Ruriimasu 1st Gear April 22, 2013 Share April 22, 2013 Anyone here uses steam iron, the type which doesn't need ironing board? How effective is it? Can it replace those type which needs ironing board? I don't need straight iron lines on my clothes, just need to remove wrinkles. ↡ Advertisement Link to post Share on other sites More sharing options...
Jman888 Moderator April 22, 2013 Share April 22, 2013 not effective, forget about it. Link to post Share on other sites More sharing options...
Watwheels Supersonic April 22, 2013 Share April 22, 2013 Effectiveness is in the hands of those who know how to use it. Actually why many ppl dunno how to use an iron? I iron my own shirts. Have been doing it for many years. Not really difficult, just have to get the hang of it. Link to post Share on other sites More sharing options...
Adrianli Hypersonic April 22, 2013 Share April 22, 2013 Have a Novita unit. Cant really get it straight for 100% cotton shirts. But for polyester shirts like the ones from G2000, can get it straight. Must pull the shirt and then use the steamer to go over it. Dont put the steamer too long on the shirt, will make it wet due to condensation. But after a while, me back to normal iron. Cos I can iron my shirt faster than using the steam iron. My Novita is a white elephant since then. Now no longer working but still there. Link to post Share on other sites More sharing options...
Jman888 Moderator April 22, 2013 Share April 22, 2013 Have a Novita unit. Cant really get it straight for 100% cotton shirts. But for polyester shirts like the ones from G2000, can get it straight. Must pull the shirt and then use the steamer to go over it. Dont put the steamer too long on the shirt, will make it wet due to condensation. But after a while, me back to normal iron. Cos I can iron my shirt faster than using the steam iron. My Novita is a white elephant since then. Now no longer working but still there. me too, want to sell it away [laugh] not to mentioned you get burn by the steam Link to post Share on other sites More sharing options...
Meanmachine Supercharged April 22, 2013 Share April 22, 2013 If you're not using your Steam iron , U may consider donating to charity, I'm doing work for a non-profit charity home for the aged and homeless. Must be in working condition. PM me. Thx Link to post Share on other sites More sharing options...
Jman888 Moderator April 22, 2013 Share April 22, 2013 If you're not using your Steam iron , U may consider donating to charity, I'm doing work for a non-profit charity home for the aged and homeless. Must be in working condition. PM me. Thx provided there are helper who is doing the ironing, if not I won't recommend old folk to use it. Link to post Share on other sites More sharing options...
Altivo 3rd Gear April 22, 2013 Share April 22, 2013 I think you are referring to garment steamers. Save your money and time by using a conventional iron. You might wonder why it doesn't work as well at home as compared to those sales girls using it in boutiques. That's becos their clothes are already pre-ironed in the factory. It takes quite a bit of effort to achieve the same for clothes which are freshly laundered. Link to post Share on other sites More sharing options...
Chrispie 5th Gear April 22, 2013 Share April 22, 2013 men's clothings usually need 'iron lines' to be hard ironed in... these steamers wont be able to achieve that. but if you are concerned with having 'shiny' marks due to high temperature and pressure when the fabrics overlaps on some fabrics, this will prevent it... Another thing is, it takes darn long to iron one piece of clothing... normal iron still the best. Link to post Share on other sites More sharing options...
TomasTom November 7, 2013 Share November 7, 2013 I think what you need is a steam iron that has the vertical steam feature,which can make the functions without the ironing board.And you can also choose the steamer garment to finish the task,But it is common more expensive than the steam iton.In a word,I recommand that you purchase the convenient steam iron has the vertical steam feature. 4 Link to post Share on other sites More sharing options...
WTF 4th Gear November 7, 2013 Share November 7, 2013 after changing job recently, got to wear long sleeves and iron them. 1st was using the normal iron but found it too siong....then switched to garment steamers..... can say not able to achieve the same standard as normal iron and also depending on the clothes' materials......but at least it's ok for the lazy me....... Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 7, 2013 Share November 7, 2013 Steam iron is junk. I switched back to conventional iron - Panasonic NI-416E 3.5 lbs Made in Malaysia more than 10 years. No regrets. The trick to reduce "siongness" when ironing is to set the temperature right. There is an indication on the knob for various types of clothing materials. Used it too low will be too siong, using too hot for certain materials like rayon will be very siong also 'cos it becomes sticky and iron will not glide easily. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged November 7, 2013 Share November 7, 2013 (edited) steam iron don't work on guys shirt. work well only lady shirt due to type of material. forget it if you are buying for yourself. BTW, why am I replying to a post that is so long ago?? Edited November 7, 2013 by Joseph22 Link to post Share on other sites More sharing options...
Myxilplix Turbocharged November 7, 2013 Share November 7, 2013 No problems with my novita steam iron, easy to use and gets all the wrinkles out. If you play around with folding/pulling you can even get the crease lines decent. I made sure to watch youtube tutorials first before using. It probably does take longer than a conventional iron but that's ok for me, only my own clothes and i'm goddamn useless with conventional iron. Plus I live in a shoebox and don't want an ugly ironing board to deal with. Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 8, 2013 Share November 8, 2013 Steam iron is junk. I switched back to conventional iron - Panasonic NI-416E 3.5 lbs Made in Malaysia more than 10 years. No regrets. The trick to reduce "siongness" when ironing is to set the temperature right. There is an indication on the knob for various types of clothing materials. Used it too low will be too siong, using too hot for certain materials like rayon will be very siong also 'cos it becomes sticky and iron will not glide easily. I tot the trick to reduce "siongness" is to get an iron with a bigger ironing surface so less movement can cover whole shirt. Thatz what the sales man told me when I was buying the iron. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged November 8, 2013 Share November 8, 2013 I tot the trick to reduce "siongness" is to get an iron with a bigger ironing surface so less movement can cover whole shirt. Thatz what the sales man told me when I was buying the iron. Provided u also have Hugh ironing board. Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 8, 2013 Share November 8, 2013 Those commercial type is the best. Very fast can finish a shirt. Just place nicely, press one time and its done. https://www.google.com.sg/search?q=commercial+ironing+press&source=lnms&tbm=isch&sa=X&ei=cDV8UvOFI4rsrAfcj4CICw&sqi=2&ved=0CAcQ_AUoAQ&biw=691&bih=877 Link to post Share on other sites More sharing options...
13177 Hypersonic July 5, 2016 Share July 5, 2016 I have a noob question, anyone knows what is the different between those ironing board which sell at $10 dollar plus to $100 per piece ah? How come pricing can be so much difference between every ironing board? ↡ Advertisement Link to post Share on other sites More sharing options...
Need Advice on Self Storage
