20G 1st Gear April 7, 2013 Share April 7, 2013 I am thinking abt going for the above. However, I am having concern on it's parts availability and reliability. Anyone with experience can share info on this? By the way, what is the difference between the pre facelift and facelift one apart from asthetically different? ↡ Advertisement Link to post Share on other sites More sharing options...
Benarsenal Turbocharged April 7, 2013 Share April 7, 2013 Well, Saab is now gone, but Eurokars will still do servicing for existing Saabs as best as they can. Link to post Share on other sites More sharing options...
XWD Neutral Newbie April 7, 2013 Share April 7, 2013 There are a few Saab specialists out there who have access to parts. Though don't expect it to be as widely available as other common makes. I recall reading the Saab spares/parts company is back in business in Sweden. And there's talks about Saab 9-3 resurrecting too but it isn't confirmed. Likely as an EV first. Link to post Share on other sites More sharing options...
Chickenbackside 1st Gear April 7, 2013 Share April 7, 2013 I had one until quite recently. Loved it while I had it. Only changed it cos I needed something bigger. Parts should not be a problem between Eurokars, Saab stockists and specialist workshops like Griffin and AKH. But if it's a rare part, you will probably need to wait a bit. No big deal really. Even my Merc and VAG car parts sometimes need a little waiting time. Pre facelift: Facelift: Link to post Share on other sites More sharing options...
ER-3682 Twincharged April 7, 2013 Share April 7, 2013 I used to drive an Rover 75,which went bust,yes,the Agent TranEurokars can get for you the parts,but all flown in by U.P.S.,the price of common items became very expensive,imagine 1 A/C filter costs $400.00 Inc Labour... Link to post Share on other sites More sharing options...
20G 1st Gear April 7, 2013 Author Share April 7, 2013 thanks guys for the heads up on the parts. but wat abt the reliability part? chickenbackside: will the top gets jammed? imagine sudden weather change and gonna pour soon then ur top gets jammed. then u gotta join the motorcycle folks under the bridge for shelter. lol so wats the diff between the old one and the newer one? power? features? the price differs quite alot between the 2 being the newer one having a higher depre. Link to post Share on other sites More sharing options...
Babymiaomiao Neutral Newbie April 7, 2013 Share April 7, 2013 Is this the one in fifty shades? Link to post Share on other sites More sharing options...
SGCMsmallcar 4th Gear April 8, 2013 Share April 8, 2013 HI, Im driving a saab 93 saloon. No problem on parts n repair. Just join the local saab forum and u will be surprised that parts can be ordered from UK cheaper than Japanese car. http://www.saabstance.com Link to post Share on other sites More sharing options...
Chickenbackside 1st Gear April 8, 2013 Share April 8, 2013 thanks guys for the heads up on the parts. but wat abt the reliability part? chickenbackside: will the top gets jammed? imagine sudden weather change and gonna pour soon then ur top gets jammed. then u gotta join the motorcycle folks under the bridge for shelter. lol so wats the diff between the old one and the newer one? power? features? the price differs quite alot between the 2 being the newer one having a higher depre. Never jammed on me. In any case, there is a hydraulic pump bypass in the boot. You can disengage the pump and put up the top manually. Of course, if you're not familiar with the steps, you'll get pretty wet trying to figure it out while reading the manual. Mechanically, no change between pre and post facelift. Only cosmetic changes. I've said this before, it's one of the most reliable cars I've owned. Hardly anything went wrong with it. A window regulator was the biggest thing that went kaput. Other than that, just oil, filter, brake pad, disc and tyre changes. But do near in mind that it is rather dated to drive. You know you're in a car that was designed a long time ago. But the fun factor makes up for it, especially the fact that you can raise or lower the top on the move. Check the condition of your key. The rubber key tends to "melt" badly. Link to post Share on other sites More sharing options...
20G 1st Gear April 8, 2013 Author Share April 8, 2013 HI, Im driving a saab 93 saloon. No problem on parts n repair. Just join the local saab forum and u will be surprised that parts can be ordered from UK cheaper than Japanese car. http://www.saabstance.com hi, great to hear dat. am glad that parts and repair is not much of a hassle. ive tried to register in dat forum 2 weeks ago and im.still.pending for approval. lol! Link to post Share on other sites More sharing options...
