Mustang 1st Gear May 28, 2013 Share May 28, 2013 Using hair dryer?Adhesive remover?Where to buy?The carbon sticker got white mark caused by the car washer whom accidentally wax the stix too.Any helps and tips is fully appreciated ↡ Advertisement Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear May 28, 2013 Share May 28, 2013 Using hair dryer?Adhesive remover?Where to buy?The carbon sticker got white mark caused by the car washer whom accidentally wax the stix too.Any helps and tips is fully appreciated WD40...lighter fluid. After the car will be oily...just wash with plenty of soap and water. And if you are using lighter fluid...remember dun smoke. 1 Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 28, 2013 Share May 28, 2013 Will the car paint have any damage if the carbon fibre sticker or wrap were to be removed few years later? I've ever considered getting car wrap but worried will it damage the paintworks later if need to be remove..... Anyone have experience on this? Link to post Share on other sites More sharing options...
Vivant511 Neutral Newbie May 28, 2013 Share May 28, 2013 Using hair dryer?Adhesive remover?Where to buy?The carbon sticker got white mark caused by the car washer whom accidentally wax the stix too.Any helps and tips is fully appreciated First try to pick at a corner to create a flap to pull at. Use a heat gun to warm up the glue, always moving the gun and never stay in one spot. Once warm enough, quickly peel back the sticker trying to pay it as flat as possible. If it cools, run the heat gun again to warm it up. Repeat until finished Remove glue residue with a citrus based cleaner (you can find at Cold Storage, Giant, etc) or some diluted white spirits. Any light scratching you can touch up with a light hand polish. WD40 may work also, but will make it slippery/oily to hold and peel and can get a bit messy if drips in between crevices. Good luck! Link to post Share on other sites More sharing options...
ECS Neutral Newbie June 7, 2015 Share June 7, 2015 thank you! thats a helpful tip! :) Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 7, 2015 Share June 7, 2015 Heat gun together with this professional scraper and plastic blade is the best combination for removing stubborn stickers. Link to post Share on other sites More sharing options...
Showster Twincharged September 10, 2015 Share September 10, 2015 Sorry hijack thread: Is there such a thing as a steering wheel sticker? To cover parts of paint loss due to friction. I tried to send for repaint but very inconvenient as the whole steering wheel had to be dismantled. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Mar 2025
Xiaomi EV is Coming
Xiaomi EV is Coming
That's how Tesla makes $$$
2024 Suzuki Swift
2024 Suzuki Swift
MYCARFORUM stickers
MYCARFORUM stickers
Mileage Tampering
Mileage Tampering
