Extinguisher 6th Gear April 20, 2013 Share April 20, 2013 Anybody knows the differences between k20r-u11 and k20pr-u11? I bought the former but realise my manual says the latter. is it ok to use? ↡ Advertisement Link to post Share on other sites More sharing options...
Ooosh 1st Gear April 20, 2013 Share April 20, 2013 Car? Model? Link to post Share on other sites More sharing options...
Extinguisher 6th Gear April 20, 2013 Author Share April 20, 2013 Mitsubishi Lancer GLX (CS3) Link to post Share on other sites More sharing options...
Vinceng Turbocharged May 28, 2014 Share May 28, 2014 (edited) This is how my normal Denso spark plug looks like after just 3000km. A lot of white deposit on the bottom one. What is wrong? Can still use? Edited May 28, 2014 by Vinceng Link to post Share on other sites More sharing options...
DonNuTs 1st Gear May 28, 2014 Share May 28, 2014 This is how my normal Denso spark plug looks like after just 3000km. A lot of white deposit on the bottom one. What is wrong? Can still use? This is a sign of water corrision from the top(gap between plug connector and engine). Not due to coolant doesn't affect your engine combustion chamber. Did you remove the engine cover ? If you did, do consider putting it back. Link to post Share on other sites More sharing options...
Vinceng Turbocharged May 28, 2014 Share May 28, 2014 (edited) I did not remove engine cover. Spark plugs are located behind yellow engine oil dip stick and below black air filter cover. How can water sip in? Edited May 28, 2014 by Vinceng Link to post Share on other sites More sharing options...
Vinceng Turbocharged May 28, 2014 Share May 28, 2014 Oops. Actually there is no engine cover. Air filter located above engine block. ↡ Advertisement Link to post Share on other sites More sharing options...
Tool to change Spark Plug
Changing of Spark Plugs
Plug-and-play vaccine
Spark Car Care
Spark Car Care
Aftermarket vs. OEM Spark Plug Wires
DENSO Singapore - Free Cleverin Treatment With No Purchase Required
Replace spark plugs
Replace spark plugs
Denso Iridium Spark Plug (IK20)
