i try to pump every week too. was actually at esso tpy lor1 last week and saw the old man who appeared in the papers. pass him $2 to buy coffee even though i never pump petrol. 1 Link to post Share on other sites More sharing options...
TVT Supercharged May 21, 2015 Share May 21, 2015 Tyre pressure should be based on tyre or car? Tyre. Especially if yours are not stock sized... Link to post Share on other sites More sharing options...
Vratenza Supersonic June 10, 2017 Share June 10, 2017 Anyone uses the Shell Stations' new tyre pump stations with retractable air hose? I used it 3-4 times in total since they are launched, for the life of me can never get the hang of how to stop the reel from rewinding while I am pumping the tires. My only solution is to step on one section to hold it down while I use the free end to top the air of my tires. Cannot find any catch or latch to stop the rachet from rewinding. 1 Link to post Share on other sites More sharing options...
jammi Neutral Newbie June 10, 2017 Share June 10, 2017 Always hated standing in line to get tyres pumped up. Life has been easy since I bought by own compressor. Link to post Share on other sites More sharing options...
BanCoe Hypersonic June 10, 2017 Share June 10, 2017 Same here, lagi worse when trying to pump bicycle tyre as bicycle tyre more wobbly and one hand have to hold the bike at times Anyone uses the Shell Stations' new tyre pump stations with retractable air hose? I used it 3-4 times in total since they are launched, for the life of me can never get the hang of how to stop the reel from rewinding while I am pumping the tires. My only solution is to step on one section to hold it down while I use the free end to top the air of my tires. Cannot find any catch or latch to stop the rachet from rewinding. 1 Link to post Share on other sites More sharing options...
Solar Turbocharged June 11, 2017 Share June 11, 2017 Guys.. Is it really necessary to do it weekly? I only check around once or monthly, sometimes two months. No significant loss.. maybe the only loss is the time I connect the valves with this pssst sound? Perhaps driving long distances daily affects it? Link to post Share on other sites More sharing options...
Blueray Hypersonic June 11, 2017 Share June 11, 2017 Guys.. Is it really necessary to do it weekly? I only check around once or monthly, sometimes two months. No significant loss.. maybe the only loss is the time I connect the valves with this pssst sound? Perhaps driving long distances daily affects it? Nah ... weekly is too ks. Once every 1 - 2 months is more than adequate. 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic June 11, 2017 Share June 11, 2017 I do it about once in a few months or when there is tyre pressure error message. Link to post Share on other sites More sharing options...
flashbang Turbocharged June 11, 2017 Share June 11, 2017 Guys.. Is it really necessary to do it weekly? I only check around once or monthly, sometimes two months. No significant loss.. maybe the only loss is the time I connect the valves with this pssst sound? Perhaps driving long distances daily affects it? Weekly is overkill. I keep track of when I pump air, once I forgot to pump for 2 months, pressure had dropped from 35PSI to 28PSI which was quite a big difference. I would think once every 4-5 weeks is about right for me. 1 Link to post Share on other sites More sharing options...
Loki Supersonic June 11, 2017 Share June 11, 2017 once every 6 weeks or so Link to post Share on other sites More sharing options...
Gnahp Turbocharged June 11, 2017 Share June 11, 2017 my car tire pressure will drop 10% in around 2~3 weeks I usually top it up every 2~3 weeks Link to post Share on other sites More sharing options...
nazerath Turbocharged June 11, 2017 Share June 11, 2017 (edited) Anyone uses the Shell Stations' new tyre pump stations with retractable air hose? I used it 3-4 times in total since they are launched, for the life of me can never get the hang of how to stop the reel from rewinding while I am pumping the tires. My only solution is to step on one section to hold it down while I use the free end to top the air of my tires. Cannot find any catch or latch to stop the rachet from rewinding. There's a notch that you can hook on the side or can just pull n step on it, got free workout too. Edited June 11, 2017 by nazerath 8 Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged June 11, 2017 Share June 11, 2017 I used to think TPMS is useless... but ever since I installed a Orange brand TPMS I feel it's really good to have. No longer have to Guess if pressure is Low and no monthly visit just to pump air Link to post Share on other sites More sharing options...
doraemon69sg 1st Gear June 13, 2017 Share June 13, 2017 Once a month, pressured up to 2.4 bar, although recommended at 2.1 bar. Link to post Share on other sites More sharing options...
Vratenza Supersonic June 13, 2017 Share June 13, 2017 Got notch? I only see rollers X 3 sides where the hose exit the reel. Will go scrutinize it again next time... heck, am starting to think I should just go to Esso station next door to do my pumping instead. There's a notch that you can hook on the side or can just pull n step on it, got free workout too. ↡ Advertisement Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
Petlas Or Giti?
Petlas Or Giti?
Is this tyre good? Made in SG!! Giti tyres!
