SGCMWhiteKnight 2nd Gear June 26, 2014 Share June 26, 2014 FYI: Autobacs is having a sale of the Crimestopper TPMS at $249, which I bought. There are different types of TPMS, some require you to remount the tires as it has to be inserted insert the wheel. The Crimestopper one is only at the valve with a small monitor which is powered by the ciggerate lighter. Its a small and light monitor which cycles through the 4 tires reading the pressure, so it only displays one tires' pressure at any time. Ok for the price and works well. ↡ Advertisement Link to post Share on other sites More sharing options...
Ahgong Supercharged June 26, 2014 Share June 26, 2014 On 7/4/2013 at 3:22 AM, Toothiewabbit said: I was impressed with your lasting tyre pressure until I came to "nitrogen" yeah... me too. i was thinking, wah... what tires he using... so solid~! then the word nitrogen popped out~! Link to post Share on other sites More sharing options...
Storm88 2nd Gear August 1, 2014 Share August 1, 2014 On 7/4/2013 at 3:34 AM, Kangadrool said: If I don't drive for 5 days in a row, the air pressure sure drop. So, have to pump. If drive everyday, 3 months pump once also can. Hi saw your response. I have this issue as well and has been wondering why. If you do not drive, tyre pressure do not reduce. Anyone can share the answer. Link to post Share on other sites More sharing options...
Kiadaw 6th Gear August 1, 2014 Share August 1, 2014 Depends, but normally within 2 months, & when I need to travel long distance. I do have the habit of checking my tires before moving off. 1 Link to post Share on other sites More sharing options...
Daniellica 2nd Gear August 1, 2014 Share August 1, 2014 Its always good to have pre-drive visual checks on your ride before starting your day. Usually i would check all 4 rubbers before starting my ride (i dun wanna tarik fumes). Once in a while (perhaps weekly) i would pop the bonnett and use a torch light to check for any leaks and oils. Then will be a quick check under the chasis before starting my ride. Sounds extreme and my neighbours gimme that "crazy fella" look but i dun bother. I believe that if u take care of your ride, the ride will take care of your wallet. I am poor man. I depend on my ride to make a living. 我靠它吃饭的... Link to post Share on other sites More sharing options...
Kiadaw 6th Gear August 1, 2014 Share August 1, 2014 On 7/4/2013 at 3:11 AM, Quantum said: mine last 10 months pressure 34psi dropped to 32psi, nitrogen I also pump with Nitrogen, 75% of it. Link to post Share on other sites More sharing options...
JJaassoonn 1st Gear August 1, 2014 Share August 1, 2014 (edited) I pump every 2week in the morning Edited August 1, 2014 by JJaassoonn Link to post Share on other sites More sharing options...
ER-3682 Twincharged August 1, 2014 Share August 1, 2014 On 8/1/2014 at 10:45 PM, JJaassoonn said: I pump every 2week in the morning Same. Link to post Share on other sites More sharing options...
TVT Supercharged August 2, 2014 Share August 2, 2014 On 8/1/2014 at 3:15 PM, Storm88 said: Hi saw your response. I have this issue as well and has been wondering why. If you do not drive, tyre pressure do not reduce. Anyone can share the answer. If you do not drive, tyre pressure would still reduce. On 8/1/2014 at 5:15 PM, Daniellica said: Its always good to have pre-drive visual checks on your ride before starting your day. Usually i would check all 4 rubbers before starting my ride (i dun wanna tarik fumes). Once in a while (perhaps weekly) i would pop the bonnett and use a torch light to check for any leaks and oils. Then will be a quick check under the chasis before starting my ride. Sounds extreme and my neighbours gimme that "crazy fella" look but i dun bother. I believe that if u take care of your ride, the ride will take care of your wallet. I am poor man. I depend on my ride to make a living. 我靠它吃饭的... That makes 2 of us. I also do what you do, bend down n use torchlight to shine below.....I know got passer-by looked at me, but I bo chap them lah. 1 Link to post Share on other sites More sharing options...
