Philipkee Twincharged May 1, 2013 Share May 1, 2013 In Jan this year, my low oil pressure indicator came on. I sent my car for servicing, everything was back to normal. Today, 5000 plus km later, the low oil pressure indicator came on again. I am sure there is nothing wrong with the oil pressure. What could be the cause? The indicator flickers on and off sometimes, not frequently ↡ Advertisement Link to post Share on other sites More sharing options...
Seitou Neutral Newbie May 1, 2013 Share May 1, 2013 Could it be the sensor of the oil press spoil? Common problem, my fren just replace his sensor total damage cost about 300+. He's using defi.. Link to post Share on other sites More sharing options...
Philipkee Twincharged May 1, 2013 Author Share May 1, 2013 Could it be the sensor of the oil press spoil? Common problem, my fren just replace his sensor total damage cost about 300+. He's using defi.. 300 dollars???? Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 1, 2013 Share May 1, 2013 (edited) To be 100% positive that you lub pump is in order get yr mech to do a oil pressure test - simple as ABC Low pressure can cause serious damage to the engines moving and rotating components. Edited May 1, 2013 by Yeobh Link to post Share on other sites More sharing options...
Seitou Neutral Newbie May 1, 2013 Share May 1, 2013 That's defi.. But if u are using others lower end brand of cause it will be cheaper.. As defi is one of the top notch gauges.. Link to post Share on other sites More sharing options...
High_octane 1st Gear May 1, 2013 Share May 1, 2013 That's defi.. But if u are using others lower end brand of cause it will be cheaper.. As defi is one of the top notch gauges.. I think TS is talking about the OEM oil pressure sensor. Link to post Share on other sites More sharing options...
5936 1st Gear May 1, 2013 Share May 1, 2013 dun jump to conclusion first.this one could be big on $$ or only small simple solution. Link to post Share on other sites More sharing options...
Blueraven Clutched May 1, 2013 Share May 1, 2013 check your oil level? Link to post Share on other sites More sharing options...
Philipkee Twincharged May 1, 2013 Author Share May 1, 2013 Oil level normal Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 2, 2013 Share May 2, 2013 Oil level normal If oil level is ok sometimes yr oil too thin. Either u using too thin oil or it thins too much till cannot reach required oil pressure. If u using a thin oil like 20-30weight oil....try using 40-50 weight n see how. Also use good quality oil not some new or unknown brands. Some lousy oil thins very fast. Link to post Share on other sites More sharing options...
Kratoschumacher 3rd Gear May 2, 2013 Share May 2, 2013 Duplicate thread, please continue your discussions here: http://www.mycarforum.com/index.php?showtopic=2688613 ↡ Advertisement Link to post Share on other sites More sharing options...
HSA recalls 3 brands of high blood pressure drugs
Tyres pressure for 225/45/R17
Low Engine Oil Warning
Speed warning device for Vans/Lorries
Clown offer money to students to follow him
Town Council Issued with Fire Hazard Abatement Notices (FHAN) by SCDF
How useful is higher pressure radiator cap?
Formula 1 Singapore GP Diary (Warning: Pics Intensive)
