Hondaes8 2nd Gear April 19, 2013 Share April 19, 2013 Hi all,anyone experience loss of signal for the last 1-2 days ? i am experiencing this with my Garmin inside the car while driving. Out in the open area static, is ok. happen to both my Garmin 205 and Garmin 2465....not sure if my set is faulty as i do not have this encounter before.Pls advise. ↡ Advertisement Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged April 19, 2013 Share April 19, 2013 Did u install any new solar film or car cam? Link to post Share on other sites More sharing options...
Caravan 5th Gear April 19, 2013 Share April 19, 2013 If the GPS system is down, I'm pretty sure you won't be the only person making noise. You already said in the open static is ok. Must be your setup problem. Link to post Share on other sites More sharing options...
Watwheels Supersonic April 19, 2013 Share April 19, 2013 It could be tall buildings blocking the signal. Sgp a lot of high rise building. If you go places like Shenton way your GPS navigation will experience loss of signal. Link to post Share on other sites More sharing options...
Hondaes8 2nd Gear April 19, 2013 Author Share April 19, 2013 Yup, just installed a car cam.... how did that affect the GPS signal ? can someone enlighten me and the workaround ? thanks thanks Link to post Share on other sites More sharing options...
Jman888 Moderator April 19, 2013 Share April 19, 2013 thick cloud in the sky also take long time to get signal. Link to post Share on other sites More sharing options...
Taipan49 3rd Gear April 19, 2013 Share April 19, 2013 Hi all, anyone experience loss of signal for the last 1-2 days ? i am experiencing this with my Garmin inside the car while driving. Out in the open area static, is ok. happen to both my Garmin 205 and Garmin 2465.... not sure if my set is faulty as i do not have this encounter before. Pls advise. I know with the Garmin cycling GPS's there can be lots of issues with certain units. Speak to Garmin and see what they say. Link to post Share on other sites More sharing options...
RadX Moderator April 19, 2013 Share April 19, 2013 It could be tall buildings blocking the signal. Sgp a lot of high rise building. If you go places like Shenton way your GPS navigation will experience loss of signal. sumtimes solar flare can cause the loss..... Link to post Share on other sites More sharing options...
Simplecar 4th Gear April 19, 2013 Share April 19, 2013 was thinking of that but i guess it would be consistent whether we are in tuas or changi. Looks like some form of electrical interference. Even buildings can cause GPS signals to be distorted - my GPS watch always display wrong values at certain areas in CBD (tall buildings) Link to post Share on other sites More sharing options...
Tianmo Hypersonic April 19, 2013 Share April 19, 2013 I always lost signal when in carpark........CTE tunnel also............ [laugh] Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged April 19, 2013 Share April 19, 2013 Yup, just installed a car cam.... how did that affect the GPS signal ? can someone enlighten me and the workaround ? thanks thanks U troubleshoot by switching off the car cam see if GPS signal is able to log on. If yes, then the only way is to shift your GPS to the right side near the door, especially of currently its placed below your car cam, or remove car cam or switch off car can if die die wants to use GPS. I got same issue before. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 19, 2013 Share April 19, 2013 Hi all, anyone experience loss of signal for the last 1-2 days ? i am experiencing this with my Garmin inside the car while driving. Out in the open area static, is ok. happen to both my Garmin 205 and Garmin 2465.... not sure if my set is faulty as i do not have this encounter before. Pls advise. Sud b yr set. If US block signal due to military ops ty dun cancel e signal completely. Ty just make it less accurate to maybe 100meters instead of 10meters. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 19, 2013 Share April 19, 2013 Yup, just installed a car cam.... how did that affect the GPS signal ? can someone enlighten me and the workaround ? thanks thanks Thete was some mention in another thread that e cam wiring might b too near yr gps. Try shifting yr gps as far fm e cam n see how. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 19, 2013 Share April 19, 2013 sumtimes solar flare can cause the loss..... Solar film i know can. Solar flare......hmmmmmmmm? R there a lot of solar flares lately? I didnt notice any? Btw hows yr boat hunting going? Seen anything u like so far? Link to post Share on other sites More sharing options...
Rustyz 5th Gear April 19, 2013 Share April 19, 2013 Yup, just installed a car cam.... how did that affect the GPS signal ? can someone enlighten me and the workaround ? thanks thanks Interference lo, if GPS still under warranty bring back agent see if they can boast it a not. no harm trying ↡ Advertisement Link to post Share on other sites More sharing options...
Speeding captured through on board GPS/In Car System
BreadTalk Will Delist Company On 5 Jun After Posting $5.8 Million Loss In 2019
Car immobiliser and GPS tracker recommend?
Is Standalone GPS obsoleting?
Dashcam with GPS
Dashcam with GPS
Use your blinker!
Use your blinker!
Car Accessories Workshop in West Area
Queuing to turn left into side road - signal lights or hazards?
