Jokerd 2nd Gear June 1, 2013 Share June 1, 2013 Hi all. Noticed something funny about my Vios. Today after driving out (startup OK, reach destination then problems come out) At the destination car park, pressing the lock and unlock on the key no signal from car. Main headlights also never light up, just the smaller lights below the signal lights light up. After restart car, headlights OK, the locks : 1. When press the unlock button on my key, key got light and car of the unlock signal but doors are not unlocked. Need to use key to manually unlock the door. Start engine, doors lock as per normal. 2. Stop engine, usually doors should unlock. Now also never unlock. Need to manually press the button to unlock. Anyone has any ideas what's going on? Electrical problems? Or problem with the lock? ↡ Advertisement Link to post Share on other sites More sharing options...
Camrysfa Turbocharged June 1, 2013 Share June 1, 2013 All these functions most probably controlled by an IC box. Those car audio/alarm shops should be able to handle this problem. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear June 1, 2013 Share June 1, 2013 your remote got problem. get it check or replace it. Link to post Share on other sites More sharing options...
5936 1st Gear June 1, 2013 Share June 1, 2013 Yea, likely alarm remote unit.change battery first, if same go to AD or alarm system distributor.It used to be Silicon alarm, not sure if your from same local company. Link to post Share on other sites More sharing options...
Jokerd 2nd Gear June 6, 2013 Author Share June 6, 2013 Hi, thanks all. It was the alarm unit problem after all. Got it replaced. Link to post Share on other sites More sharing options...
Ahgong Supercharged June 6, 2013 Share June 6, 2013 Hi, thanks all. It was the alarm unit problem after all. Got it replaced. Dun mind asking, how much is the replacement? Link to post Share on other sites More sharing options...
Mysportwish 1st Gear June 6, 2013 Share June 6, 2013 for a basic one, less than $80 you can get it with installation. Link to post Share on other sites More sharing options...
Ixus75 3rd Gear June 7, 2013 Share June 7, 2013 I have same issue with my vios before. It was isolated to loose connection behind glove box. Link to post Share on other sites More sharing options...
Ahgong Supercharged June 7, 2013 Share June 7, 2013 for a basic one, less than $80 you can get it with installation. any brand to recommend at that price? how about WS for the installation? Link to post Share on other sites More sharing options...
Mysportwish 1st Gear June 7, 2013 Share June 7, 2013 any audio workshop should be able to help you... i always go to the one at SIM AVENUE Link to post Share on other sites More sharing options...
Helmon55 Neutral Newbie June 10, 2013 Share June 10, 2013 Its definitely problem in car locking system, check with the technications, might be there are some fault in circuits. Because car does not give proper signals and you are facing problem in unlocking or lights etc. So better is to replace it with the new one and drive in safe mod... ↡ Advertisement Link to post Share on other sites More sharing options...
Online purchase for car parts
i Wake Up Naked Today Morning
ODO Mileage Tampering
Enzo car mats
Enzo car mats
