Ctng Neutral Newbie June 30, 2013 Share June 30, 2013 yesterday I doing some diy job to remove the foot light installed previously. when I tried to remove the wires I think it got shorted and I can see smoke and sparks coming out from the fuse box at the driver side. Now the driver door is always open and I cannot lock my car using remote. what could be the worst can scenario and also which workshop is good at troubleshoot this kind of issue? Any workshop in the west would be good. ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Twincharged June 30, 2013 Share June 30, 2013 Toyota,if quite a new one,go back agent,don't play with wiring,it can burn up the whole car....lost more $$$. Link to post Share on other sites More sharing options...
Ctng Neutral Newbie June 30, 2013 Author Share June 30, 2013 its a parallel import and quite sometimes already. anybody can help? I don't to go any workshop and get carrot. Link to post Share on other sites More sharing options...
ER-3682 Twincharged June 30, 2013 Share June 30, 2013 its a parallel import and quite sometimes already. anybody can help? I don't to go any workshop and get carrot. Electrical problem can try Nam Sing,at A.M.K. AutoPoint,their number are 64837230. Link to post Share on other sites More sharing options...
Kusje Supersonic June 30, 2013 Share June 30, 2013 Why not check the fuse yourself? Very easy. Link to post Share on other sites More sharing options...
Ctng Neutral Newbie June 30, 2013 Author Share June 30, 2013 workshop checked for me today say no fuse blow. maybe wire melted. ask me come back tomorrow. I just random went to a workshop. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 1, 2013 Share July 1, 2013 You have accidently grounded a hot wire ( wire directly connected to battery and not via ignition switch.) Suprising your hot wire is not fused. Link to post Share on other sites More sharing options...
Ctng Neutral Newbie July 1, 2013 Author Share July 1, 2013 So any recommendation where to fix it? Now damn troublesome got to manual lock the door and also got the beep beep beep warning sound sound. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear July 2, 2013 Share July 2, 2013 bro could be your lock actuator problem. usually the actuator control the central locking and the alarm locking. Each door lock there is one actuator. Check that one first. If is that problem replace it will solved. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 2, 2013 Share July 2, 2013 Both Nam Sing & Lion City should be able to hand such simple wiring problem. Link to post Share on other sites More sharing options...
Ctng Neutral Newbie July 4, 2013 Author Share July 4, 2013 Went another workshop. They suspect pcb board issue. They cant fox also. Anybody can help? Link to post Share on other sites More sharing options...
Ctng Neutral Newbie July 4, 2013 Author Share July 4, 2013 (edited) Went another workshop. They suspect pcb board issue. They cant fox also cos no fuse burned. Anybody can help? Edited July 4, 2013 by Ctng Link to post Share on other sites More sharing options...
Little_prince Supersonic July 4, 2013 Share July 4, 2013 go borneo lor. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear July 4, 2013 Share July 4, 2013 if you don't mind driving to the east side, you could seek help from Ah Yuan of GT Auto Sound Trading at Blk 1069 Eunos Avenue 5 #01-175. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 4, 2013 Share July 4, 2013 The best way out is to go back to the pcb & light installer. Link to post Share on other sites More sharing options...
Ctng Neutral Newbie July 4, 2013 Author Share July 4, 2013 The best way out is to go back to the pcb & light installer. installer mia liao. so long ago. I want a one stop who can fix my problem rather then keep going to different workshop and keep asking. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 4, 2013 Share July 4, 2013 For those who wish to supply hot wires ( by-passing the ignition switch, direct from battery ) to yr accessories, for safety reasons and to prevent fire , always insists on routing the wire via online fuse, if going to the fuse box is difficult or not possible. Link to post Share on other sites More sharing options...
Passer Neutral Newbie January 3, 2017 Share January 3, 2017 My turn signals are not working properly, the right hand side will blink a few times then dies off or it will turn on and not blink at all..if hazard light on, right hand light will intermittently dies and back on again..my usual mech says it is fuse box problem..but since that part for my car quite hard to find, any suggestions what else could be wrong? Driving kia cerato v2 here..thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Workshop for simple jobs
Grinding racket
Grinding racket
