Quantum 5th Gear July 4, 2013 Share July 4, 2013 mine last 10 months pressure 34psi dropped to 32psi, nitrogen ↡ Advertisement Link to post Share on other sites More sharing options...
Toothiewabbit Supersonic July 4, 2013 Share July 4, 2013 mine last 10 months pressure 34psi dropped to 32psi, nitrogen I was impressed with your lasting tyre pressure until I came to "nitrogen" Link to post Share on other sites More sharing options...
Shift_lock 1st Gear July 4, 2013 Share July 4, 2013 Monthly but usually only drop a bit maybe like 32psi drop to 30psi. Nitrogen really so good ah ? Link to post Share on other sites More sharing options...
TVT Supercharged July 4, 2013 Share July 4, 2013 Monthly. Once a month should be good enough. Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 4, 2013 Share July 4, 2013 If I don't drive for 5 days in a row, the air pressure sure drop. So, have to pump. If drive everyday, 3 months pump once also can. Link to post Share on other sites More sharing options...
StefanK Supercharged July 4, 2013 Share July 4, 2013 I pump my tyres everytime after I top up petrol. So that's about 4 -5 days? Link to post Share on other sites More sharing options...
Quantum 5th Gear July 4, 2013 Author Share July 4, 2013 I pump my tyres everytime after I top up petrol. So that's about 4 -5 days? have you detected pressure dropping obviously during your every pumping? Link to post Share on other sites More sharing options...
Johnnylim 5th Gear July 4, 2013 Share July 4, 2013 I pump my tyres everytime after I top up petrol. So that's about 4 -5 days? U mean yr tyres pressure drop every 4-5 days? Something must be wrong...... Link to post Share on other sites More sharing options...
13177 Hypersonic July 4, 2013 Share July 4, 2013 I pump my tyres everytime after I top up petrol. So that's about 4 -5 days? 4-5 days pump tyres? Need to be so frequent? Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 4, 2013 Share July 4, 2013 Arm yourself with a simple good quality tyre pressure gauge, and you will save time going to service station. Link to post Share on other sites More sharing options...
StefanK Supercharged July 4, 2013 Share July 4, 2013 Erms... 3 people asking same question, so I never quote. My usual kpa is 230 on all 4 wheels. So when I go to the pump, it shows 225 or 215. So like that means got something wrong? I like the feeling when my tyres are at 230, psychologically, smoother ride. So my case is something wrong or I too anal liao? Link to post Share on other sites More sharing options...
Octopus 3rd Gear July 4, 2013 Share July 4, 2013 Erms... 3 people asking same question, so I never quote. My usual kpa is 230 on all 4 wheels. So when I go to the pump, it shows 225 or 215. So like that means got something wrong? I like the feeling when my tyres are at 230, psychologically, smoother ride. So my case is something wrong or I too anal liao? Nothing wrong, the lost pressure went to the hose length. Just note what is the normal pressure it shows initially, if it much lower than normal initial pressure then likely there is a leak in your tyre somewhere. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 4, 2013 Share July 4, 2013 Tyre pressure is best at recommended KPA. There is nothing to worry at all if the reading is + _ 10%. Link to post Share on other sites More sharing options...
StefanK Supercharged July 4, 2013 Share July 4, 2013 Nothing wrong, the lost pressure went to the hose length. Just note what is the normal pressure it shows initially, if it much lower than normal initial pressure then likely there is a leak in your tyre somewhere. Ok. Just remembered, I only pump once a month for the other car which I don't drive often. Is it recommended to pump as regularly as I do? Tyre will overstretch boh? Link to post Share on other sites More sharing options...
StefanK Supercharged July 4, 2013 Share July 4, 2013 Tyre pressure is best at recommended KPA. There is nothing to worry at all if the reading is + _ 10%. Ya, that time my workshop pump 240 for me. Go over a pothole at 60km/h, the tyre burst. In the end have to go back to them to change a new one. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 4, 2013 Share July 4, 2013 (edited) Tyre are designed with 4 times safety factor before bursting. Under normal road conditions it 's very safe. Going into a pot hole not only destroy the rim and tyre , such happening can also easily kill the driver Edited July 4, 2013 by Yeobh Link to post Share on other sites More sharing options...
Timex1441 1st Gear July 4, 2013 Share July 4, 2013 i do it once a week....probably dun need to do tat....but it's a habit for so long liao, i juz continue....afterall, the petrol station is on my way to work, very convenient Link to post Share on other sites More sharing options...
Hydrocarbon Turbocharged July 4, 2013 Share July 4, 2013 Ya, that time my workshop pump 240 for me. Go over a pothole at 60km/h, the tyre burst. In the end have to go back to them to change a new one. Like this then they can earn your money mah. ↡ Advertisement Link to post Share on other sites More sharing options...
Pirelli P Zero PZ5
Pirelli P Zero PZ5
Petlas Or Giti?
Petlas Or Giti?
Portable Tyre Pump
Portable Tyre Pump
