Low pressure warning
Twincharged
In Jan this year, my low oil pressure indicator came on. I sent my car for servicing, everything was back to normal.
Today, 5000 plus km later, the low oil pressure indicator came on again. I am sure there is nothing wrong with the oil pressure. What could be the cause? The indicator flickers on and off sometimes, not frequently
check your oil level.... there should be leakage somewhere. If confirm no leakage, then your oil pressure sensor is faulty.
1st Gear
Dun jump into conclusion first.This one can be Big$$$ or small.
If there is no external signs of leaks, have u experienced drop in engine power or noisy lifters?
How is the EO colour? brownish or black?Low EO level is definitely one of the causes.Poor circulation can also contribute to this problem, and can be resolved with cleaning of oil pump intake screen.
Twincharged
Oil leak at the gaskets? which part oil leak bro?
they have to check.cos there are droplets of oil at various places. so they need to remove the mountings to see. will take half a day
Wow try to get a 2nd opinion, think its not gonna be cheap if they need to remove the mountings too.
Hope its a minor leak at the gasket with lesser damage cost,
Twincharged
A triple check of dip stick shows it is dry. I tot there was oil cos there was oil in he dipstick but when engine was shut off, it became dry. Dun feel safe driving to another workshop :o
Supersonic
Maybe someone forgot to tighten the oil plug during your servicing.
In the mean time, get some cheap carl-be and pour in.
Last time when my engine oil went missing is that i got a top block gasket leaking.
Hope you get it solved soon, my friend Grandis engine oil top gasket leak result in the radiator dried up and a top overhaul.
Hate it when our car gives problems.
Twincharged
Which year is your avante and mileage? I am also driving an avante.
2009 avante. Mileage 65000. Mine is OPC
Mine is also 2009 but normal plate,mileage is on the high side.So far so good, only change alternator and some wear and tears.
Twincharged
The flywheel oil seal was broken so it was changed. Total damage $480 [bigcry] [bigcry]