Lydiachristopher 3rd Gear August 4, 2014 Share August 4, 2014 On 8/1/2014 at 5:15 PM, Daniellica said: Its always good to have pre-drive visual checks on your ride before starting your day. Usually i would check all 4 rubbers before starting my ride (i dun wanna tarik fumes). Once in a while (perhaps weekly) i would pop the bonnett and use a torch light to check for any leaks and oils. Then will be a quick check under the chasis before starting my ride. Sounds extreme and my neighbours gimme that "crazy fella" look but i dun bother. I believe that if u take care of your ride, the ride will take care of your wallet. I am poor man. I depend on my ride to make a living. 我靠它吃饭的... I do same way, no matter what brand of car, just because we love our car. 1 Link to post Share on other sites More sharing options...
Lexuslover 1st Gear August 27, 2014 Share August 27, 2014 Nitrogen & normal gas got different meh? 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear August 28, 2014 Share August 28, 2014 On 8/27/2014 at 4:53 PM, Lexuslover said: Nitrogen & normal gas got different meh? Yes. Link to post Share on other sites More sharing options...
Forte3737 5th Gear August 28, 2014 Share August 28, 2014 On 8/28/2014 at 5:33 AM, Kklee said: Yes.Nitro last longer than normal air.but most cars in spore use air because it's free 1 Link to post Share on other sites More sharing options...
1fast1 Supersonic August 28, 2014 Share August 28, 2014 On 8/27/2014 at 4:53 PM, Lexuslover said: Nitrogen & normal gas got different meh? They're about 21% different, but who's counting? Link to post Share on other sites More sharing options...
Kklee 6th Gear August 28, 2014 Share August 28, 2014 On 8/28/2014 at 6:10 AM, Forte3737 said: Nitro last longer than normal air.but most cars in spore use air because it's free If the tyres are long lasting and requires frequent pumping of air, do that enough times, it will be mostly nitrogen inside. Depending on application, nitrogen may not be suitable, even if it is free. On 8/1/2014 at 5:15 PM, Daniellica said: Its always good to have pre-drive visual checks on your ride before starting your day. Usually i would check all 4 rubbers before starting my ride I do not know why on and off I still do visual checks on my tyres though I experienced that an under inflated tyre (because of a nail) looks the same as the other. Link to post Share on other sites More sharing options...
TVT Supercharged August 28, 2014 Share August 28, 2014 On 8/28/2014 at 8:59 AM, Kklee said: I do not know why on and off I still do visual checks on my tyres though I experienced that an under inflated tyre (because of a nail) looks the same as the other. Visual check is to spot if the tyres are almost flat, or totally flat. If so, got to change to spare below can drive again. Yes. An under inflated (or over inflated) tyre will look the same as the rest. Only inserting a tyre gauge will let you know the difference. Link to post Share on other sites More sharing options...
Nzy Twincharged August 28, 2014 Share August 28, 2014 On 8/28/2014 at 10:50 AM, TVT said: Visual check is to spot if the tyres are almost flat, or totally flat. If so, got to change to spare below can drive again. Yes. An under inflated (or over inflated) tyre will look the same as the rest. Only inserting a tyre gauge will let you know the difference. Under inflated tire should be easy to spot right? I see a few of my neighbors cars' tires under inflated. Very obvious as you can see the sidewalls bulging out and when they go over the hump the whole tire can compress. Link to post Share on other sites More sharing options...
TVT Supercharged August 28, 2014 Share August 28, 2014 On 8/28/2014 at 11:38 AM, Nzy said: Under inflated tire should be easy to spot right? I see a few of my neighbors cars' tires under inflated. Very obvious as you can see the sidewalls bulging out and when they go over the hump the whole tire can compress. No lah.... below side bulge out does not necessarily means it is under inflated. Visually you can't tell one, must use a gauge to check it. You can go pump your tyres to the correct pressure and see if the bulging is still there or not. For my tyres, it remains there. And did you also observe the front 2 tyres are bulge out more than the rear ones? ↡ Advertisement Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
Petlas Or Giti?
Petlas Or Giti?
Is this tyre good? Made in SG!! Giti tyres!
