Alvinlkw Neutral Newbie April 17, 2013 Share April 17, 2013 Hi bros, Any one know what might be the problem when the hazard lights don't light up when I open the door of my 06 Altis? I still hear the sound but there is no light. When I lock my car, the hazard light also don't light up anymore. My mechanic said that it could be the remote control module but where can I get it fixed? Thanks! Alvin ↡ Advertisement 1 Link to post Share on other sites More sharing options...
WTF 4th Gear April 17, 2013 Share April 17, 2013 but can your hazard lights be turned on when you pressed the hazard lights button? Link to post Share on other sites More sharing options...
Lamemonster Clutched April 17, 2013 Share April 17, 2013 There's a fuse in the alarm control module. ( stock bm alarm ) Change tat. 1 Link to post Share on other sites More sharing options...
Rustyz 5th Gear April 17, 2013 Share April 17, 2013 Agree should be fuse. That the cheapest repair if not is headache liao Link to post Share on other sites More sharing options...
Shift_lock 1st Gear April 17, 2013 Share April 17, 2013 If it's really a remote problem, it's cheap to replace. If yours is using the Silicon brand remote same as my 2005 Altis, you can buy it from Lian Siong at Veerasamy Road. Cost me only $30 there and before that I checked with BM and they quoted $80 ! 1 Link to post Share on other sites More sharing options...
Alvinlkw Neutral Newbie April 22, 2013 Author Share April 22, 2013 but can your hazard lights be turned on when you pressed the hazard lights button? Yup. My hazard lights still work when I press the hazard light button. Link to post Share on other sites More sharing options...
Alvinlkw Neutral Newbie April 22, 2013 Author Share April 22, 2013 There's a fuse in the alarm control module. ( stock bm alarm ) Change tat. Ok let me search for it. Link to post Share on other sites More sharing options...
Lamemonster Clutched April 22, 2013 Share April 22, 2013 Confirm 100% its the fuse.... Its down under driver dashboard side. .... Find the alarm module n change the fuse 10a if im not wrong..... Ive got tat same problems years back. Link to post Share on other sites More sharing options...
Lamemonster Clutched April 22, 2013 Share April 22, 2013 (edited) Dbl post ... Sorry.. Edited April 22, 2013 by Lamemonster Link to post Share on other sites More sharing options...
Alvinlkw Neutral Newbie April 22, 2013 Author Share April 22, 2013 Confirm 100% its the fuse.... Its down under driver dashboard side. .... Find the alarm module n change the fuse 10a if im not wrong..... Ive got tat same problems years back. Thanks bro. Will do it tomorrow morning. Link to post Share on other sites More sharing options...
Alvinlkw Neutral Newbie April 25, 2013 Author Share April 25, 2013 Confirm 100% its the fuse.... Its down under driver dashboard side. .... Find the alarm module n change the fuse 10a if im not wrong..... Ive got tat same problems years back. Bro I saw a 20A fuse when I open up a side panel just below the driver dashboard. It's the only fuse I see there. There was a bundle of wires tied up and one of them goes to a button where I can reset the alarm in case I open with my key. Do you think that should be the fuse? Link to post Share on other sites More sharing options...
Kangadrool Supersonic April 25, 2013 Share April 25, 2013 (edited) Hi bros, Any one know what might be the problem when the hazard lights don't light up when I open the door of my 06 Altis? I still hear the sound but there is no light. When I lock my car, the hazard light also don't light up anymore. My mechanic said that it could be the remote control module but where can I get it fixed? Thanks! Alvin [laugh] The first time I drove an Altis courtesy car, I thought the electrical system something wrong when hazard lights keep blinking when door is opened. Called the w/s and complained the signal got problem, cannot switched off. Edited April 25, 2013 by Kangadrool Link to post Share on other sites More sharing options...
Alvinlkw Neutral Newbie April 26, 2013 Author Share April 26, 2013 [laugh] The first time I drove an Altis courtesy car, I thought the electrical system something wrong when hazard lights keep blinking when door is opened. Called the w/s and complained the signal got problem, cannot switched off. Yours seems a bigger problem than mine. Link to post Share on other sites More sharing options...
Alvinlkw Neutral Newbie April 28, 2013 Author Share April 28, 2013 Confirm 100% its the fuse.... Its down under driver dashboard side. .... Find the alarm module n change the fuse 10a if im not wrong..... Ive got tat same problems years back. Bro looks like my problem is not the fuse. I changed it and it is still the same. Likely a wiring problem. Link to post Share on other sites More sharing options...
Lamemonster Clutched May 2, 2013 Share May 2, 2013 Shoul be 10a if i remembered correctly . Its not visible on sight. ↡ Advertisement Link to post Share on other sites More sharing options...
Quad Light Bulb Size