20G 1st Gear April 8, 2013 Author Share April 8, 2013 Never jammed on me. In any case, there is a hydraulic pump bypass in the boot. You can disengage the pump and put up the top manually. Of course, if you're not familiar with the steps, you'll get pretty wet trying to figure it out while reading the manual. Mechanically, no change between pre and post facelift. Only cosmetic changes. I've said this before, it's one of the most reliable cars I've owned. Hardly anything went wrong with it. A window regulator was the biggest thing that went kaput. Other than that, just oil, filter, brake pad, disc and tyre changes. But do near in mind that it is rather dated to drive. You know you're in a car that was designed a long time ago. But the fun factor makes up for it, especially the fact that you can raise or lower the top on the move. Check the condition of your key. The rubber key tends to "melt" badly. so the hearssay is a myth. haha. nvmind abt the dated look. like wat u mentioned, fun factor makes up for it. thanks for the info guys! Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged April 8, 2013 Share April 8, 2013 hi, great to hear dat. am glad that parts and repair is not much of a hassle. ive tried to register in dat forum 2 weeks ago and im.still.pending for approval. lol! pm acemundo for mod contact, that's how i got mine approved... you changing to saab?? Link to post Share on other sites More sharing options...
RadX Moderator April 8, 2013 Share April 8, 2013 thanks guys for the heads up on the parts. but wat abt the reliability part? chickenbackside: will the top gets jammed? imagine sudden weather change and gonna pour soon then ur top gets jammed. then u gotta join the motorcycle folks under the bridge for shelter. lol so wats the diff between the old one and the newer one? power? features? the price differs quite alot between the 2 being the newer one having a higher depre. use umbrella lo [laugh] Link to post Share on other sites More sharing options...
Chickenbackside 1st Gear April 8, 2013 Share April 8, 2013 so the hearssay is a myth. haha. nvmind abt the dated look. like wat u mentioned, fun factor makes up for it. thanks for the info guys! A very simple thing you can do is listen and watch the top as it goes up and down. Just make sure there are no groaning or funny noises in the process and that the operation is relatively quick and smooth. If it is sluggish and you hear groaning noises, get the dealer to fix it first or bargain down and fix it yourself (will probably be a $1k+) job. Link to post Share on other sites More sharing options...
RadX Moderator April 8, 2013 Share April 8, 2013 hi, great to hear dat. am glad that parts and repair is not much of a hassle. ive tried to register in dat forum 2 weeks ago and im.still.pending for approval. lol! lucky u no get beetle.....cos if u do cnfm porker bf type [laugh] Link to post Share on other sites More sharing options...
Acemundo Supercharged April 8, 2013 Share April 8, 2013 erh saab brand is not gone le......they were bought over by NEVS. but i can understand why many guys don't know. when saab went bust, the newspapers all reported. but when it was rescued, the papers were all silent. Link to post Share on other sites More sharing options...
RadX Moderator April 8, 2013 Share April 8, 2013 I am thinking abt going for the above. However, I am having concern on it's parts availability and reliability. Anyone with experience can share info on this? By the way, what is the difference between the pre facelift and facelift one apart from asthetically different? can't go wrong bro.....i like Saab interior. Good buy IMO Link to post Share on other sites More sharing options...
RadX Moderator April 8, 2013 Share April 8, 2013 erh saab brand is not gone le......they were bought over by NEVS. but i can understand why many guys don't know. when saab went bust, the newspapers all reported. but when it was rescued, the papers were all silent. yah lor......pity to have it go down the drain. Lucky got savior for the brand. i know a few Dr friends who love their Saabs ↡ Advertisement Link to post Share on other sites More sharing options...
NEVS Emily GT: Saab engineers shock with 621-mile EV
Daihatsu Copen
Daihatsu Copen
Would you fancy a BMW Convertible SUV?
Looking for SJH1597C
Saab cars
Saab cars
Convertible cars.
Convertible cars.
Squeezing sound after suspension replacement
RIP Saab
RIP Saab
